Question about Norcent Technologies DC-1020 Digital Camera
Lost USB cable - what type/size?
This usb cable opening is much smaller than any of the ones we have around the house. Anybody know what kind it is so that I can buy a new one?
Norcent's site did not have a user manual. The spec list just says "usb cable" and does not specify the type/size so that I can search for a new one.
  • imnangel469 Jan 20, 2009
    HI ..I am having the same problem but I broke mine and need it replaced. cant seem to find out anywhere what size USB to buy!
2 Suggested Answers
  • 14 Answers
SOURCE: usb cable and battery i need one.
Try going to best buy or to Radio Shack.
Posted on Apr 17, 2009
I have an Acer Aspire 380 w/9 in 1 card reader, where do I find the schematic?
you'd do better taking it to a pc tech. hooking up anything wrong would spell disaster. having said that, there are only 5 kinds of plugs on the board: USB, Audio, Power, intrusion switch, and fans. Power ones are big and come from a big silver box with thick wires. USB ones are smaller but are bunched into a thick cable that houses several smaller wires and leads to a 9 post square jack. The audio wire looks *almost* like the USB wire, but it is usually yellow, where the USB one is green blue and/or black. The fan wires go to the case fan, cpu fan, and any other fans installed. finally there are some systems that have chassis intrusion switches that trigger an alert to let you know the case was opened (in case you suspect someone tampered with your pc's innards). The 9 in one card reader is not much more than a USB device. It would attach to any one of the 9 pin USB points on the system board. It usually looks like this [::::.]
Jun 09, 2014 | Computers & Internet
Just bought an Ativa 7 port USB 2.0 Hub and don't know how to connect it to my computer. No manual came with it.
The ones that I have seen have 7 ports 5 in back 2 on top these are called Type A USB ports, to the left of the back ports the power port is there. To the right, there is a smaller port usually a USB Mini B or Micro A port that is where the small end plugs into and the Type A on the cable goes to your computer.
Jan 12, 2013 | Computers & Internet
Usb program cable wont install on computer
You've not supplied enough info, usb cable won't install on computer could be misunderstood.
But if what you mean is that the usb cable is the wrong size to the usb hub on your computer, then that makes sense.
There are currently three or four types of usb and sizes, two of which are PC types, these being usb version 2.0, and usb version 3.0, one is smaller than the other, the latter being smaller.
If you have a PC built after 2006, you should have both versions, but if your PC is older, then you'll only have version 2.0, and that could be the reason for the problem.
However, if I've misunderstood your query, then I'm sorry, but you need to give detailed info as to the problem, so that I can understand what it is you're trying to say, otherwise confusion reigns.
I hope I have been of some help.
Regards,
Peter
Oct 17, 2012 | Kenwood Kpg-134d V2.31 Programming...
My HP4600n uses a parallel cable, but when I look at CDW site, that only cabel it appears to use a 36pin, but the paralle connection on this printer is much smaller than 36. Are small size cable around,...
The parallel cable on the HP 4600n is a smaller C style connection not the typical larger B style. If you ar looking for a parallel cable ask for an A-C cable. So far I have not seen a USB adapter for this size. I would suggest using the Ethernet cable if it is a 4600n.
Jun 09, 2010 | HP Color LaserJet 4600n Printer
Plesase tell me what cord to purchase to connect my DSC-W-30 camera to the computer, I know it is a USB cord but what is the nomenclature of cord itself?
USB cable kinds can be seen below.
In the upper picture from left to right the second one is "Mini B tip USB" cable. You need this one. You can see mini B tip USB cable in a largers size picture below.
You can find this from any computer parts store. Or any market around you.
May 03, 2010 | Cameras
SHOW ME THE CORD FOR HOOK UP TO THE COMPUTER AND WHERE DO YOU INSERT?
Son of a ... They don't give you a USB cable in the box.
General Specifications OS Compatibility
Windows Vista™, Windows XP/2000 and Mac OS® X v.10.2.8 to 10.5.x9,11
Standard Interface
USB 2.0 Hi-Speed, PictBridge (Cable not included)
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=15603#ModelDetailAct
* It should be a standard USB 2.0 cable.
Well you need the kind that connects a printer. Type A connector on one end and type B connector on the other end. See this page.
http://en.wikipedia.org/wiki/Universal_Serial_Bus
and see this page for a better picture of the cable...
http://www.amazon.com/Belkin-F3U133-10-Hi-Speed-Cable-Feet/dp/B00004Z5M1
one end is kind of square with rounded upper corners kind of like a house, the other end is the standard flat rectangle usb connector that everyone knows from plugging in those USB memory things.
Nov 23, 2009 | Canon PIXMA MX310 All-In-One Printer
What is the cable connection like to a pc?
U need a cable that is USB type A to USB type B, type A is the rectangle, type B is like a square, here is a link to a photo of the 2 types
http://www.folcom.cz/img/USB_konektory.gif
Nov 02, 2009 | Epson Stylus Multifunction Inkjet Printer/...
What kind of USB cable comes with Sharper Image 10x25 binoculars
Go onto the www.Sharperimage.com web site if you look it will tell you that Sharperimage are in receivership but they do point you in the direction of a support comapny called N.E.W.
In reality you should be able to buy those leads from any decent camera shop or a place like Tandy
Jun 16, 2009 | Sharper Image Optics
I lost usb cord
I have only seen 3 different types of USB mini cables. 2 have a wider flare on the bottom and the third is actually USB micro which as a little bit smaller and has more than 5 contacts inside on the top and bottom. The 2 that are similar that I own are HP and SONY made for their specific cameras, but neither works 100% in the other brand. I though they were standardized but I find that one has 5 contacts in it and one has 4. Look on Ebay, very cheap and youll get your correct cable.
Feb 10, 2008 | Polaroid i733LP Digital Camera
Norcent Technologies DC-1020 Digital Camera Logo
375 people viewed this question
Top Norcent Technologies Cameras Experts
vwong
Level 1 Expert
Greg Cann
Greg Cann
Are you a Norcent Technologies Camera Expert? Answer questions, earn points and help others
