Question about Fujitsu ScanSnap S510
Lost cd to scansnap s1500 - Fujitsu ScanSnap S510
    Problem Solver:
  • 13 Answers
If you are unable to find the exact drivers then connect your device to PC and run driverscanner tool to find the recommended drivers. You can get the tool here:
DriverScanner2013.net
Posted on Nov 06, 2012
3 Suggested Answers
  • 25 Answers
SOURCE: I need a driver for my Fujitsu ScanSnap S1500. I
You will probably have to call Fujitsu to advise them of your problem and get the Adobe Acrobat 9 license once again as well as the driver you require. You cannot move this scanner from one computer to another without first deleting it from the first computer. Fujitsu is very helpful and will give you great advice.(I kept forgetting to delete the program before moving it to another machine and they were very helpful when I called to ask what to do.)
Posted on Apr 12, 2011
drifterK
  • 4924 Answers
SOURCE: My ScanSnap S1500 does not
To scan a document into the computer you have to start the scan from the manager on the computer ...and there for you need it installed if you do not have it ..The button on the scanner will not send the scanned result to the computer ...but if you choose the job from the desktop command ..
so ..open the printer/scanner utility ..choose scan ..and the mode document or picture..and proceed..
it will ask you where to save it ..or auto place it in the my documents /my scans
If you do not have the complete software ..here is the download support on the site of the manufacturer and you can get the full version from there ..
http://www.fujitsu.com/global/support/computing/peripheral/scanners/ssfaq/setup-pg.html
get the download form ..fill it up ..and get the snap scan manager ..and use it ...if you have it ..just open it and make the scanning from there ..
Posted on Jan 13, 2011
Drivers for s1500 not installed
http://www.fujitsu.com/global/support/computing/peripheral/scanners/software/s1500.html
Go here for the drivers, depending on your OS, select the proper install. make sure to check to see if you will need to also install the update found in the Update tab (windows 7 + usually)
Oct 21, 2013 | Fujitsu ScanSnap Manager
NEED SCANSNAP 1500 DISK NEW SCANNER DISK IS LOST
don't know if you ever got this resolved but....
check under the operating system tab to select the right installer for you.
Mar 23, 2013 | Fujitsu ScanSnap Manager
Fujitsu s1500 can not get setup disc to work
Try setting up the scanner manually, click on start then control panel open scanner and cameras, in the upper left side click on add an imaging device, installation wizard will come up, click next then click on have a disk, browse setup disc and locate the driver of the scanner.
Jul 13, 2012 | Fujitsu ScanSnap S1500 Deluxe Bundle...
Scansnap s1500 wia driver
scansnam s1500 wia drivers for windows xp, 7, 8 (32/64bit) can be found at driverupdate us
I hope I have helped you...
Take a look, and enjoy
Jun 19, 2012 | Fujitsu Office Equipment & Supplies
My scanner keeps flashing and not pulling the paper through, I cannot seem to figure out why it will not scan. It does this quite often, what is the problem that is causing this? Scansnap S1500
Go to msconfig or if you have a registry cleaner, go to the startup menu. Disable and ssmgr (scansnap manager in pfu). Reboot. Open the ScanSnap 1500 and then start the ScanSnap manager. The scanner is now ready to scan.
Jan 26, 2011 | Fujitsu ScanSnap Manager
I need a driver for my Fujitsu ScanSnap S1500. I don't have the disk any longer. Anyone got any suggestions? Thanks!
Jan 11, 2011 | Fujitsu ScanSnap S1500 Instant PDF...
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
PFUSSMON HAS STOPPED WORKING ON MY SCANSNAP S1500
Find your specific scansnap product and update it:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
A user had a similar issue and I found this update for the scansnap S1500 manager:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
This occurs with certain Intel dual core processors, so you might be effected accordingly.
--Rob
Jul 08, 2009 | Fujitsu ScanSnap Manager
Fujitsu ScanSnap S300 PfussMon has stopped working
--Rob
Apr 09, 2008 | Office Equipment & Supplies
Fujitsu ScanSnap S510 Logo
249 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
