Question about ASUS Transformer Tf300t Tablet
Asus t300 change language
Its in chinese or japanese and need it to be in english
Help with setting up Kindle Oasis received as gift.
Just tell it to:
Hit the small microphone and say: change tabblet setting to English language please. Let me know
Dec 22, 2016 | Tablets & eReaders
How do you change language on Polaroid 9" Quad-Core 32GB Android Lollipop Tablet
SOURCE: Changing Language on MID Android Tablet Try this YouTube video, it shows how to change from Chinese to English and you can see from the menu> layout which menu items to press.
Click here
How to change language for Apad iRobot iPed Android Tablet using Eken M002
Sep 17, 2015 | Tablets & eReaders
How do I change the language back to english?
Either look on the keyboard for a symbol of earth near space bar ....thus will change language ....or go into menu settings and look for language.if it is a language you can't read use another device which you can use google translate and convert English into Chinese ...japenese to see what it looks like in another language.then you will be able to select right option if menu is unreadable.
Feb 28, 2015 | Tablets & eReaders
Language change from Chinese to English ?
Ive done this as well. The only way was for me to look at another tablet, the same as mine and then go through each step until I found the language change button and then counted down the list until I found "English" If you have another tablet or PC access to the net, you may be able to find a guide for your machine.
Jan 03, 2015 | Tablets & eReaders
My hipstreet flare tablet language got changed to japanese how do i get it back to english
tap the system settings icon looks like equalizer to stereo then tap on language settings then select what language you want
Aug 13, 2014 | Hipstreet FLARE Wi-Fi 9" Capacitive Touch...
Everything is in chinese
To change your language go to:
Settings > Languages & input > Language > Select the one you want.
If the tablet is in another language and you cannot read any of the labels, please follow the instructions below:
Get into settings. The icon looks like three bars with small ovals intersecting them. From here, you should see a list of icons on the left side of the screen, followed by text (which may be incomprehensible). Look for the Languages & input icon which looks like an A in a white box. From the following menu, choose the very top option. It doesn't matter if you can understand the text or not - it says "language." The following menu should show a list of languages, each as it's described in that country. For instance, English is written as "English," but German is "Deutsch." In other words, it should be very easy to find the language you understand - just look for it from the list of options and it should be immediately legible. Once you tap your language option, the system language should change and you should be able to understand the rest of the system menus.
Support Troubleshooting Guide
Apr 06, 2014 | Kocaso 7" Capacitive Touchscreen Tablet...
7" Zeepad tablet switched to Japanese somehow.
Hi!
To change the language back to English on your Zeepad tablet, try the following:
1) Tap the Settings icon (in some versions, it is a square icon with blue lines, in others, it looks like a small gear).
2) Scroll up and tap the "Language & input" icon (a square icon with the A letter).
3) Now, tap the "Language" selection (the topmost one)
4) Tap on "English (your country)" and then tap the arrow to go back.
Hope you may find this answer helpful!
Best regards,
Miguel L. Martins
Dec 05, 2017 | ZEEPAD MID Android Tablet 7 Inch WiFi
How do i change my lenovo a1 from Japanese to English
it may be time consuming but 1 way iv always solved this problem (with other electrical apliances) is to go through every setting posibility untill u see the word english ( witch is always writen in english ) and select it. or google the products manual to get a better indication as to where the language setting may be. hope this helps and good luck
May 07, 2012 | Lenovo IdeaPad A1 Tablet with 16GB Memory...
Try this YouTube video, it shows how to change from Chinese to English and you can see from the menu layout which menu items to press.
Click here
Gadget
Feb 21, 2012 | Coby Kyros Internet Touchscreen Tablet...
ASUS Transformer Tf300t Tablet Logo
48 people viewed this question
Top ASUS Tablets & eReaders Experts
Alun Cox
k24674
Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
