Question about Dryers
Dryer works with no heat. I checked the follwing, heater,hi lmt thermostat and thermal cut-off,all good.I noticed the status (wet,damp,cool down and done) light is not lited. Your kindness will be hightly appreciated. Thank you jerry
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 06, 2012
docjohn174
  • 943 Answers
SOURCE: Whirlpool dryer won't heat
hi. thanks for letting me answer.the only part that was not mentioned. is the timer contacs Y & R . the heat contacts in the heating circuit. thanks
Posted on Sep 29, 2008
dididsaythat
  • 291 Answers
SOURCE: Roper household dryer not heating
you can unhook themal cut out or themostates hook the two wires together tape or make sure they dont touch anything and test dryer.. if heat comes on thats the problem
Posted on Sep 15, 2007
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
  • 2920 Answers
SOURCE: Whirlpool Senseon Dryer-drum doesn't spin & stuck on sensing mode
the belt on the drum could be broken
Posted on Feb 16, 2009
SOURCE: Thermal cut-off blows and high limit thermostat is
in this case we put the lower temp thermostat in the oven at 170 degrees till it was hot and measured with ohm meter and it was open. After it cooled down some it went back to being a short. Now with this part in the dryer and the new high temp thermostat
and it blew shortly after being turned on. A possiblity is that there is a short by passing the 150 degree thermostat and the element keeps being on and causes the 350 degree thermostate to blow.
Posted on Apr 07, 2010
Kenmore elite quietpak 9 he4 cuts off after drying clothes for a while. clothes are still damp
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 27, 2014 | Dryers
Why is my dryer running, but not heating up or drying the clothes?
Jun 23, 2014 | Kenmore Dryers
Electric dryer getting way too hot
3-5 ACCESS TO THE BLOWER WHEEL OR THERMOSTATS
To get to the blower wheel, remove the back of the dryer.
The blower wheel is under the bottom of the lint screen duct to your left, as you look at the back of the dryer.
The operating thermostats are at the blower wheel outlet.
In electric models, the hi-temperature cutout thermostat is mounted to the heat riser.
3-6 TEMPERATURE CONTROLS AND HI-TEMP SAFETIES
These clothes dryer machines use operating thermostats to control the temperature inside the drum, and hi-limit thermostats to prevent overheating of the dryer drum.. Many machines also have extra temperature controls, such as bias thermostats and heaters, hi-temperature cutoffs, and thermal fuses.
Bias thermostats are just like regular operating thermostats, except that they are mounted inside a bias heater. When the bias heater is energized, it generates a small amount of heat, which causes the operating thermostat to open sooner, keeping the dryer drum cooler inside. Thus a bias heater allows a single operating thermostat to act like both a hi-temp and a lo-temp operating thermostat.
A thermal fuse is found on the blower outlet, right next to the operating thermostat(s.) This fuse will blow when too high a temperature is sensed at the outlet; usually when one of the operating thermostats has failed. If it blows, the motor may not start, or you may get no heat (no voltage to the burner.)
A thermal cut-off is mounted on the clothes dryer heater box. It is a back-up for the hi-limit thermostat. Whenever you replace it, you should replace the hi-limit thermostat, too. A high-temperature condition causes it to open, an overheated grounded heat element may also cause it to open.
Dec 01, 2013 | Kenmore Elite HE4 Electric Dryer
Does the Kenmore Series 700 dryer use circuit breakers or a thermal fuse to shutoff the heating element?
All Kenmore Electric Dryers use a thermal cut-off or thermal cut-out, hi-limit thermostat, and a cycling thermostat apart from the motor centrifugal switch as parts of the heating circuit. The thermal cut-off/thermal cut-out and the hi-limit thermostat are located on the heater duct/element duct while the cycling thermostat is located on the blower housing.
The thermal cut-off/cut-out serves as a safety measure and blows open should the dryer overheats or should the hi-limit thermostat fails to cut off power to the heating element. Check the continuity of the thermal cut-off/cut-out and if open, replace it including the hi-limit thermostat.
Aug 22, 2011 | Dryers
Element not heating
If the model number is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance: http://pcappliancerepair.com/model-display.php
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 6)
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 20)
Thermal Fuse (Item 19)
If the dryer is running, but not heating, this is not always an indication of a blown heating element. If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
The MOST common causes of a dryer that will not heat are:
1. Blown Thermal Cut-Out (replace the Hi-Limit Thermostat along with the TCO if found to be bad). 2. Bad Heating Element.
3. Missing all , or part, of your input voltage at the wall receptacle - double check your source voltage at the receptacle and/or your circuit breakers.
4. Bad power cord. Check the terminal block on the back of the dryer with the cord plugged in. If the voltage is good at the receptacle, but missing a the terminal block, you may have a bad power cord.
Read through all the information provided and let me know if you have any questions, or need further assistance. I hope you find this information helpful.
NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Apr 19, 2010 | Whirlpool LER4634J Electric Dryer
Roper dryer Mod# REL 4636BW Worked fine this morning, does nothing this evening. Breaker not tripped.
1. Heating Element
2. Thermal Cut-Out
5. Thermal Fuse
Thermal Cut-Out (Item 7)
Internal-Bias Thermostat (Item 6)
Thermal Fuse (Item 8)
The MOST common causes of a dryer that will not turn on is:
1. Blown Thermal Fuse
2. Missing all , or part, of your input voltage at the wall receptacle - double check your source voltage at the receptacle and/or your circuit breakers.
3. Bad power cord. Check the terminal block on the back of the dryer with the cord plugged in. If the voltage is good at the receptacle, but missing a the terminal block, you may have a bad power cord.
Apr 08, 2010 | Dryers
No Heat.Which terminals on the cycling thermostat do you need to check to test it.
Check the continuity of the cycling thermostat using an ohmmeter set to X1. Disconnect one wire from the cycling thermostat terminals then connect one test lead of the ohmmeter to each terminal. The reading is zero ohms for an apparently good thermostat; further test is required to check its operation.
Unscrew the cycling thermostat from the heater housing and pull it out of the dryer. Using a pair of needle-nose pliers or similar tool, hold the thermostat over a burner and verify if it clicks when heated. Carefully check the continuity immediately before it clicks again. The ohmmeter reading is infinite (open) and zero ohms when the thermostat cools down and clicks again. A good cycling thermostat cycles off when heated, and on when it cools down.
Every heating circuit component in the heater housing need to be checked when the dryer is not heating. Set the ohmmeter to X1 and measure the resistance between the heating element terminals. The resistance depends on the model of your washer. Replace it when the ohmmeter reading is infinite (open).
The thermal cut-off fails when the cycling thermostat fails to cycle off. Check the continuity of the thermal cut-off. Disconnect one wire from its terminals and connect one ohmmeter test lead to each of the terminals. The resistance is zero for a good thermal cut-off.
A blown thermal cut-off is an indication of a failed cycling thermostat. The cycling thermostat must also be replaced when the thermal cut-off is blown. Just unscrew the blown component and screw the new component in place. Specify the brand and model number of your washer for the specific replacement parts.
Warning: Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Mar 23, 2010 | Dryers
I have a whirlpool dryer model# LEN2000JQ1 It won't heat up. I have had the heating element and thermal fuse tested and they tested good, there is no restriction in the venting system. what could the...
Just check all of this:
  • Check for proper air flow
  • Test the safety fuse
  • Test the thermostat
  • Test the centrifugal switch
  • Test the timer motor
  • Test the heating element
If a thermostat fails, it may prevent the heat from coming on, This happens because the thermostat does not close the circuit when the temperature falls below the operating temperature of the switch. It is a simple matter to test a thermostat; it should show continuity when the switch is cool and no continuity when it is warmer than its rated temperature.
A thermostat can also fail by being always on, no matter what the temperature. This switch would show continuity whether it was hot or cold. In this case, the heater would not shut off and the the dryer could dangerously overheat. As a safety precaution a second thermostat is used, a thermal fuse. The power will be cut to the heating circuit if the maximum safe temperature is exceeded. In most cases, this is a one time fuse. The heater circuit will not function until the fuse has been replaced. Of course, it will be necessary to determine and repair the underlying cause of overheating or the fuse will just cut out again.
The thermostats are usually grouped together. The are typically oval in shape and about an inch and a half in size. They may be on the blower housing, under the lint trap or inside the vent line. There should be two wires connected to each thermostat.
Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Regards:
VOTIT
Don't forget to rate:
Jul 08, 2009 | Whirlpool Dryers
Roper Gas Dryer
The first thing I would check is the thermal fuse (#6 on the bulkhead parts break down diagram). Replace if it's open.
Also, the manufacturer recommended to replace the cycling thermostat (#8 on the bulkhead parts break down diagram) too if the thermal fuse is open.
- The part number for the thermal fuse AP3132867
- The part number for the cycling thermostat AP3131939
- Here are the break down diagrams for the Roper dryer Model RGX4634KQ2
"Did it solve your problem?"
Jan 28, 2009 | Roper RGX4634KQ Gas Dryer
Sep 15, 2007 | Dryers
Open Questions:
Dryers Logo
Top Dryers Experts
