Question about E-Machines T2082 PC Desktop
Blank Screen Computer powers up but the screen is blank. I have tried moving the RAM to the other port without change. The hard drive is spinning. What would be the next thing to check? I really dont have a lot of money to put into this project. Thank You, V
  • 6 more comments
  • lindon_oj Jan 05, 2009
    you need to change the monitor
  • BIg VIc 62 Jan 05, 2009
    I failed to mention that the monitor is working fine I tested it on another computer. And the RAM I used was the same RAM that was in it, I just tried putting it in the other RAM slot, someone suggested that I should try that.
  • BIg VIc 62 Jan 06, 2009
    The cable connects to a graphics card, not directly to the motherboard. I have checked the monitor and it works.
  • BIg VIc 62 Jan 07, 2009
    I have been trying to locate a system to install that video card into, I just don't have another desktop handy. When I plug the monitor into the back of that computer the LED stays orange, indicating that the monitor is in "standby" mode, whend the monitor is active the LED turns "green". I'm looking for someone willing to let me use their computer in order to diagnose mine. Thank You for your input.
    V
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    Ok. Just drop me a comment to let me know the result. I will assist you. Anyways, you have an on board VGA port of your motherboard, right? Is it still working? If it is, you can test it there. Connect it directly on your VGA port of your motherboard first so you won't have difficulty to find another pc to work on it.
  • Jarish Castañeda
    Try to insert your graphics card to the other computer's graphics card slot first. Make sure the other motherboard slot has the same type of graphics card used.
    *Drop me a comment so I can assist you further.
  • Jarish Castañeda
    Where is your VGA cable connected? Is it on your on board VGA of your motherboard or you are using Graphics card?
  • Jarish Castañeda
    Hi, that's not a memory card problem. Where is your VGA cable connected? Is it on your on board VGA of your motherboard or you are using Graphics card?
    Master:
    Sergeant:
  • 482 Answers
Have you changed out the mother board? It could be the processer or the ram is not the right kind.
Posted on Jan 05, 2009
I turn on my Laptop and the fan will spin and the Hard disk light will turn on as well as the power light (obviously) But the Hard drive doesnt spin up and the screen stays blank no lights no nothing i...
Remove all of the ram, turn the laptop on if it does not beep you have a bad motherboard. If it beeps replace the memory and remove the hard drive turn on the laptop and see if it posts. If it posts without the hard drive then the hard drive is bad. Otherwise it is probably still a bad motherboard.
Apr 24, 2011 | Computers & Internet
Computer monitor is blank. No signal is received at any time. Currently using motherboard VGA port. I tried 2 different monitors and 2 different VGA cables. I then installed a new graphics card but still...
Disconnect all PCI Cards and unplug power to all Drives then reboot your computer using the motherboard VGA port to see if the monitor will POST. If you still have a blank screen you most likely have a bad motherboard.
Nov 27, 2009 | Computers & Internet
I have a dell monitor that the power light is on but yet the screen is blank? Changed both vga cable & power with no effect?
Pls check that the your system is working or hang on the blank screen .For system check pls press the Num lock button on your keyboard its on/off or not.If your keyboard Num lock button is on/off then Problem with your Monitor might be might be EHT is faulty its better call vendor for repair.If system hanged on blank screen then problem with your RAM OR Hard disk or Operating system.
For Hard disk pls remove the power cable from Hard disk and on the system if not resolve then
Go for RAM,remove the RAM chip and re-installed another goods RAM ano on the system, If still blank screen then Problem with Operating System .Get it re-installed Operating system
Nov 16, 2009 | Dell E173FP 17" LCD Monitor
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
When I turn computer on the windows boot manager screen comes up. It says windows is having problems communicating with a device on the computer. It says this error could be caused by a removable storage...
Sometimes when you use ram sticks on some older computers they do not handle taking teh ram stick out of the USB port without first closing out teh device OR if you have the RAM stick in while you are booting the machine... it will select the ram stick as the boot device and appear there is no oprerating system present.
In you case when you go to the boot menu.. be sure the boot menu is set to select the hard drive as the primary boot device. If it is not then you can make the change at teh bott up screen.
Oct 04, 2009 | Dell Vostro 1510 Laptop
Blank screen after switching hp nx7000 on
You will find useful information and BIOS downloads here:
Notebook Does Not Startup or Boot Displaying a Blank Screen
BIOS update
Try the first link first. Update the BIOS after carefully reading all the instructions.
Oct 01, 2009 | HP Compaq Business nx7000 Notebook
Gateway screen comes up; optical and (new) hard drive spin up, both drive lights light up during this time, fan spins up and air moves out of the side vent continously but still nothing but a blank screen....
If you have an operating system disc that came with your computer try putting it is and see if you can load the disc. If you can go to the repair screen after it loads all files. When you are at command prompt type: chkdsk /r
It will try to repair operating system. When done type "Exit" and restart. If you can't load the operating system disc you might be having a graphics card problem. Go to the manufacturer's website and check on their forums for your problem. Hope this helps
Jul 05, 2009 | Gateway MX6931 Notebook
My Macbook A1181 won't boot. When I turn it on, I
Here the same problem now.when powerbutton is pressed I hear de boot sound and only a blank screen is what you get
Jun 28, 2009 | Apple Computers & Internet
Blank screen
Look very closely at the screen when its on, see if you can see a faint image in which case the ccfl tube in the screen will be dead. Also try the laptop on an external monitor.
Otherwise if you know what your doing, remove the battery, hard drive, optical drive, all but one stick of ram, modem/wireless card and try again. There is a small chance it will be the cpu or motherboard.
Jun 16, 2009 | Averatec 3200 Notebook
Pc hangs up oftenly or show blank screen
Set your C Drive as Master and other all Drives as Slave
I Think this will slove your problem
Try IT
Mar 07, 2008 | Intel D845GVSR Motherboard
E-Machines T2082 PC Desktop Logo
71 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
