Question about Lenovo ThinkPad R60 Notebook
I added RAM to my laptop and when I turn it on it will not start even with the battery pack out.
  • Lenovo Master
  • 7,627 Answers
Is the ram of the same type?Is the ram seated properly? I'm not sure what the battery has to do with you issue. Replace the Original ram and try to Start.
Posted on Nov 06, 2012
Black screen open
hi
First of all if you can remove the ram memory DO IT SO ifyou cant try without removing FIRST.
-remove battery pack(if you can romove memory ram aswell) and wait 10 mins
-now start charging laptop without battery pack for 2 mins
-unplUg the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DONT PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILLSTART ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK ANDCONTUNUE TO USE YOUR LAPTOP
May 26, 2011 | HP Mini 1000 Netbook
My laptop is not display for a week now it is MSI 10X Series
hi
if your laptop is booting properly then foll up following steps
May 26, 2011 | MSI MegaBook S250 Notebook
I have a compaq presario CQ61 and i turn it on and everything works but my scrren stays black. what is the problem?
HI
Feb 26, 2011 | HP Compaq Presario CQ61420us Notebook
4 beeps on my Hp pavillion dv6000, blank screen
No Screen on Pavilion DV2000T
I had this problem before. Tere is a good chance this may work.
First of all remove the ram memory.
-remove battery pack and wait 10 mins
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START. ONCE YOUR SYSTEM IS READY SHUT IT DOWN PUT THE RAM AND BATTERY PACK BACK AND CONTINUE TO USE YOUR LAPTOP.
It hope fully will work as if you get one or more beeps, the POST is completing alright.
Hope that helps.
Dec 10, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
How fix a blank screen on a laptop
hi
Nov 09, 2010 | HP Pavilion dv6000z Notebook
Black screen
hi
-remove battery pack(if you can remove memory ram as well) and wait 10 mins
-unplug the power AND press and hold the power button for 45 seconds
-REPLUG THE POWER CABLE BUT DON'T PUT THE BATTERY PACK YET
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILLSTART ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK AND CONTINUE TO USE YOUR LAPTOP
Nov 02, 2010 | HP Compaq nc6400 Notebook
Blank screen
hi
NOW OPEN THE LID WIDER YOU CAN PRESS POWER BUTTON YOU WILL SEE YOUR SYSTEM WILL START ONCE YOUR SYSTEM BE READY SHUT IT DOWN PUT THE BATTERY PACK BACK AND CONTUNUE TO USE YOUR LAPTOP
vote me if you find your solution
Jul 07, 2010 | Sony VAIO R505JL Notebook
Laptop will not turn on
Some laptops will not turn on if the battery pack has a fault.
Remove the battery pack (usually the pack is easily removed by unlocking a tab and lifting or sliding out the battery pack from underneath the laptop) and then try turning it on with just mains power applied.
Worse case, take your laptop to a reputable repair agent (call Dell for help) or have a computer geek friend remove your laptops 2.5 inch internal hard drive, mount it in a temp installation eg in an external hard drive case with USB connection to another computer) and extract the lost data.
A 2nd idea, check that the RAM (computer memory used by your laptops processor) has not dislodged. Usually you can get to the RAM by removing a small plastic cover underneath your laptop. The RAM looks like a large piece of gum (approx 2" x 1") with a few memory chips on it. If you have two sets, try removing both and just inserting one at a time. You may have a bad piece of RAM. Be careful of static when handling your RAM as this is damaging to electronic circuitry. Most RAM is released by pushing two tiny locking levers away from the RAM ie to the left and right. Re-inserting RAM involves inserting the RAM on an approx 35 degree angle towards the edge connector on the laptop motherboard and then gently pushing the RAM downwards until the 2 locking clips engage.
if you have no luck, ring Dell. Hopefully you have some warranty left on the laptop. if not, go to a reputable repairer.
Good luck,
Steve (Melbourne,Australia)
May 14, 2010 | Dell XPS M1530 Laptop
Unstable after RAM increased to 1.21 GB from .5 GB
If you have another PC, use ImgBurn or another program to burn a bootable CD (ISO) or bootable floppy (if your laptop has a floppy drive) of MemTest86+
If you don't have another PC to burn the image with, remove the newly-added RAM to get your laptop back to a stable state and create the CD or floppy disk.
(Reinstall your added RAM if you removed it earlier)
Boot your laptop with the MemTest86+ CD. Make sure the "Passes" goes to at least 2. If any errors are found they will be listed. If errors *are* found, then either your new RAM is not 100% compatible with your system, it is defective, or it is not compatible with the RAM already on your system (if your laptop has more than one slot for RAM).
Change the RAM configuration (replace the RAM, remove old RAM if your laptop has more than one RAM upgrade slot) and repeate the MemTest86+ test until you get through at least 2 passes without any errors.
Despite what people (even manufacturers) say, not all memory is created equally, and faster memory modules don't always work in place of slower ones. Likewise, you can have two memory modules that work perfectly fine in a system when they are alone, but don't work together in the same system.
Aug 13, 2008 | Toshiba Satellite M35X-S149 Notebook
Acer aspire 2920
Gen the problem is that your pc is too slow to take this much load the best thing is too move your pc back to windows xp professional 32bit service pack 3 or vista homr premium service pack 1 and try upgrading your pc by more ram if it can take it
Thomas Gonsalves
Aug 08, 2008 | Computers & Internet
Lenovo ThinkPad R60 Notebook Logo
23 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Lee Durbin
Lee Durbin
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
