Question about Optimus H-4436 Electric Heater
Alarm light stays on and there is no heat - Optimus H-4436 Electric Heater
  • 4 Answers
On the back there's a round cover held on with 3 Philips screws. Remove it. You should see a peice of thermal/electrical insulation with a red wire going in one end and a white wire on the other end. It's screwed down with a wire hanger and covering a 15Amp FUSE. Its part number is "SF119U-1", made by SEFUSE, rated 15Amps/125degC. The sell for about $5 for 5 of them. You can get one at RadioShack or better yet, replace it with a thermal circuit breaker (part # R59-15A), which costs about $5, but the nice thing is that if/when it trips, you can reset it instead of replacing it.
Posted on Dec 11, 2012
While riding the key light or alarm light stays on 2010 FLHTC
Hi, David you may need an alarm reset for more information about your issue and valuable "FREE" downloads that you will need please visit the websites below, and for specific information or questions, please feel free to contact me at xlch@mail.com. Good luck and have a nice day. Security light stays on mean Harley Davidson Forums
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Harley Davidson Manuals Mark Workshop
http://www.stcharlesharleydavidson.com/OEMpartfinder.htm
Owner Manuals Harley Davidson USA
Instant Tech Relief $6
Mar 09, 2016 | 2010 Harley Davidson FLHTC Electra Glide...
Why does this thing not run continuously and stay on long enough to heat up a room?
I would guess the over heat sensor has failed .contact the manufacturer customer support
Jan 25, 2016 | Windchaser Heating & Cooling
2005 chevy uplander. The brake lights, turn signals, psd(both), pwr seats will not work. The psd alarm stays on while driving, heated seat lights turns on/off every 30_40 secs, built in compressor runs...
TURN KEY ON , REMOVE FUSES ONE AT A TIME ,TILL PROBLEM STOPS ,CHECK COMPODENTS , DIS CONNECT WIRES ONE AT TIME TIL PROBLEM STOPS,REPLACE DEFECTIVE PART OR RELAY
Jan 22, 2015 | Seat Cars & Trucks
Alarm went off had to disconnect battery to shut off, door open light stays on, interior light stays on door locks and window controls will not work
O.k. this is a security feature of your alarm the car now essentially thinks that it is being stolen. In order to fix this issue you need to reset the alarm buy reconnecting the battery and using your electronic alarm sensor if you have one (if this doesn't work get new battery for alarm sensor)
Jun 16, 2011 | 2002 Ford F350 Super Duty DRW Reg. Cab
Car alarm indicate led stay on all the time, although the lock and unlock work its a gm vsc3100 alarm system. Any help will be appreciate. Thanks
This is the aftermarket alarm may be time for a new set but before you go that direction the alarm light may have shorted to a power and not affecting the alarm itself by the way does the alarm horn work and is it diconnected because if it is it realy activated. If it isnt and alarm horn works but the light always stays on the the alrm internal relays doesnt switch over. The fix most area will make you get a whole new one
Apr 21, 2011 | Chevrolet S 10 Cars & Trucks
Buzzing alarm sound before ignition
The yellow or red light would mean a control board that is bad or going bad. The buzzing sound could just be the transformer not uncommon to hear a buzzing sound from the transformer.
Dec 16, 2009 | Heating & Cooling
Alarm red light stays on after you shut the car off 1998chrysler
I would turn the key on without starting the car then press and hold the black button till the alarm light flashes.Then turn key off take out of car and try the fob again.
Mar 29, 2009 | 1998 Chrysler Cirrus
Alarm light staying on.
I have the same problem. I removed the center panel on the back of the dish and found a fuse inside a white insulating sleeve. The fuse is open, preventing the current from reaching the heating coils. On the fuse it says 121 C. and 15 A.; I assume that it is designed to blow if the temp. of the dish exceeds 121 centigrade or the current exceeds 15 Amps. I don't see any reason to believe that either has happened so I suspect that these fuses just spontaneously fail. Now I just need to find a source for new ones. I wouldn't recommend jumping the fuse as it could lead to a fire.
Feb 22, 2008 | Heating & Cooling
Oki 520/521 logic boards
Check if the Pico fuse is blown ? next to the heat sink on the transisitor array with the number 2025.if the fuse is gone than the fuse plus the 2025 transistor must be replaced.
Dezzi
Nov 22, 2007 | OKI MICROLINE 520 Matrix Printer
Optimus H-4436 Electric Heater Logo
406 people viewed this question
Top Optimus Heating & Cooling Experts
Mack Baxter
Trippy Tripp
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
