Question about Whirlpool Dryers
Dryer whrilpool model# ywed9050xw1 is is working but no heat
  • Anonymous Mar 18, 2014
    trying to obtain wattage rating (power consumption) for electric dryer model YWED9050xw1
    Problem Solver:
  • 6 Answers
More than likely you have an open hi limit tsat....
a very simple repair i believe that model it can be found right on the element itself,, if you know how,, you can ohm it out...
but just to be safe make sure you unplug it,,, make sure you also have 120 on both sides of your dryer plug
Posted on Nov 06, 2012
Whrilpool dryer not heating up
MDG6400AW Gas Dryer: If you hear the click then the fuse is not blown. The ignitor is being powered up along with the sensor and coils. If the ignitor is not glowing then it must be bad. If it is glowing and shutting down then the sensor is doing its job. that leaves only them pesky coils. They are intermittent before they finally croak which means they heat a little then get hot and quit.
HOW THEY WORK
Slopefront service manual
Jul 23, 2012 | Maytag Atlantis MDG6400AW Gas Dryer
I have whrilpool dryer and I am getting no heat, dryer runs but no heat. Sensor and thermo fuse good. Timer keeps clicking if dryer is off but knob is in some cycle position not off position. Open door and...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 12, 2011 | Dryers
Whrilpool estate dryer model egd4400sqo not heating up
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 20, 2010 | Estate EGD4400SQ Gas Dryer
Whrilpool washer/dryer stack the dryer doesn't get hot
You will find that the drier wont get hot because the timer is not forwarding onto the heating part of the cycle. Possibly if you click one click at a time, you will possibly get to the heating part of the cycle but its not safe as it wont go any further. Install a new timer and you will be happier I'm sure.
Sep 28, 2009 | Dryers
Whrilpool gas dryer lgn2000jqd stops heating half way
u have a maf coil the dryer has a prim/ second coil remove and replaced come in a kit
May 12, 2009 | Dryers
Dryer not heatting
the model number you provided is actually the serial number. Most elements are in the rear if the lintr filter is on the top. If the lint filter is in the door the element is on the bottom.
Apr 08, 2009 | Dryers
Whrilpool gas Dryer Mod # LGR54636JQO
probably your exhaust vent is clogged, make sure every inch of it is clean. as a safety measure, if it is clogged, your dryer will not produce heat, because it will have nowhere to go
Oct 26, 2008 | Dryers
Whrilpool model# LGQ8000JQ1
It might have more than 1 thermal sensor, if you can find a manuel and check. Also if you have a leak on your gas connection(flex hose, ect.)
Apr 09, 2007 | Whirlpool LGQ8000JQ Gas Dryer
Dryers Logo
50 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
