Question about HP Photosmart M417 Digital Camera
Won't read sd card - says card not suppoorted
Hello - my recently purchased HP m417 camera will take photos with its internal 16 MB memory but when I put in a brand new 1 Gig Viking SD card it says CARD NOT SUPPORTED ... when I switch it to another 1 Gig SD card that I took from my working m417 HP Photosmart camera I get the same message ... CARD NOT SUPPORTED ... both cards work in my other working HP Photosmart m417 camera ... is there a fix for this recently purchased unit? - thanks - Hal
  • 1 more comment
  • Hal Hawley May 22, 2007
    Re: M417 Digital Camera SD fix: I don't have another smaller card but will seek out one. The reformat trick didn't work. My newly aquired M417 wouldn't reformat it. My old M417 recognized it and formatted the new blank 1 Gig SD. But even after reformatting the new 1 Gig SD the newly acquired M417 said CARD NOT SUPPORTED.
  • Hal Hawley May 30, 2007
    I picked up a 256 MB card and had to format it in my old m417 as the recently acquired one again said CARD NOT SUPPORTED. The new 256 MB card would not work in the recently acquired m417 after formatting. . It said NOT SUPPORTED. I think I'll cry.
  • Gemini1978 Mar 14, 2009
    says card not supported and I took it out of the same camera and put it back in and now it says card not supported
Did you try putting the card in the camera, and using the camera's "format" card option?(Make sure there is nothing on the the card-a format will delete it.) Often times, a digital camera requires a format of the card so the proper file/directory structure can be created. If the card is empty, you have nothing to lose.
Posted on May 21, 2007
    Scholar:
  • 125 Answers
I own an older version , M307. 1 gB SD works fine. in your case, there must be a problem with the interface (contact prblem). I agree with jackboy that there is no point trying for a smaller capacity card.
Posted on May 29, 2007
    Genius:
  • 2,985 Answers
It is strange that cards work with one M417 and not the other. I at first thought- card too large- but this appears not to be so. Do you have access to a smaller card just to prove the point? This does seem to be a fault - suggest you return it under warranty or at lest speak to HP tech support.
  • john ash
    john ash May 30, 2007
    If you are still getting card not supported then the camera has a fault and should be returned to vendor if under warranty or out for repair if not.
SOURCE:
Where can I get a card
Your hp photosmart m417 can use a secure digital (sd) memory card or a multimedia memory card (mmc), per manufacturer specifications.
Probably obtainable from local camera stores, computer stores, or via Ebay.
Mar 18, 2016 | HP Photosmart M417 Digital Camera
What does back-up to sd card mean?
the camera has internal memory and also will have the option for external memory. If you have a sd memory card in the camera you can backup the internal memory to the sd card.
Then you can remove the sd card and put in a new sd card and you now have an sd card with your precious photo memory's copied from the camera internal memory. You may have a camera that allows two sd cards one for the photos and one to back up the photos. If you had your camera stolen or lost you would lose all the photos on the camera but with a backup sd card you still have the photo files. Also a p.c with a card reader device could read the files on the sd card and you could copy them into a cloud storage on the net or onto a network storage device or onto a usb portable drive with 2 terrabyte capacity .
https://en.wikipedia.org/wiki/Secure_Digital
Jan 29, 2016 | Cameras
What size sd card needed for digimax A402 samsung? I purchased an 8gb and card read error? Do i need a 2gb? I purchased camera used and don't know what size sd card it uses???? U can email ans
Your camera has 16 MB of internal storage and will accept up to 516 MB of external storage. It will not accept anything greater than an 516 MB card. 8GB is too large and the camera will not recognize it.
Buy a 516MB or smaller card and try it, they are very inexpensive.
Sep 26, 2014 | Cameras
After taking only two -three photo , camera is displaying memory full, please help me with this
Hello - You're camera has a little less than 10 MB of memory with sounds exactly right (2-3 photos) with a 12 megapixel camera. Such images are large.
You need to purchase a memory card to insert into your camera to store pictures. Your camera takes several kinds of memory cards but I suggest your purchase a SD memory card of two GB in size. You can get them almost anywhere, Super Markets, Chain Drug Stores, Places like Walmart, Kmart, etc. It'll cost about $15 or so.
Happy Photo Snapping, Mikeywaf
Mar 09, 2011 | Samsung SL605 Digital Camera
My model is SD 10. Sofar I had 256 MB memory card in that camera. Recently I put 2 GB card. After somedays the camera take long time for processing. Finally in the photo taken day light, I can see only...
switch to a sd card of less than 2gb as your camera's internal image processor power is being used in running or reading the huge 2gb sd card ...and that is the reason the image izz getting white ...try for 1gb or less ..
Jan 31, 2011 | Canon PowerShot SD10 / IXUS I Digital...
I lost the usb cable for my camera and am trying to remove images from the internal sd card. how can i do this?
For your USB
> Contact kodak store at 1 888 369 6600 ask for KODAK USB Cable, Model U-8 or simply log on to www.kodak.com/go/shop.
To remove images from the internal memory of the camera
1. Turn the Mode dial to Favorites
2. Press the Menu button
3. Highlight delete or the minus icon, then press the OK button.
All pictures stored in the Favorites section of internal memory are removed.
4. Press the Menu button to exit the menu
** Kodak CD33 has 16 MB internal memory and it has a slot for MEMORY CARD 3428db8.jpginternal memory is different to memory card. You can use the camera without memory card but it's only up to 16MB while if your using s memory card you can load up to SD Memory Card 2 GB.
16MB if camera is set to 2MP it will only take about 2-5 photos while if your using a Memory card with a size of 1GB and camera is set to 2MP about 1137 photos.
* Contact Kodak support line @ 1 800 235 6325 (23KODAK)
Nov 16, 2009 | Kodak EasyShare CD33 Digital Camera
Hp m417 says error saving image when i try to save to card
did you check your SD card to see if a different reader sees if and you can read wirte to ir tey tio reformat it just for general purpose/
Jul 27, 2009 | HP Photosmart M417 Digital Camera
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
May 07, 2008 | Nikon Coolpix 4600 Digital Camera
How do i save the pictures to see them without a memory card
there is only a 16 MB internal memory built into the camera, which at 5 Million pixels will allow you 1 or 2 photos, so you will have to by an SD type card, i would suggest either a 512MB card or 1GB if you are taking pictures at the highest resolution.
Jul 14, 2007 | Polaroid PDC 5070 Digital Camera
Memory Problem
These figures are for jpegs, right? Because of the nature of compression in jpegs, your camera can't know how many pictures it will be able to hold. If you fill the memory with photos of the inside of the lens cap in a dark room at night, you will be able to take far more shots than if you shoot at an outdoor market with lots of different shapes and colors. The specs, which are used to market the camera, will have a number on the high end. The camera, which has to allow for many different possible file sizes, will have a lower number. Try using the camera until it's full. You may end up with about 125 shots. On my Canon 10D, with an empty 1GB card, says I have 162 shots left. I consistently fit over 180 on it.
Sep 12, 2005 | HP Photosmart 735 Digital Camera
HP Photosmart M417 Digital Camera Logo
335 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Marvin
Marvin
Are you a HP Camera Expert? Answer questions, earn points and help others
