Question about Pumptec Series 114V Pump w/ M36 Motor - 120 Volt - 200 PSI
Pumptec protection system keeps tripping
We have a Pumptec protection system for a Franklin submersiable pump. It will run for a few minutes, then trip and the red light comes on. There is no waters coming out of the faucets. We were without power for a few days. Once power was restored, we had no pump problems for the first two days.
I have a liberty pump pro 370 series. It will run for a while usually just a few minutes and then it will throw the breaker. What could be the problem. Thank you
Excessive current draw is the issue unless you have a breaker that is popping prematurely. When a motor has to work harder than specs, it will draw more current and a breaker will come to the rescue to protect it. The reduction of speed caused by bad motor bearings or a tight pump will cause the speed reduction and high energy usage.
Sep 03, 2017 | Pool & Spa
Pump stops after a few minutes, after popping gfi receptical
Your symptoms are in most cases indicating that water is entering electrical connections area, which should be a tight seal.
it is in most cases slight, and the sensitive GFCI is catching a potential shock hazard and trips.
For informational purposes.... It may run just fine with no GFCI protected circuit. But.... This is definitely a NO NO.
tighten or replace the electrical seal. Also, water will have to be removed and allowed to completely dry out.
Once complete, reconnect to a GFCI protected circuit, all should be fine.
May 29, 2015 | Plumbing
My power keeps tripping after I frefilled it
check heater sounds like shorted if ok then pump shorted
Jun 09, 2014 | Qca Spas Pool & Spa
Pressure drops as soon wand trigger is pressed
I would expect it especially if the tip is not on the wand or open to far. It is possible the pump is failing. How much is the pressure dropping, a few pounds I would expect but I am not familiar with that unit.
Sep 18, 2013 | Pumptec Series 205V - 150/M77 Pump - 230...
Pump cuts off then comes back on a few minutes later
More than likely, your unit is equipped with a protective device which automatically trips the unit should the internal motor temperature exceed a preset limit. Then, when the temperature decreases, also to a preset limit, the device turns the pump back on. The purpose of the device is to prevent burnout of the motor.
Have an electrician use a clamp-on ammeter to measure the current draw of the motor and compare that to the nameplate data. If the meter shows the motor near, at or over the normal Full Load Amps (FLA), investigate that condition. While there are numerous possibilities, the most likely causes are worn/defective motor or pump bearings. Try to determine if the motor is actually running hot. The nameplate lists a Temperature Rise which gives the normal motor operating temperature under expected full load conditions. Quick check:If you cannot place your hand on the motor surface for at least 10 seconds w/o undue discomfort, your motor is running hot.
If the motor is tripping but not drawing excessive current nor running hot, it's very possible that the protective device itself is defective and needs replacement.
Have the electrician check out whatever is used in the motor starter for overload device. Some overloads trip on overload and reset themselves on decrease in temperature. Others must be manually reset. If the starter overloads are not tripping but the motor is, then the problem is almost assuredly a defective trip installed in the motor itself.
Important: If you are not electrically trained yourself, it IS NOT recommended that you attempt any electrical troubleshooting. Hire a pro.
May 29, 2013 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
When turned on you can hear a buzzzing, like electrcicity going into the pmp then pump heats up and trips its saftefy switch. Motor does not turn.
I am assuming that this is not a brand new installation. If it is, go to http://www.femyers.com and download a manual for your pump.
If the pump has worked properly in the past, what seems to be happening is that the motor is locked up and the built in thermal protection is correctly protecting the motor. Or if by "safety switch" you mean the circuit breaker is tripping, then the following still applies.
The pump impeller may be jammed with debris, or the motor bearings may be worn out, causing the rotor to jam and stop rotating. Also a possibility - the seal between the pump and the electric motor has failed, allowing water into the motor and causing a short circuit which trips the breaker.
It is probably time to call the repairman, or replace the pump. Don't keep trying to turn on the motor; it will not fix itself and you may make things worse.
Remember, these pumps must be primed with water first before first use. Look in the Operating Instructions manual.
Mar 24, 2013 | Myers Pump QP10-3
I took out the ignition fuse while the car was running. i put it back in but now that i want to start it, it doesnt. i dont think its the battery because lights and radio come on and it cant be the starter...
take the positive battery cable off wait 10 minutes and reconect if it does not work check the fuel pump fuse sometimes the fuse for fuel pump will trip to protect the car
Jan 24, 2013 | 2000 Oldsmobile Silhouette
I have had a Grundfos CME Booster pump installed for some ten months or so. We have a pump room alongside the 150,000 water tank. The inlet is suspended from a float within the water tank, and is about...
Hi Ray, did you ever solve your problem, I have a setup that sounds identical to yours and have the same problem, Grundfos are not been very helpful.
Oct 31, 2011 | Plumbing
Pumptec Series 114V Pump w/ M36 Motor - 120 Volt - 200 PSI Logo
345 people viewed this question
Top Pumptec Plumbing Experts
Donni Steen
Tom Chichester
Are you a Pumptec Plumbing Expert? Answer questions, earn points and help others
