Question about Toro Lawn Mower With Toro Power Tools
My Toro GTS LV195EA 362003C is starting, but not staying running. I cleaned the carb, replaced the spark plug and filter, and have tried to adjust the govenor and bowl nut on carb, but the throttle and govenor are reving up and down on their own, so the mower revs up and slows down repeatedly, when I hold the throttle open by hand runs fine, Any ideas on what I can do?
  • 430 Answers
Engine surge is usually caused by one of two things...
1) a lean condition. Not getting enough fuel.
2) throttle plate shaft in carb is worn. usually clears up when engine is put under a load. You can live with it or replace the carb
Posted on Nov 12, 2012
  • 86 Answers
SOURCE: I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
Posted on May 16, 2009
SOURCE: My toro self propelled only runs for a few
Have you tried replacing the gas cap? I had the same problem with my mower and did everything you have done, changed gas cap no problem since
Posted on Jul 25, 2009
  • 475 Answers
SOURCE: starts runs min. or two then stops....
Go to toro.com then click customer care, then click manuals and parts. Type in model no. and download the owners manual. This should get you the spark and flywheel gap. Probably still something in the carb. Some orifices are very hard to find and to clean but they must be clean. Also check for dirt dopper nest in the muffler.
Posted on Apr 06, 2009
  • 246 Answers
SOURCE: can't start toro mower. cleaned spark plug , new
Hello:
There are 2 Possible Causes for this Problem.
1- The Carburetor Requires Soaking and Cleaning.
2- The Valve Clearances Require Setting.
You can View a Breakdown of this Unit at the Following Site Addy.
https://lookup3.toro.com/partdex/default.cfm
Hope this Helps.
Good Luck
Respectfully
John
Posted on May 10, 2009
lilmikew99
  • 122 Answers
SOURCE: Wont run smooth
have the govenor checked could be the spring is worn down
Model lv195ea
There is not a governor on newer mowers. Ease mower thru grass slowly, if starts to slow down stop, let mower speed up. In tall grass only use 1/2 of the deck width with side discharge open. Ensure spark plug is clean and gapped properly, replace once a year. Ensure air filter is clean, replace once a year. Ensure oil is full. 30w oil. Always use Stabile in gas. Use carb cleaner and clean outside of carb to ensure choke lever is free to rotate.
May 09, 2013 | Toro Garden
My lawn mower wont keep running, I have put on new spark plug, cleaned the carborator, changed the air filter. Any other ideas?
How thoroughly did you clean the carb? They need to be fully disassembled. There are some small orifices in them that need to be cleaned with either a jet cleaning tool or a piece of wire.
Aug 18, 2012 | Toro Lawn Mower With Toro Power Tools
Toro GTS 6.0 hp idles up and down
Excess air or not enough air. Replace air filter. Spray outside of carb to clean & ensure choke movement is smooth. Water in gas may cause this also. Flush out tank, refill with fresh gas, always use Stabile.
Jul 31, 2012 | Toro Power Lawn Mower
Toro GTS 6.5 HP doesn't run well in grass. Any ideas?
Has the fuel filter been replaced lately? Also you can look to see if the new spark plugs are getting fouled out still. Sometimes just replacing the spark plugs wont fix the problem.
Feb 17, 2012 | Garden
Have gts toro, engine starts then stops can not get it started.. r s
Your mower engine has to have these things WORKING to run: 1. Compression (engine in good shape) 2. Strong Spark (magneto air gap has to be correct for strong spark) 3. Clean air ( good, clean air filter w/no air leaks) 4. Clean, fresh fuel supply (gas less than 30 days olds with an inline filter installed in mower's fuel line). These things are assuming the mower hasn't struck an immovable object such as concrete, tree stump etc. recently. This will shear the flywheel key and timing may be off so far that engine won't start. So, where would you like to start my friend? Try checking these things. In the meanwhile....we can try to "coax" the engine into running. Remove the spark plug. Get an aerosol can of carb/choke cleaner spray. Spray a couple of shots into the engine. Reinstall plug. Choke the carb and attempt to start. This may or may not work, according to the conditions listed earlier. If this doesn't get it running, remove the plug and try it again.
We are trying to get it to run on its own, so it will start (or attempt to start) drawing fuel from the carburetor. Sometimes the brass bolt that holds the carburetor float bowl on gets clogged. You drain the gas, remove the bolt and clean all the small hole in the bottom and along the sides of it. This bolt is also the main jet of the carb. Cleaning this with carb cleaner can only help. If you do this, use NO metal objects to poke or scrape the bolt. The holes are metered and have to stay that way. Check for spark, check your air filter, see if the plug gets wet after you attempt to start. If it doesn't get wet or even smell like gas, then likely you have a fuel flow problem. Try ALL these things and post back; and again, if you have hit something solid recently with the mower, you will have the replace the flywheel shear key. It is a small aluminum $1.00 part so don't worry. Post back as needed. We wish to help.
Jun 19, 2011 | Toro Lawn Mower With Toro Power Tools
Toro gts 22 inch mpwer....sat for two
its got a dirty carb jet/s strip down fule lines and card give a good clean up to fule filter in tank on pickup pipe and clean carb jets anf any other fule parts
aways run it out of fule if your going to lay it up,,,
Oct 28, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will start until primed gas is consumed.
I had similar problem and cleaned the spark plug and that seemed to have worked, but I think that may be a temporary fix because the engine still seems to be running unevenly. I feel that it must be a larger problem with the carb. If anyone can help this novice to adjust the carb or clean both carb and filter, or offer other solutions I would appreciate your assistance.
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
You have a problem in the fuel system. First start by checking fuel lines,filter,vacum fuel pump.If this checks out,remove carb. and clean. Check for water and trash in bowl of carb. or tank. This sould solve your problem.
May 14, 2009 | Toro Lawn Mower With Toro Power Tools
Starts runs min. or two then stops....
Apr 05, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
323 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
