Question about Cecilware GF16 Counter Top 16lb Gas Fryer
Wont light when gas is turned on but the pilot is on
  • Carl Januska Nov 06, 2012
    well the pilot light stays on when you light it and will continue to stay on until you turn the gas off...but when i turn up the temperature control to kick the fburner on the pilot goes out. the thermocoupler only senses the flame from the pilot light telling the gas valve to keep sending gas to the pilot which from what i know means the thermo is good since the pilot stays lit
    Problem Solver:
  • 6 Answers
Your thermal couple is bad,, its not sending allowing your gas valve to open back to the valve.. for this unit you can use a ot water short found at most hardware stores for around 10.00 and its a very simple push pull click click repair
Posted on Nov 06, 2012
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Heater wont light
Is it Propane check pilot light and if youhave gas make sure that you do notlight a flflame or cigerette if gas has been on without pilot light lit make sureto tthen gas line off clear place of fumes them turn gas on and relight pilot light
Nov 14, 2014 | Heating & Cooling
Goodman gmt070-4a wont heat, like the pilot light is out or something
turn gas supply on....turn gas valve to pilot....press down and hold to allow gas to come through pilot tubing.....light the pilot right by the thermal couple, once lit hold valve down for about 60-90 secs...then release ur hand on the gas valve and turn the valve to on position............make sure the bloody tstat is turned off before doin anything other wise burners will fire up soon as you turn valve to on position
Dec 05, 2013 | Goodman GMS90703BXA Heater
Oven wont light, pilot is lite but the burners wont ignight
Bakers Pride used several different safety valves over the years. If your oven has a pilot valve that has a beige know that you hold in and turn to light the pilot, then after it lights you need to turn the beige know another half round to the "on" setting. If you push in a red button to light the pilot, it may not be getting enough heat on the thermocouple where the pilot flame should be heating it up. Be sure the main gas valve on the front of the oven is turned to the on position also. On some models the pilot will light with the main gas valve in the off position. If you look at the pilot flame while it is burning, make sure that it is hitting the pencil sized thermopile enough to make it glow red. If not bend it slightly to improve the heating.
Sep 07, 2010 | Bakers Pride Y-600 Gas Single Oven
I smell gas and my burners wont light - is there a pilot light in these ranges?
The best way to find out if if your stove has a pilot light, is to lift the top panel of the range . The pilot will usually be located between the burners. Typically you will have two pilots. One for the left and one for the right. The pilot light will ignite with a match without having to turn the burner knobs to the "on" position. Good luck
May 20, 2010 | GE Spectra JGBP35 Gas Kitchen Range
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Dryer pilot light goes on then goes right out. dryer wont heat
Hi there. Soon as the pilot switches off (will still be red hot but fade away rapidly) the gas valve should turn on. (make sure gas supply is on) If valve doesn't turn on, check sensor located very near pilot element.
When the sensor "feels" the heat of the pilot, it switches the pilot off and the gas valve on.
Thanks
Paul
Jul 13, 2009 | Dryers
Whirlpool gas dryer motor wont turn over
If the drum is not turning, then the belt may have broken and could be (because of the noise I think your describing, partially wrapped around the motor pulley.
Modern gas dryers do not have standing pilot lights. They are electronic ignition.
Chances are, you solve the belt problem, you'll solve the (I guess your having) heat problem.
Please respond with more detail of the problems you are having, and advise if the belt is broken.
Jan 18, 2009 | Whirlpool GGQ8831L Gas Dryer
The heater in my central heating is not getting turn on but the fresh air and cooling is getting turn on
Check the pilot light.Older standing pilot systems use thermocouples to verify the pilot is burning before the gas valve opens.If the pilot wont stay lit replace the thermocouple.
Newer systems light the pilot.On a call for heat the igniter lights the pilot. When the heat is verified the gas valve opens . Some systems use an circuit board with flashing led lights to help troubleshooting.
Jan 11, 2009 | Heating & Cooling
Gas oven dosnt work
the pilot light is there for 2 purposes. number 1 to light the burner and number 2 to heat up the thermocouple, thermocouple is a wire that the flame from pilot suppose to surround by fire. if the pilot is to low it will not reach the thermocouple. you can take the gas line that supplies gas to the pilot and clean it with a safety pin or a small needle. you can test the thermocouple by heating it up with a blow torch on low heat, get it red hot and then turned on the oven. if the oven works clean the pilot, if the oven do not work, replace the thermocouple if separate from safety valve. if thermocouple is part of it replace the safety valve.
Dec 14, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Cecilware GF16 Counter Top 16lb Gas Fryer Logo
73 people viewed this question
Top Cecilware Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
john h
jasbo
jasbo
Are you a Cecilware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
