Question about Polar F4 Heart Rate Monitor Watch
I can't get the settings to put the language back to English on this heart rate monitor.
  • Polar Master
  • 18,424 Answers
5 Suggested Answers
SOURCE: polar ce0537 watch screen goes
Have you had the battery tested? Try that, and we will go from there.Let me know, I can help you it just takes curtain steps to make sure we don't go through a bunch of things we don't have to in correcting this problem.
Posted on Aug 12, 2008
  • 155 Answers
SOURCE: Battery in a Polar F7 heart rate monitor
Hello
You can change the battery in your polar f7 if the battery is worn out.
1. Insert the tip of a pen knife into the lifting point and lifting the back up. The back of the watch is only pressed into place and will come off easily this way.
2. Grab the small clip that is extending across the surface of the battery with a pair of tweezers. Slide the tweezers toward the end that hooks down into the watch. Pull the hook end of the clip out of the watch and remove the clip from the battery
3. Match the old battery with a new one at any electronic store. The store will be able to read the writing imprinted on the battery to make sure that you get the correct battery type for your heart monitor.
4. Press the new battery into the watch making sure that the writing on the battery is facing up.
5. Press the holding clip back into place. Handle the clip with tweezers only, since it is very thin and can be bent or lost easily. Once it is in place, press the back of the watch on.
GOODLUCK
Posted on Jul 15, 2010
Coachphil
  • 347 Answers
SOURCE: i need polar heart rate
In my tips and tricks page are 2 usefull tips.
#1) is a quick guide to setting your F6
#2) is a link to download the manual for free.
Posted on Jan 25, 2011
SOURCE: I cannot set my Polar
Hello Paso,
Lengthy setting: It can take a while to change time or adjust weight as the number can be adjusted only upwards in one direction. If you overshoot, you have to keep pressing until the number reaches the top of the range. The number will then loop around and start from zero again.
Posted on Apr 22, 2011
HOW DO I SET TIME AND DATE ON MY POLAR AXN500?
For all those who lost their Polar Heart Rate Monitor manuals. Follow this link, fill in the details and get manual. Plenty of other Polar product info and support on this site.http://www.polar.fi/en/support/downloads?product=&category=User+manuals
Aug 26, 2012 | Polar AXN500 Heart Rate Monitor Watch HRM...
Change language back to english on polar heart rate monitor ft4
I had the same problem. So I will try to guide you by button push method (because I didn't understand anything in Dutch that said on the panel). If you look at the polar main wrist watch (easy to say) you will see 5 button. 2 of left and 3 on right. 2 left are top -backlight (21) bottom - back or exit from menu (22). The 3 right buttons are top - scroll up (31), middle - menu (32) and bottom -scroll down (33). Now we know the button number here we go.
Hold 22 for 3 sec. You will see current time showing up. Press 33 once -- Setting ---> press 32 once ---> watch time and date ---> press 33 three time ----> general setting shows up ----> press 32 once ----> button sound shows up ---> press 33 twice ---> language shows up --->press 32 once ----> language blinks ----> press 33 or 31 till you see english or your language of choice ---->press 32 once ----> language is set ---->press 22 for 3 sec and you are back to the watch menu. Hope that helps. This will guide you even if you don't understand anything from the language.
Apr 26, 2012 | Polar FT4 Watch
I just received a brand new Garmin FR 60 with HRM monitor strap and ANT USB from Amazon. I followed the directions to use the strap[wet the electrodes, strap it over my chest, with the Garmin logo facing...
navigate using mode button to enter into watch's menu tree for settings/ sport/ run/ heart rate and turn on the heart rate monitor to hopefully detect and scan for the garmin ant+ protocol heart rate strap!
Sep 22, 2011 | Watches
REQUIRE MANUAL FOR F4 C716G00457925 MY BATTERY HAS BEEN CHANGED.BY POLAR . AND HAS WIPED ALL SETTINGS. NEED HOW TO USE GUIDE
Nov 22, 2010 | Polar F4 Heart Rate Monitor Watch
How do i reset the Timex Zone Trainer Digital Heart Rate Monitor Watch T5J983 for each workout?
There are two ways to find the user manual for your Timex watch.
  1. Find your watch on the list below and click on the language link for your manual.
  2. Find the 3-digit module number located on the caseback of most Timex products and click on the corresponding language link for that number in the Module Table.
If you are still unable to locate your user manual, you may emailTimex Customer Service or call us toll-free at 1-800-448-4639.
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Nov 18, 2010 | Timex T5J983 Zone Trainer Digital Heart...
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
Polar F4 Heart Rate Monitor Watch Logo
178 people viewed this question
Top Polar Watches Experts
Jerry Greenberg
Jerry Greenberg
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
