Question about Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater...
Just not hot enough
Bosch AquaStar 1600H-NG (Natural Gas)
I can get 130 degree max out of mine. Would like about 10 degree more. Flame is all the way up and the flow is all the way down. Maybe my incoming water is just too cold? It has taken a year to get use to it, but would like hotter for dishes and washer. I have plenty of cold to mix with it. The hot water pressure has lowered significantly since it has to go thru the burn apparatus, etc, despite 3/4" pipes in the house.
Any suggestion.
Ken
  • Glenn Snow May 11, 2010
    Not sure what you mean by "the flow is all the way down"?
  • 25 Answers
I would have to say the pushrod on the watervalve is gummed up. This design of tankless heater has a mechanical watervalve. If the pushrod wasnt lubed properly at the factory it wont open the gas valve all the way.
Posted on Jan 19, 2009
    Problem Solver:
  • 14 Answers
Hi Ken Tankless Water Heaters typically heat to a 80 deg temp. rise. Per a set time it takes the water to pass through the heat exchanger. Matter of seconds So at 130 deg F. Your heater is working fine. Did you take a heat measurement or are you looking at the set points inside the cabinet? To get the 130 deg F you need to upgrade the sensor available from your Bosch Dealer. Typical output water temperature would be 110. There are scalding issues over this set point. As long as you have 3/4 id pipe in and out and have insulation on the discharge side of the heater at all exposed points of the pipe. Your system was likly installed properly. Look it is only my opinion but Bosch it the best you can get in Tankless heaters. As for the dishes. Use the sanitize setting on the dishwasher or alittle extra bleach in the dishwater. And don't forget to rince with fresh water only. For the shower or tub. Use less cold water in the mix. Tankless water heaters were designed to use less resorces aswell as energy. And I want to thank you for that.
Posted on Jan 09, 2009
How do i know if the control unit is bad on an aquastar 1600H
That voltage does not seem high enough. Supposed to be 1.6 VAC and I got 2.5 VAC. Do you have the water flow turned to the maximum? Is there something blocking water flow? The hydro voltage should be checked separetly from everything else, so if you can't get the VAC higher, my guess would be that's the problem.
Nov 19, 2014 | Bosch 1600H-NG Natural Gas AquaStar...
Roblem with the Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Aquastar gwh 1600 h igniter fails clicks does...
Problem could be air supply, gas supply, venting, part failure or combination of listed things.
Best place to start is manual.
http://www.boschhotwater.com/BoschModel1600H/FeaturesandSpecs/tabid/1024/Default.aspx
Typical 1600 manual shows troubleshoot starting page 19
http://www.boschhotwater.com/Portals/7/TechManuals/1600H_English_0606.pdf
Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
BOSCH error codes:
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 05, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater. Problems with constant hot water. The heater turns ok but (i think) when i turn on the cold side the heater stops. at...
Possible flow sensor issue. Check to see if your water pressure fluctuates a lot or is fairly steady. These units are sensitive to the pressure. take care.
Feb 19, 2011 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H won't work on windy days
The incorporation of an anti-back flow, flue pipe insert may be your solution, also the pilot flame control may need to be adjusted up a little.
Good luck
Aduz
Mar 24, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Won't get hot enough or last as long as it used to
You could try to adjust the thermostat to a higher temperature. Let me know the results.
Good luck...
Aduz
Feb 22, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch water heater won't heat as hot or as long as it used to.
Is it protected by a water softener?
Have you cleaned the inlet screen and flow valve?
Your problem is likely in one of those areas. If not them then you may have to backflush the heat exchanger (if you don't have a softener). The manual tells you how to do that.
Mike
Bosch 1600H NG
I hope this helps!
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/1600HTechSupport/Troubleshoot/tabid/1094/Default.aspx
Copy and paste to google search engine!
Jan 29, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600h NG not heating water hot enough
it sounds to me like the dip tube has failed. this is a plastic tube that is inside the water heater on the cold side. It is designed to put the incoming cold water at the bottem of the tank allowing heated water out at the top. when this tube deteriorates the cold water mixes at the top of the tank instead of the bottom. a new dip tube is about 5 bucks but must be inserted on the cold side by someone with plumbing experience.
Jan 08, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Bosch 1600H-NG Natural Gas AquaStar AquaStar Natural Gas Tankless Water Heater... Logo
173 people viewed this question
Top Bosch Water Heaters Experts
Steven Foerst
Steven Foerst
Level 1 Expert
Colin Stickland
Colin Stickland
Raygin
Raygin
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
