Question about Radio Communications
Identifying which magnum delta force version i have?
I have a magnum delta force which came in a box with all wrappings etc..and on the front of the box it has a yellow star sticker with 2002 version on.The radio has already been opened up for the 25-29mhz but out of curiosity i had a look inside to see if i could find the pcb board with the cpu reset and jumpers but i can't see any???I am now wondering if the rig is the first kind were the diode has been cut at the back of the front panel and the cpu shortened from there? I can't see anything to indicate this?Can some one shed more light on this for me?
Also is there a chance the ssb can be off frequency with these radios and need re aligning?
  • 3 Answers
The 2002 model is different. Go to http://www.cbtricks.com/radios/rflimited/delforce/df_new_freq_mod.htm
Posted on Jan 10, 2009
Magnum delta force radio wiring diagram for Mic turner 2pluse 2
Based on the Delta Force Schematic and the Turner +2 diagram 1=White 2=Red 3=Black 4=No connection (Unless you install 2 scan buttons in the Turner +2) 5= Shield Switch the internal switch in the bottom of the microphone for Electronic Switching (Not Relay). :-)
Aug 24, 2014 | Radio Communications
Is there a diagram showing how to calibrate a magnum deltas force cb radio
I found it and so can you.Do a serch for magnum delta force radio. or go to www.bastardfairies.com
May 25, 2014 | Magnum DeltaForce CB Radio
Magnum parts
email parts list needed to: saml@rflimited.com
He's a great guy and a pleasure to work with.
Mar 20, 2010 | Magnum DeltaForce CB Radio
My magnum delta force blows the higest amp fuse!!! (shorting out)
yes it sounds as if the diode has gone short curcuit. this is at the back or near the in put socket. the diode is black with a silver end. replace with same size this should sort it out.
May 14, 2009 | Magnum DeltaForce CB Radio
Service manual
You may click this link for the service manual:
http://www.rigpix.com/cbfreeband/magnum_deltaforce_manual.pdf
Have a great day!
Apr 29, 2009 | Magnum DeltaForce CB Radio
Magnum Delta Force Radio: The schematic does not match what is on my work bench! Schematic shows 10 tact switches,there are eight on the unit. If I trace back the leads from the rotary frequency changer...
usualy that is a sign that someone was trying to get more channels then it already has which is imposible to get any mor ok check this web site cbtricks.com go to the radio information section go to m look for the magnum radio section look for the deta force you should find all you need there. good luck with your projec and god bless you.
james morgan
morgans electronics
Feb 28, 2009 | Magnum DeltaForce CB Radio
D-104 mike wiring
Go to cbtricks.com look up radio information go to magnum use the wiring set up for the 357.
Jan 19, 2009 | Magnum DeltaForce CB Radio
Magnum delta force
pin1 = mic audio,pin 2=receive, pin3= push to talk or transmit, pin5= shield.
cobra usually is white= mic audio, red= ptt, black= receive or speaker complete
Dec 21, 2008 | Radio Communications
Delta force magnum radio
Herman, one thing that should help is turn on the NB and also TONE .
Feb 08, 2008 | Magnum DeltaForce CB Radio
Radio Communications Logo
91 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
