Question about Whirlpool Duet GHW9150P Front Load Washer
F 06 error flashing - Whirlpool Duet GHW9150P Front Load Washer
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
The F/06 is:
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
The tech. should check these:
Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
Check the Drive Motor
Check the MCU
Check the Wire Harness
If you still get the error, replace the CCU.
Here is the part to order.
Posted on Nov 06, 2012
Whirlpoool front end loader washing machine showing an f 06 error
The F/06 is:
Check the MCU
Nov 04, 2012 | Whirlpool Washing Machines
"service" flashing also what seems to be an error
Service flashing- 1. Ice maker not working 2, Rise in temperature 3. Condenser needs cleaning
To Clean Condenser 1. Remove Grille 2. Brush with a soft brush 3. Vacuum being careful not to bend fins.
Jul 07, 2011 | Sub-Zero 650/SRH Stainless Steel
Need bootloader 06.A3, Err:a5,69,35,00,2E
This is an internal software error. If your phone is less than 1 year old you can get it replaced at no charge from your provider. If it is over 1 year old you would need to use your insurance if you have that option. Point is, t he phone will need to be replaced.
Apr 20, 2009 | Motorola Mobility ROKR E8 Cellular Phone
WASHER STOPS WORKING AND FLASHES 06 F
F06
Drive motor tachometer error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Replace failed component.
Jan 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F and then 06 error/ Kenmore elite HE 3T series 4
well i found the answer on browsing through fixya. the following would assist you with the needy.Hoe it is helpful.Pay back with your comments if the problem is solved.
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Laptop will not fully start
This could be a device failure. However, try flashing the bios. Do this by going to Acer's support site and creating a bootable disc with the bios or updated bios, if there is any, on it. Then run this in your machine. You will have to use a different computer to do this, apparently. If this doesn't fix the problem, then you will need to take it in and have a tech run down the device that failed.
Jun 26, 2008 | Acer Aspire 5100 Notebook
42PF7320A/37
Replace X-tal (Viper) on SSB (item 1H00, order code: 2422 543 01397).
REMARKS:
- Error 5: Viper does not boot.
- Only a "reboot" is visible in the Debug menu.
- Error will appear after heating up of the xtal.
HISTORY:
23-03-'06: Chassis added. Text updated.
Jun 13, 2008 | Philips 42PF9630A 42 in. Plasma Television
Acer Aspire 3100 Boot errors and intermittent lock
Try flashing the BIOS to the latest version.
http://www.acerpanam.com/flex/acerdrivers/bin/drivers.html?CFID=1078534&CFTOKEN=55079713
Also, take a can of compressed air and blow out the dust and debris from the CPU air intake and exhaust vents (Go back and forth several time to try and dislodge compacted dust in the heatsink vents)
If the BIOS flash doesn't resolve then you most likely have a NIC failure. Since the NIC is integrated you can either replace the motherboard or get a PCMCIA or USB NIC to use and disable the integrated one in the BIOS (If possible)
Jun 05, 2008 | Acer Aspire 3680 Laptop
Whirlpool Duet GHW9150P Front Load Washer Logo
54 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
