Question about DeLonghi ESAM6700
Can you de-scale without the water spout as ive lost mine ?
  • 1,238 Answers
Yes.
Posted on Nov 06, 2012
Machine seems to have lost its pumping power, water/coffee still comes out but only in a trickle. Got the machine for two and a half years.
Do you de-scale your machine regularly? Is your water hard, ours is here and if we don't clean it regularly(with vinegar or a de-scaling agent) it has the problem you are describing. Let me know?
Dec 09, 2013 | Coffee Makers & Espresso Machines
My Phillips Senseo only produces a small amount of water why?.
Hi Have you tried to clean and de-scale it, limescale can really play havoc with these sort of devices. If you still have the instruction book give it a read and follow instructions for de-scaleing. Also there is a cleaning cycle on some of the models which just flushes the senseo through to clear it out again it is in the book but if I remember rightly you fill up the resoviour then turn it on and put a large bowl under the spout and press both the one and two cup buttons at once. But I would do a descale phillips say it should be done about every 3 months this should also clean out any other muck that has built up, they also say to clean out the pod holder including the little hole. The Phillips website has help if you have lost the booklet.
May 22, 2012 | Philips Senseo HD-7810 Coffee Maker
It says to de scale, ive been running vinegar and water through it but it's having a hard time coming out and still says de scale.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Jul 21, 2011 | Keurig B60 Coffee Maker
I lost my manual. How do I de-scale? Does this not allow you to brew a cup until it has been de-scaled?
From http://www.keurig.com/customer-service/brewer-registration-and-support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions.ashx
To begin, you will need the following:
  • 48 ounces of undiluted white vinegar
  • Large ceramic mug (do not use a paper cup)
  • Access to an empty sink
PREPARE Step 1: Empty the water in the Water Reservoir. Step 2: Disable "Auto Off" features.
FILL AND CLEAN Step 1: Pour approximately 48 ounces of the vinegar into the Water Reservoir. Step 2: Place a large mug on the Drip Tray Plate and run a brew cycle. DO NOT USE A K-CUP, just press the BREW Button. Pour the contents of the large mug into the sink. Step 3: Repeat the brew process without a K-Cup until "ADD WATER" is indicated. Step 4: Now let the Brewer stand for at least 4 hours while still on. Step 5: Discard any residual vinegar and rinse the Water Reservoir thoroughly.
RINSE Step 1: Ensure the Water Reservoir is filled with fresh water. Step 2: Place a large mug on the Drip Tray Plate and water brew cycle. Pour the contents of the large mug into the sink. Step 3: Repeat brew process until "ADD WATER" is indicated. Step 4: You may need to perform additional water brew cycles if you notice any residual taste. NOTE: If "DE-SCALE" is still displayed after completing the procedure, repeat the de-scaling procedure above.
Mar 17, 2011 | Keurig Special Edition B60 Coffee Maker
Once k cup is inserted and process begins; it drips all over without making the coffe. Need help
sdfsdf
Sorry to read about your issue.
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 23, 2010 | Keurig B60 Coffee Maker
Water runs thru maker without k-cup inserted but once I put a k-cup into maker the water drips out only and does not fill up the cup but when i remove the k-cup the water continues to run thru it.
Dec 20, 2010 | Keurig B70 Coffee Maker
B40 descale light is on but won't **** up water with descaling solution- tried many times without success
you said descale solution, do it this way, if you have not
Dec 19, 2010 | Keurig Elite B40 Coffee Maker
I press brew. It sounds unusually loud. No water comes out the spout. water drools out the bottom.
we9e9w999e
Dec 19, 2010 | Keurig B50 Coffee Maker
Liquid leak while Vienna runs...but where from?
You may have a cracked coil inside the boiler and cracked nut of the coil going up to the wiring lug. Check it out, it will be a hair thin crack, almost invisible.
Feb 11, 2009 | Saeco Vienna De Luxe Espresso Machine
Water no longer comes out of the fill spouts during a rinse.
try and do a heavy duty de scale of the machine , put some descale directly into the tank, heat up ( de scale works better at high temp) select rinse, clean or flush programme. the vast majorty of probs. are due to limescale in the narrow pipe work.
Feb 08, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
DeLonghi ESAM6700 Logo
56 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
