Question about Refrigerators
CONNECT ICE MAKER - Refrigerators
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 06, 2012
Looking for a manual to install a Summit BIM24SS ice maker
Not all the necessary hardware is provided for installation so it is necessary to hire a professional licensed plumber to complete the installation.
• Connect tubing (supplied with unit) to the nearest cold water source. Connect sufficient tubing to the unit to allow the appliance to be moved freely for cleaning and service. Also make sure that the tubing is not pinched or damaged during transportation.
• Position unit to allow free airflow through the front grill (see sketch 1). Wipe out inside of unit and ice bin
with a damp cloth.
Before Using Your Ice Maker
• Remove the exterior and interior packing.
• Check to be sure you have all of the following parts:
1 removable ice bin
1 plastic scoop
25 ft. hose
1 instruction manual
• Before connecting the ice maker to the power source, let it stand upright for approximately 2 hours. This will reduce the possibility of a malfunction in the cooling system from handling during transportation.
• Clean the interior surface with lukewarm water using a soft cloth.
Installation of Your Ice Maker
• This appliance is designed to be either free-standing or built-in (fully recessed). If free standing, the unit should have at least 4" of clearance at both sides, at the top and at the back to allow for adequate ventilation. If it is built-in, leave at least 3/16" at both sides, 1/16" at the top and 2" at the rear. Be sure that airflow under the appliance is not blocked.
• Place your ice maker on a floor that is strong enough to support the ice maker when it is fully loaded. (Remember that the unit will be significantly heavier once it is fully loaded.) To level your ice maker, adjust the leg at the front of the unit.
• Locate the ice maker away from direct sunlight and sources of heat (stove, heater, radiator, etc.). Direct sunlight may affect the acrylic coating and heat sources may increase electrical consumption. Extremely cold ambient temperatures may also cause the ice maker not to perform properly.
• Avoid locating the ice maker in moist areas. Too much moisture in the air will cause frost to form quickly on the evaporator requiring more frequent defrosting of the ice maker.
• Plug the ice maker into an exclusive, properly-installed grounded wall outlet. Do not under any circumstances cut or remove the third (ground) prong from the power cord. Any questions concerning power and or grounding should be directed toward a certified electrician or an authorized SUMMIT products service center.
Jan 20, 2016 | Kitchen Appliances - Others
Tip
How to install/replace Icemaker in top bottom fridge
Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
on Aug 01, 2011 | Refrigerators
The ice box on the ice dispenser appears to be clogged so ice cannot be dispensed on either setting (chunk or crushed). How does one remove the ice box front to look inside?
Hello there,
For you to be able to remove the ice maker from the refrigerator, you will have to get a screwdriver and a work glove, then you follow the steps below:
  1. Pull the LG refrigerator away from the wall and unplug the electrical cord.
  2. Shut off the water supply valve to the ice maker by twisting the knob clockwise. The valve is built into the metal or plastic tube that feeds water to the ice maker at the back of the appliance.
  3. Open the freezer door and remove the ice bucket below the ice maker. Set the bucket in the sink for the ice to melt.
  4. Lift the white plastic housing off the ice maker and set aside.
  5. Remove the screws that connect the ice maker assembly to the inside back of the freezer, using a screwdriver and work gloves to protect your hands.
  6. Push up on the ice maker from below to release the mechanism.
  7. Disconnect the wire plug that connects the ice maker to the back of the freezer and remove the entire assembly.
  8. When you are through with what ever you want to do with the ice maker.
  9. Reconnect the LG refrigerator power cord and slide the appliance back to its original position.
Hope this helped. All the best Elect_Comp
Sep 23, 2011 | LG Refrigerators
My Frigidaire model SRF24ZRH ice maker needs to be replaced but power supply runs threw the back of the refrigerator, how do it remove and replace the ice maker?
There is a quci connect on the ice maker where the wires run along side of ice maker. Without the complete model number of fridge I can not see the wire harness. Usually it quick connects into another quick connect sometimes inside the frezzer wall that can be removed. Otherwise ir quick connects into the side of icemaker.
If you have any further questions or need further assistance please comment me back.
Jul 27, 2011 | Kitchen Ranges
Ice maker not making ice
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 30, 2010 | Refrigerators
Connect ice maker
Almost all ice makers have a plug on them and the fridge has a corresponding plug. If you cannot find the plug in the Fridge - look in the area of the ice maker for a plastic plug in the wall of the fridge. If you've added this to the fridge after the fact then you may need to fish out the plug from the wall of the fridge.
Aug 06, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
KitchenAid Superba refrigerator, no ice.
this fridge uses a infrared controlled ice maker on the freezer top right side you will find a white lid whit three screws the ice maker control board replace it and if don?t solve your problem emplace the ice maker to.
Jun 07, 2009 | KitchenAid KSRK25IL Side by Side...
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
GE profile refrg. with ice maker
Too much ice, maybe the ice maker didn't connect right, the gears moves but the spring inside the ice maker won't move.
Jul 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Refrigerators Logo
26 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
