Question about Avaya IP Office 5410 Terminal - New
Avaya phone 5410 how can I manually change time
  • dino1274 Nov 07, 2012
    With the time change (DST) recently, my 5410 model display still reads the old time. How do I change the display to read the new time? Is there a way to do this manually or reboot?
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Posted on Dec 31, 2012
Change my answering machine greeting on avaya 5400
Do you have voicemail pro or embedded voicemail? Do you have the right document?
Aug 22, 2012 | Avaya 5400 Series 5410 Phone
Hi I need to re set the number of rings on my Avaya 5410 anwerphone before it answers because it takes ages. How do I do it?
You need to do this in the Manager application. Under the telephony tab of the user, you can change the "No Answer" time.
Jun 18, 2010 | Avaya 5400 Series 5410 Phone
Can't change voicemail on my 5410 Avaya digital phone
The auto attendant greeting, or the general mailbox greeting?
May 15, 2010 | Avaya 5400 Series 5410 Phone
How do I set up voicemail on the 5410
Press the voicemail button and follow the prompts. You will need to know what the password is. When prompted for the password, try just pressing #
Mar 10, 2010 | Avaya 5400 Series 5410 Phone
Switch board phone needed to transfer lines, etc.?
You should not need the main phone to access the system and make changes as long as the phone you are trying to make changes from has a LCD screen.
May 29, 2009 | Avaya 5400 Series 5410 Phone
How do i change the time on the avaya 5410 handset There is a feature code i have used before but cant remember where i wrote it down....... doh ! pls help!!!!!
  1. Press feature +(00)+(left intercom)+(left intercom)+#103 at extension 10 or 11.
  2. Enter a new time in 24-hour notation. For example, to set the time to 2:15 p.m., press 1415.
    A display similar to the following appears:
    System Time
    Data 1415
    This time appears on system display phones as 2:15 p.
  3. Select another procedure, or exit programming mode.
Apr 01, 2009 | Avaya 5400 Series 5410 Phone
Trying to change number of rings before voicemail
By default individual coverage is set to 45 seconds. Ask your phone vendor to reduce it.
Feb 20, 2009 | Avaya 5400 Series 5410 Phone
Cant get Voice mails
Try to delete all the messages then try adding a voice mail dialing from another extension then you will recieve the messages.
Dec 02, 2008 | Avaya 5400 Series 5410 Phone
Avaya IP Office 5410 Terminal - New Logo
786 people viewed this question
Top Avaya Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you an Avaya Radio Communication Expert? Answer questions, earn points and help others
