Question about Measuring Tools & Sensors
Digitech 4-LD1197-6 manual - Measuring Tools & Sensors
How can I get instruction manual for digitech xc0430 weather guage ?
Hello!
Please kindly check - here is the list of Digitech devices. Hope you can get here the one you need or a similar one.
https://manualsbrain.com/en/brands/digitech/popular_categories
Oct 20, 2017 | DIGITECH Music
Looking for a manual for a Digitech QM-1589 Sound Level Meter...
hi
I have mini sound level meter, I need to calibrate it. I lost my manual. it is Digitech QM - 1589. Pls help me to do that.
Sumudu
Sep 12, 2013 | Audio Players & Recorders
Vocalist Live 4
U.S and Canada: 20 VAC, 60 Hz Adapter: PS093B-20
Japan: 00 VAC, 50/60 Hz Adapter: PS093B-00
Europe: 230 VAC, 50 Hz Adapter: PS093B-230
UK: 240 VAC, 50 Hz Adapter: PS093B-240
Power adapter requirement straight from the user manual. I am sure you are aware that a simple plug adapter in a tourist shop does nothing to convert 120v US to 240v AUS. Note you unit does not like temperatures above 40C. And you can get that in Australia.
Bear in mind the timezone difference if you try Digitech support in the US.
DIGITECH VOCALIST LIVE 4 Owner Manual Page 36
Dec 30, 2017 | Digi-Tech Digitech Vocalist Live 4...
Hiwhat is the best way to connect my DigiTech RP10 to my Marshall MA100H Guitar Amplifier
Read your manuals for both pieces of gear carefully first. You only have one amp so you won't be able to take advantage of all the FX on the Digitech as a lot of them are designed for stereo. The Digitech manual shows guitar into the Digitech and output from the Digitech into input of any guitar amp. Since you have a Marshall and can already get some great sounds by running your guitar straight into the Marshalls input, you would probably be better off using your Digitech in the FX loop. Run a guitar cord out of the send on the loop into the input of the Digitech and a guitar cord out of the left / mono output jack on the Digitech into the effects return jack on the Marshall. Start out with the effects level on the Marshall all the way down. Do the same with the Digitech with both the input and output levels. (Read the manual carefully) I think the choice of the Digitech isn't that great because it is already trying to reproduce a lot of what you can already get with just your Marshall but with a little experimentation and some careful adjustments you should be able to add to the sound of the Marshall. Hope this helps.
Oct 23, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Hi! Im looking for the service manual or schematic for the Digitech Valve Fx guitar eff.proc. The unit can turn on, and in bypass mode has a clear sound, but in normal operation has terrybly noisy, It...
hello,
can be too late but one never knows:
http://mesnotices.fr/314159.php?k=b7e42b97c5e87d24451de2516f66eef9&ID=18334&q=DIGITECH%20VALVEFX
you must simply answer the questions to be able to download.
Philippe to France
Jun 10, 2009 | Digi-Tech Digitech Vocalist Live 4...
Digitech RP250
you can download an instruction manual for free from here... I am sure that it will help you. http://www.devicemanuals.com/guide/Musical%20Instruments/DigiTech/DigiTech-RP250-English-User-Guide-TmpVeE16WT.html
or ask your question of this forum... i am sure they can help :)
http://www.digitech.com/soundcomm/new_account.asp
Dec 26, 2007 | Audio Players & Recorders
Measuring Tools & Sensors Logo
881 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
