Question about Whirlpool Duet GHW9150P Front Load Washer
I need to find a washing machine part
I want to combined two washing machines and I need to combine two hoses for the return to only one
  • 640 Answers
Ok get a sphion break it cost a couple of buck..it looks like this F...now all you have to do is pull the little vavle out a a little piece of hose and you have it...
Posted on Jan 05, 2009
LG WM1832CW, what is the key code combination to cause it to spin only?
The machine has a "Rinse & Spin" button in the "Options" side of the control panel. Press this button to accomplish the spin "cycle" that you require.
Oct 12, 2014 | LG WM-1832C Front Load Washer
Ariston h20 errors
The washing machine fails to load water (The wording H20 is
displayed).
• The water inlet hose is not connected to the tap.
• The hose is bent.
• The water tap is not turned on.
• There is a water shortage.
• The water pressure is insufficient.
• The START/RESET button has not been pressed.
Dado
Jan 14, 2014 | Ariston Technologies AWD 129 NA Washer/...
Kelvinator Washing Machine only works when you fill it with buckets of water
Problem sounda like its within your valve . take off hoses in the back of washer and check for clog to the valve . if nothing found change out the valve. strange for both to fail but it can happen .
Feb 17, 2013 | Washing Machines
Kenmore washing machine will not drain water /spin cycle
There is likely an object (like a sock) lodged in the drain hose that runs from the tub to drain pump. It could be in the hose in which case a squeeze will verify, or jambed against the drain pump impellers. It could even be between the inner basket and outer tub covering the drain hole. Regardless it is usually easily retrievable with a little ingenuity as well as a little to big mess of water. So prepare for the water if you losen a hose. Unplug the machine before you start because electricity and water are never a good combination. A wet dry vac works good to remove standing water in the tub and you can even hold the nozzle over a loosened hose to remove water from it as it pours out. Let me know if you run into difficulty.
Jan 11, 2013 | Kenmore Washing Machines
Clothes are dump after over an hour of drying
maybe too many cloths at one time or maybe the vent is clogged that lets the air outside or you need to clean the lint trap.
Sep 07, 2012 | AEG Lavamat 12710 Front Load Washer /...
I think because of zinc& salty water,water supply hose(cold) is not working water flows continuously it won't stop. because when water stop automatically it won't.What to do how to repair?
most probably you have either a bad water pressure/level switch, a pressure hose that has detached, a clogged pressure hose or a combination of any or all of the above.  the machine is not being told that the machine is full...
Jul 28, 2010 | Washing Machines
Frigidaire gallery washing machine and dryer combination flsec72gcs6 will not stop draining need to take out clothes in order to fill happens mostly on rinse cycle.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Make sure the drain hose is not pushed too far down the drain pipe. It could cause a siphon effect and drain the tub.
Make sure the drain hose is not tight in the drain pipe. It should fit loose so as not to trap the air which can also cause a siphon effect.
Feb 22, 2010 | Washing Machines
Please help me i lost my washing macine booklet and am unable to get a proper combination i have indesit washing machine wdl 106 i need a perfect combination about temp and all three knobs. cuz right now...
check the internet for a manual for your washer most of the time you can down load them. Put in the name and model number and state you are looking for manual.
Oct 31, 2009 | Indesit WA 125 Front Load Washer
Washer has no cold water on any combination temp. setting or rinse cycle. cold water valve is on at wall , no kinks in hose.
PROBABLY THE COLD VALVE HAS FAILED- BUT CHECK FOR A DIRTY HOSE FILTER - CAN BE EITHER END OR WHERE THE HOSE SCREWS ONTO THE MACHINE.
Jul 06, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
