Question about Frigidaire GLEQ2152ES Electric Dryer
Remove drum LEQ2152ES0 dryer - Frigidaire GLEQ2152ES Electric Dryer
2 Suggested Answers
  • 7 Answers
SOURCE: model LEQ2152ES0
check the drive belt is on the pulleys
Posted on Jul 20, 2008
Frigidaire front loading dryer model LEQ2152ES0 I am looking to purchase a used one, the owner has all paperwork and such, says the drum does not turn, sounds like it trys to but does not. he thinks i
Hey friend, thanks for the post!
If the drum is not turning on a Frigidaire dryer it could be a potential problem with the belt, motor, or control panel. The best thing to have done would be to have a professional come out and properly diagnose the appliance. Hopefully this is helpful. -Matt
Sep 23, 2014 | Dryers
What do i do when my frigidaire dryer shows error code 68
Good Morning Friend,
I understand that your Frigidaire dryer, model# LEQ2152ES0, is showing a 68 error code. The E68 error code means that there is a possible button that is stuck. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Once power is restored start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Electrolux Dryers
I have a frigidaire LEQ2152ES0 Front Loading Dryer. The machine has started to squeek rather loudly. I've noticed a
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Thank You for using fixya
Mar 14, 2012 | Frigidaire GLTF1670A Front Load Washer
Need to remove lower front panel off a LEQ2152es0 model, can you pry it off with a screw dryer, how is it attached. I remember the service tech showing me, but now I can't remember and I need to check for...
there are 2 screws located near the floor,remove these,then it comes outward toward you and unclips,then remove the door hinge screws next with the door open and remove the door,then the upper rest of the front cover can be removed too
Aug 01, 2010 | Frigidaire GLEQ2152ES Electric Dryer
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer is making a banging sound even when drum is empty
The dryer drum support is worn and must be replaced.Unplug the dryer. Open the top lid and fold it back. Remove the front panel,dryer belt and drum. To remove the drum pull UP on the rear of the drum. There is a ball and cup support on the rear of the drum and rear cabinet. They are worn down.
Nov 03, 2009 | Frigidaire Electric Dryer
Error code PF
PF means power failure. Check your electrical connections and voltage for proper voltage
Jul 09, 2009 | Frigidaire AEQ7000ES Dryer
How to to put the belt back on. Frigidaire LEQ2152ES0
I will be more then happy to help you but I need the model n serial # to better assist you.
thank you for trust fixya I will be waiting for your e-mail
May 13, 2009 | Frigidaire Dryers
Model LEQ2152ES0
Jul 08, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire GLEQ2152ES Electric Dryer Logo
24 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
