Question about 3Com NBX® V3000 (3C10600BUS)
All ports busy - 3Com NBX® V3000 (3C10600BUS)
  • 58 Answers
When there isn't an available line, you will get an "all ports busy" on the display of the phone. This can mean a few things. It can mean that your line cards (analog or digital) are not being seen by the NCP (Network Call Processor), all lines are busy or your T1/PRI circuit is down. If the cards are "Unknown" you can reboot the system (through the browser) and try again after about 5 minutes. The line cards are hot swappable and can be loosened, pulled out an inch or so and then pushed back in. Do not try this with the Call Processor though! It is NOT hot swappable!
Posted on Nov 12, 2013
Can i use webcam on e3200 cisco usb port ?
Hello i would say no.
Becauce need of driver.
But you can buy a IP camera ( i guess you need it for some kind of survailance ) it have its own ip address.
And you can access it from any computer.
Here is some info about that:
http://www.dlink.com/us/en/business-solutions/ip-surveillance/business-ip-cameras
Good luck
Oct 29, 2012 | Linksys by Cisco Linksys E3200 Dual-Band N...
Tip
EZ steps to install HP printer in Windows 7 without Installation software
  1. Make sure that the USB cable is not connected to the product. If the USB cable is connected to the product, disconnect it.
  2. From the Windows taskbar, click the Windows icon, and then click Devices and Printers. The Devices and Printers window opens.
  3. Click Add a printer. The Add Printer window opens.
  4. Click Add a local printer.
  5. Click Use an existing port.
  6. Click the Use an existing port drop-down list, select LPT1: (Printer Port), and then click Next.
  7. Under Manufacturer in the Install the printer driver window, click HP.
  8. Under Printers, select approriate drive from below list provided and then click Next.
  9. In the message window, click Finished.
  10. Connect the USB cable to the product, and connect the USB cable to the computer. A Device driver software was not successfully installed window opens.
  11. Click Close to close the window.
  12. In the Devices and Printers window, right-click the name of the product and then click Printer Properties. The Printer Properties window opens.
  13. Click the Ports tab.
  14. Click the drop down menu, and then change the port from LPT1 to USB or DOT4.
  15. Click OK.
  16. In the Properties dialog box, click the General tab.
  17. Click Print Test Page.
Determine the appropriate compatible driver
Deskjet 3320, 3325, 3420 and 3520 -------------Deskjet 3600 *
Photosmart 7600 series------------------------------ Deskjet 5600
Deskjet 5850 ---------------------------------------------Deskjet 5600
Photosmart 130, 145, 230 and 245 ---------------Photosmart 330 *
Photosmart 7350 and 7550 --------------------------Deskjet 5550
Deskjet 6122 and 6127 --------------------------------Deskjet 990c *
Deskjet 3820 -----------------------------------------------Deskjet 970cse *
Deskjet 656 ------------------------------------------------Deskjet 660c *
Business Inkjet 1100d ---------------------------------Business Inkjet 1000
Business Inkjet 1100dtn ------------------------------Business Inkjet 1000
Deskjet 9300 ----------------------------------------------Deskjet 1220c *
Deskjet 9650, 9670, 9680, 9680gp---------------- Deskjet 9800
* Available only through Windows Update.
(Happy Printing)
Regards
Rizwan
on Jan 29, 2010 | Office Equipment & Supplies
I get a busy signal when I press 777 on intercom, why is that?
Either all the ports of the voice mail system are busy, or you don't have any ports programmed in the VM group. I'm betting on the latter.
Carl
Apr 19, 2011 | Avaya Corded Phone avaparp18d
Can't page to central speaker system. gives a busy signal.Merlin Plus system with Page Pac 20 paging system. All other features work. I think it is the Page Pac but don't know how to troubleshoot.
If you are getting busy signal, something is shorted out.
Disconnect the wiring from the phone systems page port, and try to page. did the busy go away?
if not the port is bad in the phone system. If it did, the page pac is bad...
Apr 30, 2010 | AT&T Merlin BIS 10 Phone
I want to know how the parallell port is configureg. baudrate. bitrate etc
The parallel port does not use bit or baud rate. These terms apply to not serial ports.
A complete description of the Parallel port operation is not possible in this forum, so I'll just highlight the differences.
First, serial transmits one bit at a time. Parallel means that all 8 bits in a byte are passed at one time. A parallel port can pass data at about 10K bytes (Standard) to greater than 1M characters per second depending on the configuration of the Port.
There are two types of parallel port connections. The Centronics or Standard Parallel Port (This is signal line activated and then is run by timing.)
For example, when the PC has data to send to the printer, it first checks that the parallel port is not busy, by testing the signal on the nBUSY pin.
If the printer is not busy, then the PC lowers the signal on the nSTROBE signal line. The printer sees the signal drop and waits about 500ns and then sets nBUSY to low and transfers the data to the printer. 500ns later, the printer will raise the ACK line and lower the nBusy line.
The high speed version of the port works off of the edges of the signals and does not use the timing delays.
For example, the PC will check the nBUSY line and if it is not busy, then it will lower the nSTROBE line. When the printer sees the nSTROBE line go low, it latches the data off of the parallel port and then raises ACK and lowers nBUSY.
So the difference between the High Speed IEEE1284 and the Standard or Centronics is the timing. Standard uses timing delays and IEEE1284 does not. Also, the IEE1284 protocol allows for communication back from the printer via the parallel data pins. You cannot do this with the Centronics port.
There are several forms of IEE1284 so yo8u have to know which forms are used by your PC. For example, I believe that HP PCs use EPP form and Lexmark uses another form of IEE1284.
Don
Dec 02, 2009 | Brother HL-2040 Laser Printer
Dell 2330dn - my printer won't print my work. It keep reading Parallel busy. What does this mean?
How is this printer connected to your computer? Is it connected by a parallel/centronics cable, or USB, or perhaps not connected physically at all, but via network (it's a network-capable printer)?
Also, you don't specify the operating system.
I would guess, that it was installed on the LPT (parallel) port, instead of a network port, and because in reality nothing is connected to the parallel port it is producing an error (explaining why it's called busy would be long and boring).
Anyway, please either check the setting of the port to which this printer is printing (find that in Printer Properties), or be more specific as to what your current situation is.
Dec 01, 2009 | Office Equipment & Supplies
"flash busy" message when trying to retrieve voicemail messages
It is telling you that the voice mail ports are busy and can not take another call in to the voice mail system. If the port the does not clear up after a min or two then reset the voice mail system . Unplug the power cord from the wall and let it set for a min , then plug it back in and wait about 5 min for the system to come back up , that should free up the ports .
Apr 16, 2009 | Lands Phones
Electra elite IPK Problem
There are several things that could be causing this and it depends on how many conversations (ports) your voicemail can handle.
1. The voicemail ports could all be busy. Dial vociemail when you know nobody is using it. If you can get in then there is nothing wrong except that your voicemail system is busy and you may need more ports.
2. If you are pressing a button on your phone, then the button may be programmed incorrectly. Using the dial pad, manually dial the vociemail and see if you can get in.
3. As a last resort, you can turn the phone system off for 10 seconds and then turn it back on. Do this with caution however and make sure nobody is using the phones. You also run the risk of defaulting the programming on your phone system. If the voicemail ports have locked up, this will clear the locked ports. If this happens again (busy) hopefully it is under warranty as either the voicemail is going bad or is misprogrammed.
Dec 08, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
Printer port
usually port 1 but you can select which one if that's busy.
Sep 15, 2008 | Canon ImageClass D880 Copier
3Com NBX® V3000 (3C10600BUS) Logo
363 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
