Question about Cycling
I need to know how to change a back inner tube on a 16" huffy bike no gears
  • 843 Answers
Sue, there are lots of how-to videos out there about this. Just google "How to change bike tube" or tire, or flat. You have to remove the wheel, which is easiest with TWO wrenches - they can be the adjustable "Crescent" wrenches, but don't use pliers. You also have to remove the small screw that holds the fat little L-shaped lever to bike. Use a rag to remove the chain from the cog on the wheel. Then use the little "Tire irons" to remove the tire from the rim and get the old tube out - these come three to a set, the plastic ones are best, and you can get them at K-mart. Also, use some baby powder (talc is better than cornstarch) to make the new tube easier to position correctly in the tire - sprinkle the powder inside the tire when you have if off and put the tube in the tire before you put the tire back on the rim. It helps if you put a little air in the tube to make it a nice sausage first. And make sure you get the valve stem straight and pulled all of the way through the hole in the rim. Be very careful that you don't pinch the tube against the rim when you put the tire back on. And the hardest part might be getting a pump to hold tight onto the valve stem - using compressed air (like at a gas station) is by far the easiest method. Good luck.
Posted on Nov 06, 2012
  • 1514 Answers
SOURCE: huffy green machine front tire is flat
There are nuts at each side of the axel, on which the wheel turns. These may have to loosened by a spanner or may have quick release levers. If there are levers pull them outwards from the wheel and you can then turn them to release the wheel. Let all the air out of the wheel. Then insert 2 levers under the edge of the tyre, about 6 inches apart and pull the tyre out over the rim of the wheel. Put in your finger and pull the rest of the tyre over the rim. Then lever the other side of the tyre over the same side of the wheel and remove the tube. Replace the tube ensuring that the valve for pumping is in place first. Replace the tyre as far as possible by hand and use the levers for the final few inches taking care not to trap the tube between the lever and the rim of the wheel as this could cut the tube. Place the wheel back on the bike and tighten the nuts.
Posted on Jul 17, 2010
dunnbiker
  • 8546 Answers
SOURCE: Slipping gears on bicycle
Make sure the rear wheel axle is snugged up against he dropouts in the frame and that the wheel is centered in the brakes. Also, check the seating of the shifter cable at each end, but most likely at the rear shifter, to make sure the jacket is inside the ferrule.
Of course, it is impossible to get a sense for how well maintained the bike is. Perhaps the shifting problem's appearance is not related to the wheel removal and may be something else like bad cables or cable housing. The cable should slide easily in the housing. Shift the bike to its lowest (easiest) gears in front and in back. Then, without moving the crank, manually tug on the rear shifter cable from the rear and push it in. Resistance is bad. Sometimes a bit of lube inside the housing will buy you some time. Use something thin and squirt a little into the end then cycle the cable in and out to distribute it.
If you don't have a bike repair stand, find a small tree with a stout, narrow, low horizontal branch about shoulder height and hook the front of your seat on it so you can spin the cranks and test the shifting. If it's hard to downshift the rear (pulling cable into the housing) it will likely not freely shift upward because the only froce pulling the cable out is the little spring in the derailleur.
Shift to the highest (smallest) cog and sight along the axis of the it and the two rear derailleur pullies. They should all be in the same exact vertical alignment. If they're parallel but not aligned you can adjust the barrel on the cable at the derailleur. Try a small turn then shift up and down while turning the crank to get the cable and shifter to settle where the new adjustment wants to be.
If you ride regualrly it would be worthwhile to find a local bike shop (LBS) and get to know them. They can teach you some self sufficiency in exchange for a little business from you.
Posted on Apr 29, 2009
  • 1138 Answers
SOURCE: How do I get a replacement for a Disney Cars Huffy bike pedal?
You probably can't obtain an original part but if you can get the pedal off the crank ( right pedal unscrews counterclockwise, left pedal unscrews clockwise) you can take it to a good bike shop to match it up to a new one. You will probably have to buy a set unless they have a spare in the shop. Hope this helps.
Posted on May 26, 2009
  • 1138 Answers
SOURCE: Where can I find a replacement seat?
A good bicycle dealer?repair shop should be able to help you. Take the seatpost and old seat if you have it with you and they can sell you one. They will definitely need the seatpost to match the seat.
Posted on Jul 10, 2009
  • 1138 Answers
SOURCE: operator manual for huffy crosswind bike grip shift
Look for the manufacturers name and model number on the gripshift and check at www.parktool.com. Look under derailleurs for repair tips which will give you an idea how they work. A twelve speed has six gears on the rear sprocket and two on the crank giving you a combination of twelve speeds. sheldonbrown.com is another good site with good articles and pictures.
Posted on Jul 17, 2009
Have an older Huffy female 12-spd road bike that is missing the rear wheel assembly. Looking to find a replacement as well as instruction manual...wheel assy. more important. Thanks.
Unless you have a deep sentimental connection with the bike, it may not be with it:
Rear wheel - $35-$45
Rim strip/tape - $1
Tube - $8-14
Tire - $10-20
Gear cluster - $25-40
New Huffy is about $150-250
You might be able to find a used bike or wheel at a garage sale that would work.
Sep 19, 2015 | Huffy Cycling
How to change rear tire ?
Remove rear wheel with either a 15 mm or a 17 mm wrench. Take the tire off the wheel. If you are replacing a tire, reverse procedure. If you have a flat, replace inner tube, then reverse procedure
Aug 14, 2014 | Huffy Cranbrook 26" Mens Cruiser Bike
My Huffy Cruiser Cranbrook has the rear tire flat. Does anyone know how to take the wheel off so that I can replace the tube? Thnak you.
Loosen the axle nuts on both sides. Slide the wheel forward to disengage the chain from the gear. Now pull the wheel up and out the back, sliding the chain over the axle as you bring it out. Hope this Helps FixYa up.
Sep 03, 2011 | Huffy Cranbrook 24Inch Cruiser Bike
Have a "Stridor" ten speed
Sorry, it takes a special wrench. You can try a hammer and punch and try to knock it loose. It is a reverse thread. It is called a cassette wrench, here is a picture. This may not be the exact one to fit your bike, but it will look similar to this. They only cost about $5 - 6 dollars. Not hard to find here on the net. Start with a good bicycle parts site. Sounds like You will need to replace the cassette (gear assy)mcneb_6.gif
Aug 20, 2011 | Huffy Men Mountain Bike (26")
I just purchased a second hand 10 speed 26" Huffy bike and need to know how to work the gears
Web search "how to shift gears" and go to http://www.huffy.com/Support/OwnersManuals.aspx for there generic manual.
The web has all thwe answers. Just ask it.
Aug 12, 2011 | Huffy Cycling
How is the "ten speed"
I am answering, but hoping this is not a trick question. ALL Bikes from that time period had two shifters, one the speed gears and one to represent the Hi-Low Function of the gears. In other works, when shifter one was move, it moved the chain on the front sprocket to the Low Gear ratio, Which would translate on the rear 5 piece sprocket as gears 1-5. These were change by slightly moving the second shifter, which in turn would move the chain a slight bit and onto the next sprocket in the line. You could go in any combination of gears from 5th to 1st from 1st to 6th, all by moving the correct level, which would move the appropriate chain guide and mode the chain to the correct sprocket. Let me know if that helps at all. I tried to remove the technical in order to keep it simple. I can make it harder and more technical if you would like.
If you are trying to get to a certain answer, please do not hesitate to ask any question, other than where to get parts, cause that part of Huffy's business is no more and Huffy, really isn't the same Huffy as was in 1989. No really, different organization all together, they basically sold the name and ops.
Jun 30, 2011 | Cycling
We have the 20 inch Huffy seastar and the tires wont hold air, Do I need a new tube? and if so where can I buy them
beckysmith123-
Sounds like you may need new tubes. Tubes may be purchased from bike shops, most hardware stores, and some big box retail stores like Kmart and Target, to name a few.
If the leaks in the tubes are reasonably small, there are several products that can be squeezed into the tubes to seal punctures - both existing ones and ones that occur after the product is added. They are put into the tube through the valve stem, similar to adding air). Two that I know of are Fix-a-Flat and Slime. Both can be purchased at most hardware and automotive stores.
Changing a tube is not terribly difficult but can appear daunting if you've never done it before and don't have some of the tools required.
Hereare step-by-step instructions for most styles bicycle:
  1. Loosen thenuts that hold the axle to the frame.If they are extremely tight, spray some lubricant on the nuts - a siliconelubricant or even vegetable oil will do the trick.
  2. Take thewheel out of the frame. If it's therear wheel, you will need to lift the chain clear of the gear cluster. To easethe removal of a rear wheel, shift the chain to the smallest gear on the wheelbefore loosening the skewer or nuts. If it's the front wheel, that one will bea little easier. You may also need to release the brakes if they interfere withwheel removal.
  3. Deflate thetube completely by pressing down on the inner part of the valve.
  4. Take acouple of tire levers (you can purchase these at your local bike/outdoor store). You can use the handle of a spoon or similarobject if you don't have tire levers but be very careful, as you riskscratching or damaging the rims of the wheel and/or puncturing the inner tube.Ease one lever in under the wheel rim and lever out the edge of the tire(taking great care not to puncture the inner tube) and pry it up over the wheelrim. Move around the rim about an eighth of the circumference and repeat theprocess again, leaving the first tool in place. Now zip the second lever aroundthe wheel and the tire should come right off on one side.
  5. Remove thewheel and tube completely.
  6. Replace theinner tube
  7. Check thetire wall for an arrow or similar to indicate the direction of rotation - sometires have a "direction specific" tread pattern.
  8. Put one sidein first, then ease the partially inflated tube into the tire and locate thevalve in the hole in the rim.
  9. Starting atthe tire edge closest to the valve, use your thumbs to work the other side oftire over the rim and into well.
  10. Beforeinflating, use your thumbs again to ease the tire from the rim all around the circumference,peeking in to make sure that the tire is not pinching any part of the tubeagainst the rim. When youinflate the tube, if it is pinching, it will pop, and you will have to repeatthe entire process, and buy a new tube.
  11. Inflate thetube,checking to make sure the tireis on evenly and there is no "pinching".
  12. You're now ready to put the wheel back on the bike.
Hope this helps.
Regards,
DIYpro
Apr 29, 2011 | Huffy Dream Journey 20 in. Children's...
Brake system. how to install the brake system for huffy disney princess 16
The link below will take you through the brake assembly and how to use the brakes on a huffy princess bike. Go to page 30 and page 31. A diagram shows how the brake arm should be secured.
http://www.huffy.com/pdf/ownersmanuals/e0664c94-726b-49d6-8322-5e053dca5b0a.pdf
For more information on bicycles, bike safety or bicycle accessories, visit my website: Huffy Bikes
Dec 25, 2010 | Huffy Disney Princess 16 in. Girls Bicycle
Cycling Logo
497 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
