Question about Kenmore 659 Electric Dryer
Kenmore Electric Dryer 66812 clicking not starting
Hi I have a Kenmore Electrc Dryer Model-66812694 it stopped working, I can hear a clicking noise when i press start button coming from the timer knob but its not starting, kinda like a vehicle starter when battery is dead.
  • knubs Jan 07, 2009
    we have the same problem,does anyone know hoow to solve it
  • Anonymous Mar 18, 2014
    The timer make a clicking noise when I press the start button
  • 979 Answers
I hate to tell you this, but it is probably the timer. The good news is that it is easy to replace and you don't have to have a tech to do it.
Posted on Jan 14, 2009
I have a Kenmore Elite Dryer Model 110.66992500 that will not start. When the start button is pushed, it only makes a click. During the last use, the dryer was working fine then all of a sudden while...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 01, 2011 | Kenmore Elite HE4 Electric Dryer
My kenmore elite electric dryer inconsistantly starts to heat and
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
Kenmore model 66812694 - quits running, buzzing noise at restart
bad motor,when you hear that noise open the door,hold in the door switch with one hand and with the other spin the drum and have someone else start it while you do this,all your doing is helping the motor start to spin but it sounds like a bad motor,this could be from not cleaning out the dryer,if it's gas it should be done once a year,electric can go another 6 months because there isn't an open flame in there,if you clean out the dryer and vent line the clothes will dry on time,the parts will last longer and you won't have a dryer fire.
Nov 19, 2017 | Kenmore Dryers
Kenmore electric dryer, won't start and clicks by time dry knob
usually the thermal fuse goes and dryer dies part number 3390719 located in front of dryer on top of the blower wheel housing,when you read anything out you have to pull one of the wires off to get correct reading.also on some of the dryers there is a switch on the pulley that will kill the dryer if the belt breaks
Nov 02, 2009 | Kenmore 62602 Electric Dryer
I typed in 66812 not the number that is showing - I need to know what receptacle to use with the Kenmore 66812 electric dryer. Thanks for any help you can give me.
on the front of dryer open the door there should be a tag or on the rear where the cord goes into the dryer there should be a tag to tell you what the voltage is
should be a 250 volt plug and outlet to match
nema # plug-S42 AND THE OUTLET # 6-30 OR 6-50
Oct 17, 2009 | Kenmore 62602 Electric Dryer
Dryer just stopped
The dryer will not start with a broken door switch. Replace the door switch if found defective.
Most dryers have a door switch actuator lever - when you close a dryer door, it presses against the lever, which actuates the door switch. If the lever is broken, the switch would not activate and the dryer would not start. Replace the lever, if broken.
Note: Door switch actuator lever usually comes with the door switch assembly and it is recommended to get the whole assembly since there is almost no price difference between the door switch assembly and just the lever. Check your model for more details.
I would also, check the Thermal Fuse as well.
Jun 25, 2009 | Kenmore 62602 Electric Dryer
Th pilot won't start ,motor start but won't light the pilot
I have a Kenmore Series 80 (Model # 66812694, Stock # 66812) that will not start. The light comes on, but no power when you push the start button. I have checked the fuse box and everything is fine. I've also tried unplugging for 10-15 minutes and replugging it in, but no success. Any suggestions?
Apr 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Electric dryer heat coil off mid cycle
You have 3 thermostats. By the description of the problem it sounds like it needs a new high limit thermostat. All 3 thermostats and the heating coil can be checked with an ohm meter. Also check the ground on the heating coil. It could be grounding it's self out.
Jan 16, 2009 | Kenmore 62602 Electric Dryer
I can hear it running--but it doesn't spin
your belt is broken the heat should still work.
Aug 29, 2008 | Kenmore 62802 Electric Dryer
Kenmore 659 Electric Dryer Logo
374 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
