Question about Porter Cable 5,500 Watt Portable Generator #BSV550 W...
Porter Cable 5,500 Watt Portable Generator starts then cuts off
CarlGehrke
  • 169 Answers
SOURCE: My porter cable generator 3000 wt will not stay running once star
If this generator has been stored for any length of time with fuel in the carb you probably have a plugged main jet in the carb. As joboo1 says there are a few other things that could cause this behavior, but most often I see dirty carbs, water in the fuel, and plugged/dirty air filters. Get a flashlight and look into the fuel tank thru the filler hole, if you see anything floating in there you've got water in the fuel. Look at the ari cleaner, oil and fuel on the element indicate a dirty carb. Of course check the oil level. Lastly, take the bowl off the bottom of the carb (shut off the fuel valve first), if you see debris in there the carb needs a good cleaning.
Regards,
Carl
Posted on Mar 01, 2009
pic498
  • 32 Answers
SOURCE: no electricity from generator
If you have a voltmeter, you can check the voltage coming out of the outlet. If you have some kind of residual voltage, such as 25 Volts AC or 10 volts ac, then you probably have a voltage regulator problem and your regulator will need to be replaced. If you read 0 volts then you you have an open between the output (outlet) and the windings of the stator.
Posted on Jun 13, 2009
protek480
  • 1723 Answers
SOURCE: how do I test diodes
You have to have a multimeter and know how to use the ohms scale. Some meters actually have a diode test setting. Do you have a meter? I'd be glad to work you through it...
Posted on Jul 04, 2009
  • 905 Answers
SOURCE: Porter Cable Generator does not produce electricity
Here are a a few possibilities to look at:
1) Bad connection at the outlets themselves (loose wire) regarding neutral, hot wires.
2) Bad Excitation Capacitor. The Exc. Cap. is responsible for energizing the field wiring of the alternator. If the field is not energized, there will not be a magnetic field developed, therefore, no electrical output.
3) Open Field / Stator winding. If Field winding is open, no magnetic field will be developed. If Stator winding is open, no voltage will be induced.
4) Generator speed is too slow. If the RPMs of the engine are too slow, the output of the alternator will fail as well. Note that from normal speed, voltage output will occur but at reducing frequency until ouput ceases altogether, usually at about 47Hz. If your alternator is a 2 pole, engine speed should be 3600 rpm nominal. If alternator is a 4 pole (most aren't), engine speed would need to be about 1800 rpm nominal.
5) Generator speed too fast. If RPMs are too fast, output may fail as well. See above.
6) Excitation Fuse has blown. There is sometimes a fuse in the excitation circuit. To check this, you will likely need to pull the end housing off the alternator. Pay attention to bearings / bushings.
Posted on Nov 27, 2009
  • 45 Answers
SOURCE: I have a porter cable
high idle screw or governer
Posted on Sep 09, 2010
Gfci receptacle reset
There should be a reset button on the GFCI. If this keeps tripping, or will not stay in, the receptacle is bad, or there is a ground fault causing it to trip.
Mar 09, 2014 | Porter Cable 5,500 Watt Portable Generator...
No AC Output after sitting up for 2 years
If the field circuitry is good (winding, diodes, AVR, [rings and brushes if any], try to recharge the field for a few seconds when motor is running, with a 12 V battery "B+" to "F+", "B-" to "F-".
Jun 24, 2010 | Porter Cable 5,500 Watt Portable Generator...
No power in Honda generator
I DIDN'T KNOW HOW THE POWER CAME BACK , I SERVICE THE GENERATOR AND THEN IT
CAME BACK ,BUT I WILL BE BACK IF I HAVE PROBLEMS AGAIN THANKS
Mar 20, 2009 | Porter Cable 5,500 Watt Portable Generator...
Porter Cable 5,500 Watt Portable Generator #BSV550 W... Logo
Top Porter Cable Electrical Supplies Experts
John Trevino
Spud Howell
Are you a Porter Cable Electrical Supply Expert? Answer questions, earn points and help others
