Question about Dryers
How do you repair a blower wheel - Dryers
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of your unit?
Posted on Nov 06, 2012
Blower motor repair
Section 12-02A: Heating and Defrosting, Ranger, Explorer 1995 Aerostar/Ranger/Explorer Workshop Manual REMOVAL AND INSTALLATION Blower Motor and Blower Motor Wheel Assembly Removal and Installation
  1. Remove the windshield washer bottle.
  1. Position the speed control servo out of the way (if so equipped), refer to Section 10-03A.
  1. Disconnect the wire harness connector from blower motor by pushing down on the connector tabs and pulling the connector off the blower motor .
    Item Part Number Description 1 18527 Blower Motor 2 19A786 Blower Motor Housing Tube 3 - Heater Case Insulator
    (Part of 19850) 4 19930 Blower Housing 5 - Electrical Connector
    (Part of 19805)
  1. Disconnect the blower motor housing tube (19A786) at the blower motor .
  1. Remove three screws attaching the blower motor to the A/C blower housing (19930) .
  1. Holding blower motor housing tube aside, pull the blower motor from the heater plenum chamber case (18A484) and remove it from the vehicle.
  1. Remove the blower wheel hub pushnut and, if applicable, the clamp from the shaft. Then, pull the blower motor wheel (18504) from the shaft. For installation, follow removal steps in reverse order. Check system for proper operation. NOTE: When the battery has been disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module (PCM) (12A650) relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
Nov 16, 2010 | 1995 Ford Explorer
Drum vibrates unit and makes a rumbling noise
sounds like the blower wheel is bad.the blower wheel is behind the duct that the lint filter slides into,when the wheel goes it makes a rumbling sound,also you could have worn glides that the drum rides on or a bad roller,you need to get in there and look but i'm sure it's worth repairing
Mar 29, 2010 | Amana DLE330RAW Electric Dryer
I have a maytag ldg8200aaw gas dryer. it works and will dry clothes well but makes an extremely loud grinding noise as the drum turns...sometimes it even seems as if it is not engaging...I am trying to...
Your dryer is definitely worth fixing. The blower wheel is plastic 53-0106, These will wear out and get loose. Make noise and the clothes take a long time to dry. Repair Photosa9a0520.jpg
Mar 10, 2010 | Dryers
Maytag Performa Dryer doesn't heat up properly. Takes 2 to 3 cycles to dry clothers. Recently changed elements. Maybe a little better but not much. Any ideas?
I replace an awful lot of blower wheels on these. The flat portion of the plastic blower melts causing the wheel to be loose on the shaft. I have repair photos HERE
I pop the top and remove the front, then remove the old blower wheel and clean out the dryer, oil the rollers and idler and check the glides for wear. When I gits that baby back together it be sweet.
Feb 26, 2010 | Dryers
Dryer starts slow with rrrrrrrrrr noise and timer does not move
This could be a simple repair. The blower wheel in the exhaust housing maybe free spinning on the shaft. If it is replace the blower wheel. If not the motor has gone bad.
Feb 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Rumbling noise in maytag gas dryer DG110 series 01
Unplug Dryer first: Page 3-11 of full service manual at link below will get front off. The most common solution for your problem is the blower wheel loose on the shaft. Hold drum and see if you can turn blower wheel (lower left plastic squirrel cage) separately. If you can turn the plastic wheel while you hold drum still, replace blower wheel.
http://www.servicematters.com/maytag_library/docs/16008714.pdf
Aug 22, 2009 | Maytag PYE2300AY Electric Dryer
Blower wheel loose on shaft of motor on maytag dryer
GO TO www.repairclinic.com and enter the model number look for your blower wheel item 1245880 it looks as if there is a flat side on it. this may help ya Good luck
Apr 09, 2009 | Dryers
Grinding noise
In my humble opinion, a dryer making a grinding noise is worth repairing. Possible Problems:
Worn Drum Rollers (Very Likely): More of a thumping / grinding sound. Replacing drum roller supports is considered to be a routine "normal ware & tear" repair with parts costing about $15 - $20 or so. Its' kinda like a tune-up for a vehicle. The rollers can be located in a couple places, but are typically located on the inside rear of the drum; upon dis-assembling the dryer.
Broken/Loose Blower Fan Wheel (Likely): The blower wheel can become loose or brake off the motor shaft and can make a "rumbling / grinding sound and can run about $15 - $25 for the part. The degree is difficulty when repairing a little high, but is commonly performed.
* Note: Removing and threading the blower wheel is reverse to prevent the fan blower from natually spinning/coming-off "Righty loosey, lefty tighty"
- C
Jan 27, 2009 | Maytag Dryers
Dryers Logo
24 people viewed this question
Top Dryers Experts
