Question about Asko D1776 Stainless Steel Built-in Dishwasher
F2 Error Message on my Asko D1776
My dishwasher rarely seems to go a full cycle without an F2 error message flashing. We've checked everything and have had the repairman out here 3x. He said to let the water in my tap run very hot before starting the dishwasher which I did but it still happens. Any other people have this problem? Thanks!
Pay attention I got the same error F2, after many tests I have not understood where he lost, I called a technician and he quickly realized that the loss was caused by 2 smallholes in the sheet, these holes were caused by salt, we put salt and some grain is left for days on the sheet bucandola not believe it, the salt if left for a long time on the sheet metal drilling.
Posted on Apr 27, 2012
Clean out the pump...they tend to get clogged with grease...then poor washing up liquid in the strainer and poor a couple of kettles of boiling water in the strainer.
It worked for me on my Whirlpool dishwasher.
Posted on Feb 10, 2008
  • 641 Answers
F2 error message means that you have a high water level problem that could be caused: - A plugged or bed water pump - A defective water inlet valve (stay open) Good luck !
Posted on Jul 27, 2007
SOURCE:
F2 error code
The F2 error means the tray underneath the unit has filled with water
please check this solution:
http://www.fixya.com/support/t6078000-f2_error
Il you want to diagnose or repair the nit yourself, I suggest to protect yourself by connecting the unit on a residual-current circuit breaker (RCCB).
Sep 18, 2013 | Asko D1776 Built-in Dishwasher
ASKO D1976 model. We have a F2 error message. Water has now been drained but we are unable to remove error code or have dishwasher return to normal cycle
Display shows an error code. Do the following:
1. Unplug washer or disconnect power for one minute.
2. Plug in washer or reconnect power.
3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
May 27, 2011 | Dishwashers
Dishwasher runs part way thru cycle then f2 cumes up all lights come on and draim pumps runs all the time even with door open
F2 signifies high water level. Check the drain pump and drain hose, make sure they are not clogged. Check the operation of the water inlet valve.
Feb 23, 2011 | Asko D1776 Built-in Dishwasher
F2 error message after dishwasher backed up when draining. Asko brand.
Hi
Thanks for using FixYa. Error F2 in your Asko Dishwasher means high water level. This error occurs due to plugged/bad water pump and/or a bad inlet valve. If the water pump and/or water inlet valve are bad it should be replaced to resolve this issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Dishwashers
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
My Asko dishwasher is not draining. Code F2
drain plugged, hose kinked or discharge pump bad
Jan 19, 2010 | Asko D1976 Built-in Dishwasher
ASKO Dishwasher F2 light flashing
Hold the Rinse button for 5 seconds to reset.
Jan 19, 2009 | Asko D1776 Built-in Dishwasher
ASKO dishwasher
F2 fault water in the base remove dishwasher from under the bench and tip back water will run out,then it will restart.remove rear lower panel and run the dishwasher you may find a leak,also check that the inlet valve is shutting off and not filling the dishwasher up overnight.hope this helps.
Mar 27, 2008 | Asko D1776 Stainless Steel Built-in...
Asko 1776 dishwasher error message
open up the underside of the dishwasher and check the 2 terminals that connect to the heater element. Sometimes they burn off and it is a quick repair to just put a new terminal on the end. Also make sure the water going into the dishwasher is hot, as that can cause this problem too. Hope this helps
Oct 04, 2007 | Asko D1776 Built-in Dishwasher
Asko Dishwasher F2 Error Flashing
F2 flashes, and wll not stop runing. No water in pan. help
Sep 29, 2007 | Asko D1776 Built-in Dishwasher
Asko D1776 Stainless Steel Built-in Dishwasher Logo
1,330 people viewed this question
Top Asko Dishwashers Experts
Jose Pino
Marvin
Marvin
Archie Ferrarini
Archie Ferrarini
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
