Question about Intermatic Inc. ST01C Digital In-Wall Timer
Pushed reset button and will not respond. Red on light stays on
Wanted to reset my Utilitech LW0418. Pushed the place that says reset. None of the buttons will respond. Red light stays on and will not turn off. Turned the circuit breaker off and put it back on and timer is still unresponsive and red light is still lit on the on off switch
  • Intermatic Master
  • 5,089 Answers
11/6/12
Copy following link for Utilitec LW60418 timer.
Same as Westek TMDW10, and Stanley 30418
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is reset with one-button.
Unlike some timers that require 2 button push.
Push in reset button firmly with paper clip, and hold for several seconds. Repeat.
This action will clear timer memory.
If reset does not restore functionality, then timer could be bad.
This timer has 1 year limited warranty.
Suggest buying new timer at Lowes, and returning defect timer in new package.
Posted on Nov 07, 2012
  • 351 Answers
SOURCE: Trying to replace Intermatic with Utilitech inwall
The wires on your new switch are intended for black = power .. white = neutral . and red = lights .. with two black wires on the old switch I am assuming that there is a bundle of white wires in that wall box, the white timer needs to join that bundle ... then you need to determine which black wire is the power from the electrical panel ( voltage tester) and connect to the black timer wire .. the red timer wire connects to the other black wire in the wall..
Please Vote !!
Posted on May 13, 2010
SOURCE: I am trying to install
1) Wires in box:
Black looped to to next switch is Black hot wire
Other Black goes to fixture
2) Connect timer wires
Black timer wire goes to Black hot
Red (or Blue) timer wire goes to fixture
White wire connects to white neutral wires (usually connected together with wire nut and pushed to back of box)
Green goes to bare ground wire
Posted on Sep 21, 2010
SOURCE: installing a GE digital wall
Review:
Black goes to Hot wire from breaker box
Red wire goes to Load (light, fan, motor)
White wire goes to Neutral
Green to bare copper ground wire
Orientation:
Your original switch had 2 wires plus bare ground.
One of these wires is Hot, the other goes to Load.
You said original wires are Red and Black
How do you find Hot wire?
-Your original switch had 2 wires.
-Remove timer from box.
-Pull original 2 wires out where you can test them
-Turn on power
-Use regular tester
-Tape tester leads to wood sticks so your hands stay away from voltage
-Power is on
-Test each original wire to bare ground wire
-When tester lights up, that is Hot wire ... this wire connects to Black wire on timer
- The other wire goes to Load so it connects to Red wire on timer
How to test for Neutral wire
Test Hot wire to your white wires - No need to untwist them.
When tester lights up, that is Neutral
White wire from timer connects to Neutral.
Green goes to ground wire.
How to reset timer
I'm not sure which timer you have. Probably GE 15086. Reset is small round button below HOUR button. Use paper clip and push-in reset until timer flashes 12 o'clock.
Posted on Sep 30, 2010
SOURCE: I bought Utilitech #0141224 7
If your box contains 2 and only 2 wires, then the Utilitec timer will not work.
You need the Intermatic ST01C or EJ500 timers that operate with a battery.
I have tested the Intermatic and Utilitec timers:
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
http://waterheatertimer.org/ST01C-program.html#wire
Do not connect white and red wires together on any timer, but thank you for solving the problem why lights blink when connecting timers.
Now lets look at your wires.
Scrape paint off the wires so you can identify white and black.
According to your information, the black wire inside box will connect to timer-black wire.
The red wire always goes to Load (your light, fan, motor)
The white wire is necessary to complete a circuit so the clock inside timer will operate.
The timer has a clock just like your alarm clock, and it needs to connect back to neutral busbar in breaker box.
This is why the battery-operated timers will work with two wires, the clock runs on battery.
The Utilitec timer-white wire is the wire that goes to Neutral
The timer-white wire is supposed to connect to the other white wires that are twisted together and covered with a wire nut ... but some boxes do not have this neutral wire
To work-around, the timer-white wire can also connect to a bare ground wire.
The bare ground wire also connects to Neutral busbar in breaker box
If you do not have a neutral or ground wire as described above, then you need the battery-powered ST01C or EJ500 Intermatic timers.
See if you can pull some more of the wire into your box ... there might be a ground wire that was cut off and pulling more wire might reveal a ground wire. This will salvage the project.
Aplus is one of many places that sell the Intermatic timer
http://www.aplussupply.com/intermatic/timer.htm
For more about electric wiring:
http://waterheatertimer.org/See-inside-main-breaker-box.html
http://waterheatertimer.org/B220C.html
Posted on Oct 24, 2010
SOURCE: Utilitech 7 day in-wall digital timer #LW60418
Need programing instructions
Posted on Nov 13, 2010
Old hotpoint gas dryer will not stay running starts when start button is pushed will stay running if button is held in but stops as soon as button is release
you have a bad push start button test it with a meter for continuity ohms should show ohms when pushed in and none when released
Oct 04, 2014 | Dryers
Red exclamation light is on and brushes not turning
On my Electrolux Precision, the exclamation light indicates that it detected an obstruction and will stay lit until the obstruction is cleared AND the "reset" button is pushed. The reset button is on the black part (same side as the exclamation light) about half-way back on the side of the vac.
Apr 17, 2013 | Electrolux Vacuums
Buttons on controller light up but none of the buttons respond anymore I think they may have been over pushed as we have many grand kids running around pushing really ******* the buttons. I'm th
Couldn't hear anything in the video. You should be able to remove the board. The number you are looking at on the bottom may not be the part number, it looks more like a molding number for the plastic case.
Apr 15, 2013 | Refrigerators
I have a 6-month old RS261 and when I put in a new filter and pushed "water" for more than three seconds to get the water back on, the red light did not change nor did any water come out. What...
Try holding it for a bit longer. On my fridge, it is hard to push the buttons on the fridge. Sometimes, letting someone else push and hold the button helps. (It's a matter of getting exactly lined up on the contact under the touchpad. So coming back later or letting someone else try has always worked.)
If the above doesn't work, check that the child lock is off. Press and hold the Energy Saver button for 3+ seconds to toggle the lock. If none of the buttons are responding, then the problem may be in the panel. (I refer the problem to a repairman. Membrane type touch panels don't respond well to the cleaning process that I learned for other electrical devices.)
I hope this helps.
Jan 13, 2011 | Samsung Refrigerators
DOES RESET BUTTON PRESS AND RELEASE TO RESET5?
it should pop out,when motor over heat's. you push it up and you may or may not feel a slight click when button is pushed.it should stay in when pushed.
May 12, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Model 7305 - power light comes on when switch is pushed but none of the cycle lights or Start button come on when buttons are pushed
Problem was solved by pushing the very hard to find black reset button in the center of the back of the dryer.
Feb 22, 2010 | Asko Dryers
Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
Blinking lights, unresponsive
I went to the Maytag site looking for a manual. None existed for my model, but I looked up won't start under the FAQs. The advice said to push the cancel button twice. My model doesn't have one, so I just started at the left side of the control panel and pushed each button twice. pushing the dry button twice made the lights stop blinking. i pushed the wash button and the unit started.
May 08, 2009 | Dishwashers
Blinking red light standby/timer
It seems to respond to power supply, send it to a nearby technician. The problem might be it fused the picture power supply fuse. make sure the installation is at you presence.
Sep 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Nov 01, 2007 | Sony PlayStation 2 Slimline Console
Intermatic Inc. ST01C Digital In-Wall Timer Logo
318 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
