Question about Royal Office Equipment & Supplies
How do I unjam my royal rs 10 shredder
Dose not even make a noise let alone work
fellowesrep
  • 102 Answers
SOURCE: Royal 85X 10 Sheet Shredder
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Posted on Mar 02, 2008
  • 35 Answers
SOURCE: jammed shredder
First UNPLUG THE MACHINE.
Unscrew four (4) screws, two in front underneath top cover and two in back of top cover. BE careful not to disconnect any wires.
Rotate motor gear or belt in reverse to remove jam. Do not put oil on paper because it expands the paper thickness and only makes it worse.
Posted on Mar 03, 2009
  • 1218 Answers
SOURCE: I have a Royal RL170MX shredder. It has started
Try putting some oil on a sheet of paper and then shredding the paper with oil on it.
If that dosn't fix it....take cover off....(with the unit unplugged.) and check plastic gears in drive train.
Posted on Jun 28, 2010
  • 1218 Answers
SOURCE: How do I go about getting replacement plastic
For Royal parts and prices give Royal a call at 1-800-524-0799.
Posted on Aug 21, 2010
  • 1218 Answers
SOURCE: Replacement gear for Royal PX100MX shredder
For replacement parts call Royal at 1-800-524-0799; they should be able to help.
Posted on Aug 22, 2010
What kind of oil is used on the royal orca 9512x?
The shredder does not use oil. The noise probably relates to something jammed in the shredding mechanism or one or more damaged shredding elements.
Mar 01, 2015 | Royal Office Equipment & Supplies
Our shredder motor is working but it will not go forward to shred. It will reverse. I've unjammed every visible paper jam but still nothing. HELP!
If it wont run forward but does run in reverse you may have lost the PCB inside.... contact Royal at 1-800-524-0799 for parts assistance and pricing.
Nov 29, 2010 | Royal CIA 12X Shredder
Is it possible to unjam this shredder. It was allowed to get too full and I started eating it's own shredding . I have pulled all of the paper out that I can - but it still won't go.
If you have cleared all jammed paper out of the unit but its dead and wont run then its likely you have blown the PCB inside...replacement parts you can get from Royal at 1-800-524-0799.
Oct 16, 2010 | Royal 10X Shredder
How do I unjam my shredder?
Unjamming the shredder is sometimes complicated by what was put thru in the first place.
Run the shredder in reverse to pull out the offending material.
If there remains parts of the debris still obstructing the blades, run it forwards then backwards several times (like rocking a car out of mud)
If you need to remove the debris manually, UNPLUG the shredder first even though it has a safety catch when it sits on its bin.
Sep 27, 2010 | OfficeMax 0M96431 Shredder
My royal paper shredder is jammed. How do I unjam the shredder?
Normally try to run it in reverse while pulling the paper back out to assist the motor. If it won't even run in reverse then you will have to take it apart to manually clear the jam.
Sep 10, 2010 | Royal 15MX Shredder
My shredder is jammed and I cnnot get unjammed
Hi. Go to the local hardware store and purchase a small pair of needle nosed pliers. Use these to pull the paper from the shredder a little at a time. Then in the future only shred up to 3 sheets at a time so it does not jam on u. J.
Aug 06, 2010 | Royal 160MX Shredder
Shredder jammed
For any jammed shredder..try the following.. pull backwards on the paper while you switch the machine into reverse. Try not to tear the paper as if there is nothing to hold onto then you can't help the motor.
If this dosn't work then you will have to take the top cover off(after unplugging of course.) and the try to force the paper backwards out of the machine by turnings the cutting blades or gears in the reverse direction.
Jun 04, 2010 | Royal 150MX Cross-Cut Shredder
Feb 06, 2010 | Royal Office Equipment & Supplies
I have the Royal SC120 model. The shredder does
1 or 2 gears are broken. royal doesn't make many replacement parts for their machines, might try calling royal at 1-800-222-2310. I would recommend replacing unit with a Fellows brand shredder. royal also makes Ativa brand- don't buy it either.
Dec 11, 2009 | Televison & Video
142 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
