Question about Redfield 3-9x40 Rifle Scope Rings Fits Weaver Rails
Will redfield rings fit a weaver rail base - Redfield 3-9x40 Rifle Scope Rings Fits Weaver Rails
3 Suggested Answers
SOURCE: Can a novice install a Redfield base and rings?
Problem solved. Redfield had all the size information I needed and mounting the base was a breeze.
Posted on Jan 17, 2009
agent91
  • 2100 Answers
SOURCE: redfield scope mount
Paul , got the fotos, now I know what you got. And now I know I don't have that one, but,,,, My local ace hardware has a ton of ancient bases and rings in a draw, I can go through them, also, did you try gunparts.com? They sell to the public and have just about everything known to man. E-mail,,, whitebro53@bellsouth.net
Posted on Feb 15, 2010
Testimonial: "Thanks very much - you have been a tremendious amount of help. I am sure this problem with get solved with your help. I bid on e-bay already."
Will the rings that come with aim point H34L fit a ruger guide rifle?
No, Ruger uses custom rings which clamp onto the receiver in machined groves. You can get Burris "Weaver to Ruger" adapters for about $33.00 at Brownells. Mfr Part: 410990
BURRIS RUGER TO WEAVER BASE ADAPTERS
Aug 17, 2013 | Aimpoint Hunter H34L with rings
Directions for mounting weaver 1inch see thur scope mounts
there the same as any other mounts,,, screw then down on a wever mount and plonk your scope into them,,,then re-zero the scope
Nov 27, 2010 | Weaver 1 INCH PICATINNY WEAVER BASE RIFLE...
How many ft lb of torque for scope rings
A typical torque setting for scope bases (on a steel reciever) is 30 in/lbs. The rings (steel) need 15-20 in/lbs.
For a aluminum receiver and/or rings, 15-20 in lbs is about max. I use 10 in/lbs with blue Locktite for aluminum receivers and rings.
Apr 20, 2010 | Redfield Ring and Base Sets for Knight...
How to set up a redhead red dot pursuit deluxe
You must have the correct rings for your base. If the scope has rimfire dovetail rings already attached, it should be easy. Remove the 4 setscrews on the top of the receiver, install the dovetail mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!).Loosen the clamps, place the scope on the dovetail mount and tighten snugly.
If it has weaver mounts, you will need to install a weaver rail to your receiver. Remove the 4 setscrews on the top of the receiver, install the weaver mount (use blue locktite and DO NOT TIGHTEN THE SCREWS MORE THAN 10 IN/LBS! Otherwise you may strip the threads in the receiver!). Install the rings in the weaver slots, tighten snugly.
Go Here:
http://www.outdoorpros.com/How-To-Guides/How-To-Zero-A-Rifle-Scope/5
for info on how to zero your red-dot after you have it mounted.
Apr 17, 2010 | Cabela's Optics
Need a pair of adjustment caps for a Redfield 2x7 Scope Where might I locate?????
go on line with redfield and look for there tech phone number and call them.
Mar 19, 2010 | Redfield See Thru Rifle Scope Mount Base...
Redfield scope mount
Feb 13, 2010 | Redfield Optics
What kind of base would you use on a TC pro hunter
You base must be compatible with the type of mounts you use. You will have to get a gunsmith to fix them so if you decide to use weaver mounts for example, the logically you would use a weaver rail. Be cause different mounts have different holding methods, first select the scope you are going to use. Once decided then find a set of mounts that you are happy with and from there you select a rail that will accommodate your mounts.If in any doubt, ask the person who is doing the work for you for advise.
Feb 13, 2010 | Weaver Optics
The dovetail groves are closer on a pellet gun rifle and they ca not close enought.
You probably have rings designed for a standard Weaver style scope base.... you need "3/8" groove .22 style" rings... available from your local gun shop.
Hope this helps, Mark the Gunsmith
Please give feedback!
Jan 08, 2010 | Weaver 1" Inch Steel Gun Rifle Scope...
Jan 17, 2009 | Redfield See Thru Rifle Scope Mount Base...
Need to find a Redfield rifle scope repair shop-scope fogs up
iron sight inc.918-445-2001 4814 south elwood avenew tulsa oklahoma. 74107
Dec 11, 2008 | Redfield Ring and Base Sets for Knight...
Redfield 3-9x40 Rifle Scope Rings Fits Weaver Rails Logo
Top Redfield Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Redfield Optic Expert? Answer questions, earn points and help others
