Question about Frigidaire GLWS1749A Top Load Washer
Water leaking into tub
Slow drip of water into tub?
    Top Expert:
  • Frigidaire Master
  • 9,472 Answers
A solenoid is bad on the water inlet valve and needs to be replaced. Here is a link to the part to order.
Posted on Nov 06, 2012
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
  • 38 Answers
SOURCE: Water is leaking from under the washer.
Yes you are correct, there is a seal there. The part is not expensive, but the labor will be. This is a long job.
Posted on Mar 08, 2009
  • 77 Answers
SOURCE: Water leak from front load washer - Frigidare GLTF1240A
just remove bolts, open bit enough to fill with silicone, close back wait to dry, ready to go for couple more years.
Posted on Apr 26, 2009
  • 16 Answers
SOURCE: water leaking from below the tub. THe right shock
Yes it is the O-Ring part number 134146100 that is failing. I just had this happen on my washer. It involves a significant tear down of the machine. I have the service manual that I found on the internet showing how to tear it down. I am pretty sure I found it here on this site in fact.
Posted on Feb 02, 2010
  • 1531 Answers
SOURCE: leaking from the bottom of the washer.
it sounds as if the main tub ring is bad you need to pull your agitator out and check the two blots that hold the tub to the shaft and make sure they have not become loose or broken causing the inner tub to drop on the shaft and tear the tub seal.
Posted on Feb 23, 2010
Dripping water in frigidare. Affinity dryer
I appreciate your post, Joe Ivey!
From the information you have provided your Frigidaire dryer is leaking water inside the tub when clothes are drying. It sounds like your water valve may be leaking. You may want to have a professional technician out to your home to properly diagnosis your dryer this will help to avoid any unnecessary part purchases or future issues. Hopefully this was helpful. -Matt
Jan 11, 2015 | Frigidaire Dryers
Water is continually leaking into the tub from the inlets as a slow drip. This happens while the washer is off and continues forever unless the water supply is turned off. This is a stackable washer/dryer.
A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Jan 06, 2011 | Washing Machines
Slow muddy drip right behind the motor/
Is the machine noisy when it spins,because it sounds like the bearings are starting to wear and there is water leaking from the rear bearig seal.
May 03, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Model GSL9365EQ2. It has a slow drip
Take the drain hose out of the regular drain and lower it to gravity drain into a bucket, pan, or floor drain if available. Turning the water off should not have prevented the machine from starting. The drip is likely coming from a leaking solenoid water valve at the rear of the machine where the hoses connect. Replace the valve assembly after removing the cabinet top and maybe the cabinet back panel. Make sure to remove the power if you are going to do the work. Hope this helps!
Mar 26, 2010 | Washing Machines
When I push the faucet to off I get med fast
push down the tub-spout lift rod and it will empty the remaining water that is between the shower valve and the tub spout
Mar 10, 2010 | Moen Posi-Temp Single HandleTub And Shower...
Ice maker leaking inside freezer compartment, water dripping down from unit
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Sep 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Dishwasher tub leaks underneath
Hello. Anything is worth trying! But I would recommend epoxy. It works alot better with plastic and rubber items. Most of the leaks I have found in Kenmore machines are at the water pump. You may want to take a peek while it's running, just stay away from the wires!! Thanks!
Jan 17, 2009 | Kenmore 15899 Built-in Dishwasher
Water leaking into tub from inlet
you need to replace the water valve. Look on line for parts for your model
May 07, 2008 | Washing Machines
Washer tub slowly fills with water
Is your problem a SLOW FILL problem, or a problem with WATER DRIPPING FROM THE RUBBER DOOR SEAL - or BOTH? If you have a slow fill problem, this is generally caused by a bad fill valve, which can be attributed to hard water deposits or well water mineral deposits. Sometimes the fill valve can be removed, cleaned and reinstalled, but most of the time a new fill valve is required. If you are experiencing water leaking from the rubber door seal (bellow), it may be time to replace it. Sometimes the seal can develop a wrinkle or crease where it meets the glass, which can cause leaks. Water dripping from the door when you open after washing a load is normal. Water dripping during a load is NOT. The bellow may also have started to rip or tear inside the door which may not be noticeable until you pull the folds of the bellow back and look underneath it. I hope this helps.
Jan 17, 2007 | Kenmore Elite 45986 Front Load Washer
Frigidaire GLWS1749A Top Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
