Question about Vacuums
Spin and dry
Will not extract water
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 156 Answers
Check 4 sock in drain seen it more then once
Posted on Nov 05, 2012
What products will remove dog wee stain from a carpet?
  • Dog liquid waste turns to crystals when it dries,, the only way to get the crystals out is with hot water extraction. If you use too much water you run the risk of it getting into the padding or the backing of the carpet and then it smells till it dries out. You need to get a carpet shampoo or cleaner that has enzymes in it.
May 05, 2017 | Vacuums
Windsor fiber pro 20 Betco extracter not spraying out enough water
clogged nozzel run some hot vinegar through it... then some plain water. (do this in a dry bathtub.)
Dec 29, 2012 | Vacuums
Will not sunction water
Your extraction pump is bad. it needs replaced by a Repair center such as Sears.
Apr 17, 2012 | Bissell 7950 ProHeat Upright Wet/Dry...
Not working after vacuuming water.
Your wet/dry vac came with 2 filters.
Paper for dust and dirt and Foam for wet/dry use.
If you left the paper filter on and tried to vacuum a wet surface, you most likely shredded your paper filter and clogged the outlet vent above your water shut-off float.
You should always use a filter to prevent clogging of the cyclonic impeller blades next to the motor. When extracting water or moisture you will need to use the Foam filter to prevent water from collecting in your fan blade area which then creeps to the motor eventually causing it to seize up.
Mar 15, 2010 | Craftsman 17776 Canister Wet/Dry Vacuum
Hoover SteamVac isn't extracting solution from carpet. Motor runs and the brushes weren't turning at first but do now
That vacuum is fine on liquid extraction but often gets clogged by debris when it hits a solid. It would be better to do the clean with the steamvac then follow it with a wet/dry shop vac to be sure you got all the water. I say this because the vac built into that hoover is way too easy to clog.
Mar 13, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Car interior!!!!!
It will extract the water from the interior, just be sure to remove the paper filter from it before you do.
Jan 25, 2010 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
My Bissell all pro does not extract water from carpet
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
zcvzcv
Jul 12, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
My G series kirby carpet cleaner will not **** up the water or foam very well
The Kirby shampooer deposits the foam onto carpet,and works it into the carpet with the shampooer brushroll.After the carpet is dry,use the vacuum itself to pick up the dry foam and dirt.The Kirby Shampooer is not an extraction shampooer
Nov 14, 2008 | Kirby Vacuums
Won't extract
I am having this same problem. Do you have a manual because, I don't and I also would like to know what I can do to fix the problem.
Mar 24, 2008 | Kenmore 85920 PowerSpin Upright Wet/Dry...
Vacuums Logo
12 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
