Question about Dell Latitude D600 Notebook
Acer Aspire 5315 won't boot, black screen
I have an Acer Aspire 5315 and it has a black screen when I try to boot it. I have connected it to a good monitor and it didn't help. I replaced the hard drive with a good hard drive, and nothing. I tried to boot without the battery and it didn't work. I tried to boot with a boot disk, too.
When I hit the power button, it makes a bit of a chugging sound and then stops after a minute or so. It doesn't beep. The fan seems to be starting up.
I'm stumped.
  • philb74452 May 25, 2009
    I am having the exact same problem, it started after i let the battery die right down. Ive only had it as new for about 3 months now and if it is broken and can't be fixed just wanted all my files off it as they are really important. The night it died i had been downloading songs and wasn't sure if this was the problem. If someone could help, it would be brilliant
  • 3 Answers
I had the same symptoms on friends laptop. She had nothing to lose so gave me carte blanc.
Took out battery (to eliminate as problem) plugged in power, and powered up
Power light OK, HD flashed, CD flashed, then black screen. Powered down.
Did the following:
1) took cover off of fan/circuit board (see http://www.insidemylaptop.com/ for details). (4 screws)
2) take out fan (3 screws) and find huge amount of gunk on cooling fins at fan disch. Blew out with compressed air. Also cleaned fan blades.(reboot shows didn't fix.)
3) Repeated step 2, Pulled out memory sticks and cleaned terminals by rubbing with lint free cloth. Replaced memory sticks.
4) System boots normally. Replaced battery. Boots normally.
DAMN I'M GOOD!
Posted on Sep 23, 2009
  • thegt Aug 10, 2010
    Excellent tip. Saved me buying a new laptop. It looked like a band of felt stuck in the fan. I'd say that was kicking off some temp sensor or something. Mine would run for random amounts of time, but now it's rockin' again! Huge thanks to rpic257
Im having the same problem, you have to some how reboot windows vista virtually. PLease tell me if you have any luck.
Posted on Jan 05, 2009
2 Suggested Answers
SOURCE:
FingerStrong
  • 190 Answers
SOURCE: Acer Laptop Aspire 5315 Continuous Beep on Start Up
its either there is a stucked key on your keyboard or you have a bad ram (memory card).
Posted on Jun 11, 2010
My Acer aspire 5315 laptop,screen/display has gone all white.Please what should i do about it?.
if possible plug in to a external monitor if the display on the ext. monitor is white is likely video chip on motherboard. if its white the second you turn it on try the above. found here
white blank screen on acer aspire 5315 laptop how can fix this
if you see boot a little then it goes white watch this video
Laptop white screen trojan virus infection easy fix
Jul 03, 2015 | Acer Computers & Internet
Hello, I have an Acer Aspire 5315-2362 laptop and
Get a legal copy to install and your worries will be gone
Dec 26, 2010 | Acer Aspire 5315-2153 Notebook
I have an Acer Aspire 5315, the screen has just been black for a couple of days now. the two green lights on the front of the laptop are on, and seem to stay on constantly. So I am presuming there is still...
Lea, listen press F2 whilst booting up to get into boot sequence,there you can enable corect loading procedure of your hardware.Otherwise if you have an OS re install that,or even if you have an external monitor socket on the side of your pc ,,plug an external monitor in to see if your pc is working but the screen has failed,so theres some options!--Good Luck!
Davey Snake!
Oct 21, 2010 | Acer Aspire 5315 Notebook
Cracked lcd sct reen acer aspire 5315 model
I would start by doing a search on Ebay. Often times you can get parts or a damaged laptop with parts for a very reasonable price. I just did a search for your laptop model and found a damaged Acer Aspire 5315 for $81. As of this posting on 10/31 at 9:10 am CST time, the auction ends in 2 hrs.
After doing a quick internet search, I found a web site called http://www.screencountry.com and I saw a monitor for your model listed at $99.
Oct 31, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5310 the screen just blank and not
Possibly the monitor is defective - usually most laptops have a blue plug at the back for an external monitor, if plugging in a normal monitor brings up a screen, then likely the laptop monitor is defective. If you get a splash screen and bios info on trying to start it,it indicates your windows is defective or has lost it's start-up files - a windows reinstall will fix that.
Aug 29, 2009 | Acer Aspire 5315 Notebook
I want 15.4" WXGA Acer Crystalbrite LCD (8ms/220-nit) monitor.
my acer crystalbrite lcd 8ms 15.4 is no longer in my laptop and i need a software so i could download a new one
May 26, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 5315 lcd screen corruption. External lcd partially ok
i know your problem. even if you change the inverter it will not work. the real problem of your notebook is vga memory or video memory. use hot air to resolder your memory. trust me!
May 20, 2009 | Acer Aspire 5315 Notebook
Acer aspire 5315 refuses to boot up
plz try by reinstalling the operating system, if you cant then plz check your hard drive
Jan 13, 2009 | Acer Aspire 5315 Notebook
Black screen with cursor acer aspire 5315
start your laptop in a safe mode by pressing f8 during booting, the restore your system to a back date where its working fine
Sep 30, 2008 | Acer Aspire 5315 Notebook
Dell Latitude D600 Notebook Logo
4,201 people viewed this question
Clive
Clive
Alun Cox
