Question about Pbi HD3150 DTV Receiver
Digital Stream HD 3150 OTA HDTV tuner does not operate
On power up, red LED comes on in front display. Pressing on/off switch changes to green LED in display. Opened unit and power supply provides marked voltages to main board. No output to TV.
  • daveseb Mar 22, 2009
    Same problem. LED on front indicates red when plugged in, green when powered on. But no channels display and no output to TV.
    Anyone know a solution?
  • Anonymous Apr 02, 2009
    Power light goes red/green but no channel display and no video output
Disclaimer: The answer provided is entended for you to have some basic electronic knowledge and soldering skills.
Troubleshooting switching power supplies just sucks, but there are ways of finding the fautly componets. In my case, a visual inspection found 2 bad capitors, the tops bulging open and oosing goo. If you look at the tops of any other caps they should be flat. You can also note faulty caps by discoloration of the circiut board itself. I had one other faulty cap on my supply that, by visual inspection had been running hot. After replacing the defective caps (Nichicon 105c) I went with an ohm meter, and checked the smaller transistors for faults. Q1 a very common transistor was bad (2N3906) with a base emitter short. In conclusion, it's the cheap caps that are at fault, sometimes taking the silicon with them as they short out. The unit is now working.
As an added note, I understand that there is a Radio Shack branded version of the HD3150 as well.
Posted on Jun 12, 2010
Is RCA TV Model L40FHD41YX9 a high definition tv ?
It has a 1080p display panel (Full HD) and also supports 24p for the optimum way to display Blu-ray. So in these respects it is a high definition TV.
The built in TV tuner may or may not receive HD broadcasts though. That doesn't change the TVs ranking as a HDTV. It just means you might need an external HDTV tuner to get the same kind of quality from TV broadcasts as Blu-ray and console gaming.
Hope this helps.
Oct 13, 2014 | Televison & Video
How to set a clock on a hd dual tuner dvbr dch3416
The clock should set automatically, synchronized with your cable provider's time. You can't change it, as far as I know. OR does it display the channel number and you want it to display the time? If so, go to your onscreen menu (home), choose setup, choose cable box setup, front LED display: current channel ----> current time.
Mar 14, 2010 | Motorola Mobility DCH3416 (160 GB) DTV...
Dvr recording pauses occasionally (for about 30 seconds) and freezes (which requires a reset or unplug).
Hi! I will be more than glad to assist you in this concern. If your directtv hdtv receiver occasionaly pauses for 30 seconds and freeze and the only troublshooting steps that you do is to press the power button for 10secs or unplug the power-hard reset for 15secs. please do this steps
1. check if the software version of your receiver is updated, how to? got to the sysinfo of your receiver by pressing the sysinfo button on your remote or front panel of the hd receiver, write down on a piece of paper the version, then exit the sysinfo, run a check switch test, you need to access the menu of your receiver, once your done with the check switch and test.. turn off the power of your receiver by pressing the power button on the remote, make sure that there are no lights lit so that the satelite will automatically download the software if its outdated and if nothing happen it means that your software is updated. after all the steps that you did, by running the check switch and test.. still problem exist.. call the directtv tech support for the replacement of your hd dvr receiver, this is a dvr lost of function. I have experience that symptoms on my hd dvr receiver as well with one of the sat provider..
note: if you cant run the check switch and test, please call the direct tv tech support for assistance.
please feel free to get in touch if you have any query..
Aug 30, 2009 | Directv HDTV Receiver
How do you connect a Sansui STB-HD01 (set top box) to an LCD tv?
Hi trishallan! I will be more than glad to assist you in this concern.. On the back of your Sansui STB-HD01 (Set top box) there is an input name - ANT In- Attached an external antenna to this terminal. If your LCD TV is an HDTV you can use the HD-YPbPr (you will see there Red, Green, Blue) on the back of the Sansui-STB-HD01, The cable that your going to use is the component cable - the color is Red, Green, Blue) - connect the 1st end to the back of the sansui-set top box and the other end is going to your LCD-TV. If your LCD TV is not and HDTV you cand use the other terminal which is on the right side of the HD-YPbPr, the SD-YPbPr, you can use the same cable - the Red, Green, Blue, .. then there is s display switch-Set this switch in conjunction with MODE switch according to your TV display capability.and there is a mode select- Set this switch in conjunction with DISPLAY switch according to your TV display capability, then u need to tune in the tv to compionent channel, use the LCDtv remote to cycle the input of your tv.
if you have any query please feel free to get in touch..
Aug 28, 2009 | Televison & Video
Do we need to buy an antenna to get this TV ready for Digital TV?
LCD TV refers to the substance that creates the picture quality (it would be either LCD or Plasma or Tube) and HD refers to a crisp clear picture that can be attained. So your TV is an LCD (Liquid Crystal Display) TV that is capable of receiving and displaying HD (High Definition) Picture.
What you need to check for is whether the TV has a built-in Tuner. This will either be SD (standard definition) TV Tuner or an HD TV Tuner. The box it came in will tell you or you may still have stickers on your TV.
If it has a built-in SD tuner you will be able to pick up HD channels but in a lower quality. In this case you will only need to plug the TV into a Wall-socket antenna or rabbit-ear antenna.
If it has a built-in HD Tuner you will be able to pick up HD Channels in full HD quaility picture. Simply by plugging the TV into a Wall-socket antenna or rabbit-ear antenna.
If your TV does NOT have a built-in TV-Tuner then this TV is clasified as "HD Ready". Which means that you have to purchase a Set Top Box (STB). you can get either HD or SD set top boxes. In this instance you will plug the cable from the wall socket into the STB then from the STB into the TV using either an HDMI cable (as long as your TV has an HDMI input) or through RCA cables which will be coloured Green, Blue and Red (i think red)
By the Way - best picture quality is from a wall-socket antenna.
HDMI = High Definition Multimedia Interface
STB = Set Top Box
High Definiton RCA cables will also be refered to as YPbPr/YCbCr (depending on equipment)
LCD = Liquid Crystal Display (the method used to make the picture on your TV screen)
If you have anymore questions, ask away.
May 26, 2009 | Philips Televison & Video
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
Combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Sep 18, 2008 | DISH Network Televison & Video
Digital television signals
What type of digital tv signal? Satellite or OTA (Local Digital Antenna Channels)?
What type of equipment is the split signal going to? Straight to the tv's or some sort of Satellite or HDTV Tuner box?
Dec 19, 2007 | Motorola HDT101 DTV Receiver
No signal
reconnect the antenna and restart the receiver. then go into the menu and a run the initial setup. make sure you dont skip the zip code. it may take a moment to register all the channels
May 13, 2007 | Samsung SIR-T451 DirecTV DTV Receiver
Problems with subtly changing colors
What connection are you using, HDMI or component?
Also, on what source is the problem happening, through sat or through off air antenna?
If you're on HDMI I'd try component. Then, playback the affected video and see if it's reproduced w/ component.
If it's on ota only, you may have a loose tuner cable inside. It's easy to fix, you need a torx t-10 screwdriver. Unplug the unit, take the 5 torx screws off of the back cover, and on the right side you'll see 2 cables running from tuners in the front to a splitter that connects to the tuner for ota on the back right. Just make sure the connections are tight with your hands only, don't over tighten them. Also, make sure you don't touch the power supply when you have the unit open!
Apr 06, 2007 | Directv HR10-250 DTV Receiver
Pbi HD3150 DTV Receiver Logo
502 people viewed this question
Top Pbi Televison & Video Experts
Electro Med Services...
Are you a Pbi Televison and Video Expert? Answer questions, earn points and help others
