Question about Sony Playstation 3 (PS3) Console
My ps3 will not work
I just bought my ps3 two days ago and we just plugged our hdmi cable in and the whole system just shut down what do i do???
  • a_bomb_mx May 11, 2010
    yes
  • n_alspaugh May 11, 2010
    Was the PS3 working before you used the HDMI cable?
  • 124 Answers
Try pluging in the cables it came with first while on stand by hold down power on system for 10sec hope this works iif it does then try to switch to hdmi cord and reset system
Posted on Jan 07, 2009
I plugged in my PS3 using an HDMI cable and i get no feedback
If you just bought the PS3 use your composite cables that came with the system. Turn the PS3 on and go to the video settings, set up video input to HDMI. After you've done that plug your HDMI back into your PS3 and try turning it on. If that works go back to video settings and change the resolution to 1080p. If that doesn't work make sure your T.V. is on the same input that the HDMI cable is plugged in. If it is and still doesn't work try switching to a different HDMI port. If switching to a different HDMI port doesn't work try a new HDMI cable. If the new HDMI cable doesn't work then there is a problem with the port on the PS3 which would require a repair.
May 03, 2011 | Toshiba 50HP66 50 in. Plasma Television
My ps3 was working fine four days ago. I took it to my brother-in-laws two nights ago and hooked it up. We played it on his tv with an xbox hdmi cord and it was fine. I took it home and plugged it up to...
Ok you must be using a a/v cable at your house? And the hdmi cable at your brother in laws? If this is the problem its not the xbox hdmi cable. It doesnt matter all hdmi cables work the same. Its your settings. You need to hold you power button down and it should come on and beep twice then release it and a settings menu should pop up if it doesnt hold the power button down until it comes on and shuts off then hold the power button down again until it beeps twice. Hope this helps.
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
HDMI not working with PS3
Try to reset the video signal: when you power on the ps3, gently press and hold on to it for a few seconds untill you hear a couple of quick bleeps. release your inger and you should now be able to reset you r ps3 to HDMI signal. Hope this works and makes sense. if that doesn't work then you and i are facing the same problem.
Good luck
Jun 18, 2009 | Sony PlayStation® 3 (60 GB) Console
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
Ps3 static audio
I just bought my PS3 and noticed this exact problem, Go into your audiosettings click hdmi. then go to manual. Uncheck Dolby 5.1. save your settings. This fixed the static for me. Sony should fix thier 5.1 drivers
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Hello can you help with this error!
When you switch from one cable connection to another (Hdmi to AV etc) you need to reset the PS3 to its default settings. Basically what is happening is, your PS3 is set to HDMI, so when you plug in AV cables it doesn't know it. So you have to reset it. Hook your PS3 up to whatever cables (make sure system is fully off) then hold the front power button down for a few seconds.
Doing this will reset the display settings. You can then go into the XMB (main menu) and choose your connection. Although the PS3 should do this during the start up on its own.
Hope this helps.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Ps3 power problem
Hi lafayetteron,
I am currently working on this problem with a PS3.  Can you tell me what lead up the PS3 shutting down, did you remove a cable or anything prior to this?  I see you were playing Call of duty 3. If I find the cause tonight, I may be able to fill you in on what the cause is.
Repairtech@playstationclinic.com
Oct 23, 2007 | Sony Playstation 3 (PS3) Console
It wont run through HDMI
Follow the guy aboves solution to reset your Ps3 to 480i. Turn the power to the system off from the switch on the back and then when you flip it back have the power button held down on the front of the system. This only resets the picture doesn't change anything else or erase any games, I had to do it and it works!!
Oct 22, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
