Question about Maytag Dishwashers
Maytag wu204 door latch lever will not flip all the way to the right to latch-even when the door is open.
  • crookedseam2
    crookedseam2 Nov 06, 2012
    I guess it's not supposed to flip over with the door open. I cleaned the plate on the right side, sprayed liberally with WD40, exercised the plate & spring & now it's OK.
5 Suggested Answers
  • 833 Answers
SOURCE: dishwasher door latch
Check for a couple of screws to the left and right of the latch handle. Remove them and the unit should slide out and allow you access... By the way...if they are loose, tighten them first...you may just fix the problem.
Posted on Dec 09, 2007
SOURCE: Door Latch does not open door
I threw caution to the winds and removed the outer panel of the appliance. The plastic latching handle practically fell out--it was broken. Called all local parts suppliers--none had any parts in stock for this dishwasher. Called the manufacturer, who had a part listed on his computer at a distant location. Ordered it, paid for it, and was assured the part would be received within 2 days. Incidentally, you can't order just a replacement latching handle. It is included as part of a component.
Posted on Sep 24, 2008
  • 28 Answers
SOURCE: broken maytag door latch assembly
unscrew from bottom
Posted on Nov 17, 2008
I just had this problem (or should I say, finally had the time to deal with it). Google searches revealed different ways to get the door open including repairmen with crowbars (causing replacement of the entire control assembly $$$), having to back out the top screws that hold the dishwasher in place (and to the top of the counter) with pliers, then moving the dishwasher out from the counter.
Nuts to all that.
First things first. Turn OFF the power to the dishwasher.
I wound up on my back first watching how the handle moved and which side seemed to be loose, in my case the right side was moving freely. After first trying to hold the handle in the "down" position with a springhook (to no avail) I wound up biasing the handle to the right (with a screwdriver inserted on the left side of the handle) while moving the handle in the "operate" direction. Suddenly (and without warning) the entire handle assembly moved to the right and created an opening that made it simple to stick a screwdriver up to operate the latch manually.
Four screws later the control panel was out, the offending broken handle assembly was in my hands to discover that they could have easily made the little tabs the hold the handle in place a whole lot sturdier, but let's not go there...
If I had to do the whole thing again it would have taken me less than 5 minutes to open it up I'm sure. Now to simply order the part and install it when it arrives. The best part is we can still run the dishwasher until it gets here!
Posted on Dec 06, 2008
How do I get the rear lift door open on a 2000 ford winstar? I have removed the inside panel..
That is a tricky one, could be just sticking and some WD40 or white lithium grease could help to get it freed up to work. I am assuming you are referring to the lever that is on the right latch itself and not pulling on the cable. If I recall, there is a spring that turns the latch to the open position, perhaps having an assistant help by trying to open the door as you flip the latch lever could help to get it to release.
I apologize I can't assist more, but hopefully you can get it.
Feb 01, 2017 | 2000 Ford Windstar
1995 grand marquis fuel door button not working
when the small spring that flips the fuel door open when the button/ lever is pressed/pulled ,it gives the impression that the control is not working. Check out the problem by having someone operate the control while you are listening at the door. If you hear the latch moving then the spring is broken/missing. You may be able to get to the latch by removing the boot trim and moving the latch enough to open the door.
Feb 03, 2015 | Cars & Trucks
DOOR WONT OPEN
ha on either inside or out side?? you are going to have to take the door panel off and try to flip the tab to open the latch. the latch either broke or the rod fell off that moves the latch release lever
Nov 09, 2013 | GMC Cars & Trucks
Back doors won't open from the inside
Open the door from the outside and while open look at latch mechanism on door.
There should be a small sliding or toggle lever and it only has two positions.
Flip it to the other position...and this should fix it.
This is a safety feature to keep children from opening the doors from the inside...
Hope this helps...
Aug 28, 2011 | 1996 Ford Explorer
We have a wall mounte singe maytag oven. When I go to set the oven temp. the panel reads"door" and I am unable to set it. I have opened/closed the door and put the lock lever on and off, but to no avail....
Hello there:
Here is all of the possible error codes for the door and what they mean and what to look at
DOOR Bake or Broil
· Defective latch switch
· Shorted wire from ERC 10-pin connector, pin 10 to ground
· Door latched Replace latch switch if defective.Replace wire from 10-pin connector if defective DOOR Self-Clean
· Open wire from ERC 10-pin connector, pin 10 to ground
· Door not latched Replace latch switch if defective.Replace wire from 10-pin connector if defective LOCK Not in Self-Clean
· Oven temperature sensor resistance too high Check oven temperature sensor resistance, wire harness and connections, replace defective component
Sep 28, 2010 | Maytag MEW6527DDS Electric Single Oven
Trunk latch on 2002 Civic EX 4-Door won't close
trunk latch cable probably needs to be replaced
Jul 06, 2009 | 2002 Honda Civic
Maytag Model # MDB7600AWW door will not latch
double check door latch make sure connections are proper if right and still not working probably main board and panel
Apr 23, 2009 | Maytag MDB7100AWB Dishwasher
Broken maytag door latch assembly Maytag quiet series 300: the latch is not working, door is closed and cannot open, seems something snapped inside, how can I open the door ? and change the broken part ?
To open this latch, the handle works as a lever to push inward when you push up on the handle. If your handle if broken, it has probably ceased to work as a lever (the pivot pins have likely broken). You want to push in on the handle to open the latch, ideally toward the bottom of the handle opening. Once you get the latch open, you'll likely want to order a replacement (here is one source : http://www.repairclinic.com/PartDetail/Door-Latch/W10130694/1266678 ). Remember to turn off the power to the dishwasher, and you'll need a star head driver to remove the screws from the inside of the door to access and replace the latch.
Andrew
Nov 17, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Soap dispenser
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Jun 04, 2008 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwashers Logo
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
