Question about Sony STRDH520
My receiver mutes itself - Sony STRDH520
Why is humming coming from speaker when mic is keyed?
this is strange as most times if a proper transmit key is depressed , then the radio switches from receive to transmit , the mfg know this would cause some great squeal from receiver /transmitting so close to a receiver so the part that is the receiver is muted to keep this from happening , id say there is some fault in the part that does this muting of receiver
Apr 13, 2016 | Radio Communications
Receiver won't play music from an MP3 device
Use your computer speaker as the sound device or use a headphones.
If it sounds good, it could just be your cable that goes to the receiver.
( using a Y cable to connect to one of the regular audio inputs.)
or have one like these:
3.5MM To Stereo Rca Cables: Electronics
Sep 25, 2012 | Sony STRDH520
Hk 630 i belive any way when i turn it on it shuts off immedately. now if i mute it it will stay on.. what is going on
check all your speaker connections for shorted wires, and the cable itself. if it still won't work, then its most likely an internal problem. muting is probably isolating
the output to the speakers.
Oct 03, 2009 | Audio Players & Recorders
Avic f900bt always on mute but key sounds and navigation not mute
You have to isolate yellow-black cabel. This cabel was in contact with earth and it was the reason, why you have Mute on the display.
Mar 26, 2009 | Pioneer AVIC-F900BT Car GPS Receiver
Programming Harmony 880 Remote to Mute with CC on Sony Bravia KDL-40W4100
Do you use a Home Theater receiver along with your televison?  Are other components, such as a DVD player, VCR, Blu-ray player, etc. connected?
If so, it's possible that the Mute function on your remote is muting the sound from your receiver, and not the TV itself.
If that's the case, you'll need to look at the details of the "default" buttons for your activities, and see whether the Mute function is associated with your TV or your receiver.  If it's set for the receiver, you need to change it to be associated with the TV.
Oct 30, 2008 | Logitech Harmony 880 LCD Remote Control
Muted sound
Mar 14, 2008 | Pioneer DEH-1500 CD Player
Sony cd car stereo
Your Cd Player has a cell phone mute wire (lt blue) to connect to a car kit.
You may have inadvertently connected it to something else, or the bare wire may be making contact with something causing it to engage the ATT (MUTE).
Best of Luck.
Oct 25, 2007 | Sony CDX-CA750X CD Player
Disconnects by itself; mute problems
Mine also disconnects from my PS3 occasionally.
Oct 20, 2007 | Motorola Mobility H500 Wireless Headset
Sony STRDH520 Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
