Question about LG 60PC1D 60 in. Plasma Television
Power and audio, but no video - LG 60PC1D 60 in. Plasma Television
    Top Expert:
  • LG Master
  • 75,311 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Posted on Nov 06, 2012
How do I set up my secura cam SW214-SCC
Step1: At the end of your SecurityCam cable you will find three colored plugs: Yellow(Video RCA), white(Audio RCA),Black/Orange(DC Power) or identify
OR
Identify the cables at the end of the SecurityCam cable as color for video ,audio and power may vary.
Step2: Plug Video RCA plug(1) into the "Video In" input(3)(Usually located at the back of your TV or VCR)
Step3: Plug the audio RCA plug(2) into the "Audio In" input(4)(Usually located at the back of your TV or VCR)
Step4: Connect DC power plug(5) at the end of your Security Cam into the end of the power adaptor(6)
Step5: Plug the power adaptor(7) into the main power point in your wall
Step:6 If you have AV/TV with RCA sockets you will need to switch the TV to the AV change to view the camera.
Pictures is attached. Please have a look at it.
Jul 17, 2016 | Office Equipment & Supplies
Tip
Tv problems lg and vizeo
Power Issues Troubleshooting
*NOTE* LG & Vizio TVs must be plugged in for 5 minutes before it will turn on*
1. Inspect ALL Ribbons and connectors. Any tears or bad connections between boards must be replaced FIRST
2. If you have any of these boards, it should be the first board to be replaced
A) T-Con Board - Video Problems (No Video with standby light on, audio but no video, grainy, distorted, or color problems in screen)
B) X or Y Buffer Board (Plasma TVs only) - Standby light is on but no power
C) Backlight Inverter / LED Driver - No Video with standby light on
3. Main Video Board
- Either video or audio does not work (if no T-Con in TV. If audio but no video it is T-Con)
4. Power Board - No power AND standby light does NOT turn on. If standby light is on try other boards above
5. Panel - No power, distorted picture, lines, slow motion, half screen, faded in / out. Panel problems are usually not worth replacing the panel.
on May 22, 2015 | LG Televison & Video
How do i wire up camera after somebody cut off plugs
INDUSTRY STANDARD WIRE CODE COLORS FOR CAMMERAS ARE AS FOLLOWS
RED- POWER SUPPLY POSITIVE
BLACK - POWER SUPPLY NEGATIVE
WHITE- VIDEO CENTER
YELLOW- AUDIO CENTER
THE SHIELDS ON VIDEO AND AUDIO HAVE TO BE JUMPERED TO BLACK - POWER SUPPLY NEGATIVE
NEVER ALLOW POWER SUPPLY POSITIVE TO TOUCH VIDEO OR AUDIO LEADS
Oct 09, 2014 | Lorex Home Security
My yamaha does'nt turn on it just blinks on then turns off right away
You have a power audio amplifier problem.The blinking is an error code,common on latest TV,audio/video and all electronic appliances. The one that you have is your Audio Power amp is defective,it needs replacement of main Audio Power IC,do check the caps too.
Dec 15, 2010 | Yamaha RX-V795 Receiver
Ps3 plays audio but does not show image on tv
Well you can just use the hdmi cable if you're going both audio and video in to your tv. With your hdmi cable you get the best quality for both.
But in anycase, it seems that your PS3 is set up to output video via HDMI cable. To reset our video output settings, simply power down your PS3 (turned off) and hold down the power button until you hear the second beep. (around 5-10 secs) Power back up and hopefully you'll have video via your av cable. Hope this helps.
Apr 22, 2009 | Sony Playstation 3 (PS3) Console
Power On-Green Light....No Video No Audio
If replacing the power board did not fix the problem, then there is only one board left to replace that could affect both audio and video. It is called the motherboard( the board with the highest count of microchips on it and the smallest components.
Jan 08, 2009 | Televison & Video
Picture Shrinks and Expands
If you have any of the following problems you may want to check the site www.TvRepairKits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
Symptom: Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
Symptom: No Audio or Video but power light is on
Symptom: Audio works but no Video. Power light still work
Symptom: No Video. Audio is intermittent. Power light still works
Oct 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox rear projection tv mn 9p5514c101
If you have any of the following problems you may want to check the site www.tvrepairkits.com for a repair kit. Most of the issue below are fairly common with the older Magnavox projection sets.
(Note: The below symptoms typicaly occurs after having the expanding/shrinking screen problem above)
Oct 11, 2008 | Philips Magnavox 9P6034C 60" Rear...
Audio noise
turn down the volume or dont use s video us fire wire it eorks way better
Feb 23, 2008 | Canon GL2 Mini DV Digital Camcorder
LG 60PC1D 60 in. Plasma Television Logo
20 people viewed this question
Computer Repairing
Computer Repairing
