Question about Bobcat Miller 225 Welder Generator 907209 Or 907210
My 225 Bobcat welder will not crank. I can pull the fuel hose off and stick it over the carborator and it pumps fuel into the carborator and runs. But when I take it away it stops. Plug the Hose back up to the carborator and it won't stay running. I have pulled the top of the carb off and cleaned, needle valves working fine. I see that there is an electronic piece in the back of the carb with a wire to it. Is it possible this piece isn't working correctly. I need help. Is that a fuel shut off?
5 Suggested Answers
  • 18 Answers
SOURCE: Bobcat Miller 225 won't start.
Check the oil safety switch maybe it is bad. It will stop running if low on Oil or wont start.
Posted on Feb 19, 2011
kel1guy2002
  • 3740 Answers
SOURCE: Bobcat 225 welder fuel pump
Hi Harry, I hate to not answer yet but which engine do you have? The Robin / Subaru engine or the Kohler engine? I can get you the service manuals but need to know which one to search for.
Kelly
Posted on May 05, 2011
luis_david
  • 407 Answers
SOURCE: Why is my bobcat 225 not welding hot enough?
If all your settings are correct and still not hot enough probably your fuse F1 is open and need to replace. Check page 42 of the owner's manual for instructions.http://www.millerwelds.com/om/o4434q_mil.pdf
Hope this fix your problem.
Posted on Nov 30, 2011
  • 1212 Answers
SOURCE: have a 225 bobcat welder wont stay running can add fuel to carberator but if i stop sparing fuel in unit stops??
The fuel pump is one of the probable faults, or the needle valve in carb is stuck in closed position.
If the fuel hose is removed at carb, it should squirt gas as the engine is cranked over. If not, look in tank to see if the screen on the barb threaded into the tank has not clogged up with debris. If it is clean, replace fuel pump.
If it squrits gas- open up the carb and check to make sure the float is able to pull the needle valve down as well as the float level setting. When the bowl is exposed, look for sediment as well.
Posted on Jan 04, 2012
No gas coming to carb fuel filter good engine runs while sraying gas in carb
Onan engine? If so, check your fuel pump. It will be located on the engine cowling. You'll see 2 fuel lines, one on top and one on bottom. These are the fuel in/out lines. The line you WON'T see is the vacuum pulse line that hooks to the rear of the pump assembly behind the cowling. This line operates the pump via a vacuum pulse created by the engine.
You can remove the pump mounting screws and the pump will pull away from the cowling a short distance exposing the vacuum pulse line. Make sure it's attached and not dry rotted. If the engine has set up for any extended period, there's a good chance the pump gaskets are "glued" to the pump chambers (internally) by bad gas and not allowing the vacuum to pump the fuel. Onan has (when I was working on them) kits for these fuel pumps and I've installed them successfully, but it might prove to be somewhat tedious if you're not well versed in kits of this sort or not extremely mechanically inclined. But if memory serves, a new pump was priced within reason. Good luck.
Feb 16, 2015 | Bobcat Miller 225 Welder Generator 907209...
I have a miller bobcat 225, it keeps blowing 30 amp inline fuse on a blue wire that runs to the hot side of the starter, any idea?
millerwelds.com will let you down load a manual for this unit, it can help you with this problem, also you can call miller and tech support should help
Jan 22, 2015 | Bobcat Miller 225 Welder Generator 907209...
Oil coming out of the fuel pump
replace seals if possible
failing that renew pump
Oct 07, 2013 | Bobcat Miller 225 Welder Generator 907209...
Is ther a fuel shut off valve on bobcat 225 welder
No shut off unless someone installed it- a good idea if ithas running gear. Unit has an electric fuel pump. Check to make sure wiring to it is in good condition and not brittle from heat. When in start position, there should be 12 volts to pump- it bypasses the oil pressure switch until key is moved to run position.
Check the fuse to the fuel pump to see if it has not fatigue failed- it will look okay but no continuity.
If fues is good, then next:
The Oil pressure switch is in the circuit to shut off fuel It may be defective, or fuel pump may be defective. Check for continuity with a full oil level first. If you do not get about 5 ohms or less continuity, replace switch.
Sep 23, 2012 | Welding Tools
My miller 225 welder will crank but not start, no spark, i tried jumping the oil psi sensor. what do i do next?
I had a problem like this a few days ago try taken of the air filter to were u can see the choke it may not be opening rite just cause it opens don't mean itsnot opening rite get a small spray bottle put gas in it and as u start ur welder spray the choke with with the gas a lil if it starts turn ur switch to run for while it workd for me if that don't maybe change the spark plugs
May 20, 2012 | Bobcat Miller 225 Welder Generator 907209...
Have a 225 bobcat welder wont stay running can add fuel to carberator but if i stop sparing fuel in unit stops??
Jan 03, 2012 | Bobcat Miller 225 Welder Generator 907209...
Bobcat 225 does not produce ac current 110 or 220?
Probably you need to act the braker, put the idle at max (pull throtle) and let it run for a minute, that will reset the braker.
Dec 03, 2010 | Bobcat Miller 225 Welder Generator 907209...
New fuel pump but won't pump fuel
start from the geginning. fuel tank- trash water etc. fuel line, valve open line not plugged, caberator clean and float not stuck closed. use air to blow lines out. good luck
Sep 02, 2010 | Bobcat Miller 225 Welder Generator 907209...
Bobcat Miller  225 Welder Generator 907209 Or 907210 Logo
51 people viewed this question
Top Bobcat Welding Tools Experts
Lawrence Oravetz
wadingriver
wadingriver
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
