Question about Speakal Ipig 2.1 Stereo Ipod Docking Station Pink Ipigpnk Kit
I have lost my speakal ipig power cable - if i replace it what size is the socket?
UN50EH5000F
First disconnect the power and signal cables. Then, open the back of the TV carefully. Lots of screws of different sizes. Remember where each screw goes. You will find flat cable connectors and sockets. Just pull out each connector from socket, blow into the holes to clear any dust. Plug them back one by one.
Then close the back and put the screws on and plug in the power and signals. see if this worked. Lots of times, dust settles in the connectors and if you are in a humid environment, the dust and humidity form a thin layer of insulator enough to block low level signals.
Aug 08, 2016 | Televison & Video
What is the bolt size on a starter in a 2006 Suzuki Verona? one is 14mm. the other is smaller. what is that size?
what are you asking?
i lost my bolt???
or i can't find a socket tool to fit the one there, metric head size?
you said one is 14mm well that is not the bolt size, its the head socket size.
so i guess your socket set is missing all the other sizes?
10 to 22mm?
what we do is try all metric sockets if stumped.,
it will be one of those.
Sep 10, 2014 | 2006 Suzuki Verona
I would just like to know what tools i need to replace my 2001 pontiac sunfire battery. i have looked everywhere online and there have been no answers to as wht size sockets i need.
Besides the battery retainer, all I know that's left is battery cables. For the battery cables you might be able to use a pair of vice-grips and or pliers, maybe an adjustable wrench. To work on your own vehicles you need a basic set of wrenches and sockets, standard and metric sizes. Vice-grips are good if the battery cable bolt or nut has been rounded off. It's always best to use the proper tool.
Other than battery cables, I don't know what bolts your talking about? What is liter size of engine?
May 31, 2017 | Pontiac Sunfire Cars & Trucks
Bolt size for 2008 ford focus side mirror
Thread size is 8mm 10mm is the head size meaning you use a 10mm socket
Apr 01, 2013 | 2008 Ford Focus SE Sedan
Have lost the cable that connects to computer. Besides the power, there are 2 sockets on the back. Tried a cable from the square socket to USB but computer doesn't recognise that a device is connected....
The round socket sounds like the power port, and the square one should be the USB as you thought.
Please respond with the scanner make/model and one of us can verify the connections required.
Joe
Dec 20, 2009 | Canon CanoScan D1230U Flatbed Scanner
Lg micorwave, lam1180st refridgerator and microwave were plugged into the same outlet. i heard a loud pop. circuit breaker popped. i reset and the frige works fine. Microwave does not have power. the...
It is possible that the interconnection link(s) between the two sockets in the duplex outlet have blown apart. Turn off power at the electrical panel for this circuit, remove the outlet from it's box, and check the interlink on both sides. If obviously burned, replace the socket. A better option is to run another duplex cable from the breaker box to the outlet from a new breaker, cut the interconnections on the new socket, and wire the new cable to the isolated part of the socket. This supplies full power to each half and allows both units to run at the same time.
Oct 19, 2009 | LG 1.2 Cu. Ft. Mid-Size Microwave -...
Mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
Oct 29, 2008 | Clarke Power Products Welding Tools
Power supply cable
The power cable using is the normal 3 pin power chord used on computer.
U need to check the power chord and the wall socket...
Jul 24, 2008 | Toshiba DP80F Printer
98 Dodge Caravan
The most common size is a T-50 Torx socket.
Jun 28, 2008 | 1996 Dodge Caravan
Speakal Ipig 2.1 Stereo Ipod Docking Station Pink Ipigpnk Kit Logo
65 people viewed this question
Top Speakal Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Speakal Audio Player and Recorder Expert? Answer questions, earn points and help others
