Question about Pramac Electrical Supplies
HOW TO CHANGE OIL IN A HOMELITE TECUMSEH 5000 WATT GENERATOR
SOURCE: checking oil in generator
I found some website help. I have this same problem.
http://www.powermate.com/faq.php?cat_id=3
http://www.powermate.com/faq.php?cat_id=3&faq_id=32
I also found out a lot about the Powermate company via a customer service email reply: This has an elusive customer service number that i have not tried yet.
Powermate Corporation is not a part of The Coleman Company, Inc. They have been an independent company for over 10 years and we have no information on their products.
Powermate manufactured generators, pressure washers, air compressors and air powered tools. Information about those products was available from
Powermate Corp.
125 Airport Road
Kearney, NE 68848
Toll Free: 1-800-445-1805 (disconnected)
or 402-758-6303 (disconnected)
Web Page: www.powermate.com
Earlier this year, Powermate transferred the right to sell air compressors and air powered tools to a company by the name of MAT Industries, LLC, 625 Barclay Boulevard, Lincolnshire, IL 60069, 1(800) 628-8815. This company may be able to help you with questions related to air compressors and air powered tools.
In March 2008, Powermate filed for bankruptcy protection. We understand that customer service inquiries to Powermate via emails, mail and telephone calls will not be answered. However, some information about Powermate and its products continues to be available at their website.
If the problem with your unit is with the engine, check the engine manual that came with the unit to determine whether the engine has a separate warranty from the manufacturer. When Coleman was affiliated with Powermate, they did. If so, you can contact the engine manufacturer for a listing of warranty centers in your area. The contact number should be in the engine manual.
If you are needing parts for a powerwasher, please visit the site
http://www.ppe-pressure-washer-parts.com/coleman-powermate-pressure-washer-parts for assistance.
Thank you,
Harold
Coleman Consumer Service
Posted on Sep 02, 2008
CarlGehrke
  • 169 Answers
SOURCE: need oil type for generator & motor for 5000 power mate
Unless you're in very cold locations use SAE 5W30 regular motor oil.
Posted on Dec 03, 2008
SOURCE: Need to know about this
To find a manual for this generator go to powermate.com and search your model and serial number. Good luck!
Posted on Mar 16, 2009
mamicheddy
  • 79 Answers
SOURCE: I have a Generac portable generator 5000 watts, won't start!
I am assuming the generator worked fine before the oil change. Now that you have done the oil change the genset does not start. These generators have a safety switch, which is basically an oil pressure switch that keeps the engine from running when there is not enough oil in the engine. Make sure that there is enough oil and if there is, look for a wire that runs along side of the engine to a round component. disconnect that wire and try starting. If it does not start then try to ground out the wire to the engine block. If this does not work, then there is other engine problems.
Posted on May 08, 2009
SOURCE: Coleman 5000 watt generator Tecumseh 10 hp engine.
it's running lean.....try resetting the choke partially when it begins to surge.....not completely closed, but enough to richen the fuel mixture (that's all a choke does btw..)
if that helps or clears the problem, your carb is outta whack.....cheaper to buy a new carb than keep taking back into the shop.
Posted on Feb 01, 2010
I have a homelite 5000 watt portable generator that starts to run for like 5 seconds and then just stops
check sump oil level
check oil level sensor that switches off the engine if the oil is to low
check fuel flow through the tap as they corrode internally and block the flow
Dec 31, 2016 | Electrical Supplies
We have a Maxa ER 5000 Tecumseh Generator, changed the oil and spark plug, no fire. How do you check the low oil switch?
Nancy, If you think this is the problem, simply unplug it. See links below.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How To Disconnect Your Low Oil Sensor
Re Testing Low Oil Sensor on Honda GX Engine
How to Test the Low Oil Pressure Switch on Generator
Generator runs then shuts off
Feb 26, 2016 | Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers ยท I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
What weight oil do I use for a 5000 watt Coleman generator
Depends on the temperature where yuo will operate it, but a good multi-viscosity oil like 10W-30 should work. 5W-30 for cold climates.
Sep 07, 2014 | Coleman Powermate 5000 Portable Generator...
Gasoline generator homelite 4400 watt will not run getting gas spark plug is fireing but will not start..
If it has sat for a while, empty the carb. float chamber, flush out with clean fresh petrol. Make sure fresh petrol is in the tank and try again.
May 13, 2014 | Briggs & Stratton Briggs and Stratton...
My 5000 watt Homelite Generator will start on the first pull but then runs for about 2 to 5 seconds and dies or it gets rough and then dies. I have cleaned the carburator and checked the full line for flow...
If you have an oil level switch on this generator, it could be that you have low oil level or the switch is bad. Check the oil level. Bypass the oil level switch.
How old is the fuel in the tank, and how full is the tank? Fuel goes bad with time due to the ethonol turning to gummy varnish like substance. Not keeping a tank full allows condensation to form on the inner walls, contaminating the fuel with water. Drain the tank completely and fill with new gasoline.
How did you "clean the carb?" If it was not completely disassembled, soaked in carb cleaner, and all jets and ports blown out with air, you could have blockages from the "bad gas."
BigDaddyPat
Jul 20, 2011 | Pramac 5000 Watt Generator
Need to know what oil to use in 10 HP 5000 tecumsah engine - goes on our generator and I lost the manual
It depends on what temperature range the generator will be operating in. Below is a chart from Tecumseh that shows different oils for different temperature ranges. It says on their website to use a high quality brand name oil so you don't have to get actual Tecumseh oil.25b21be.jpg
Feb 26, 2010 | Coleman Powermate Premium Plus 6250W...
May 08, 2009 | Electrical Supplies
How to change oil and what kind to use on a es 5000 generator
you should have a drain plug at the side and bottom of the motor crank case its a small plug with a square head how old is your generator if new put 10w30 oil if old put sae30w if really bad add some lucas oil treatment also now a 9 h.p. should take less then 2 quarts
Mar 23, 2009 | Pramac Storm 5000 Watt Generator
Electrical Supplies Logo
180 people viewed this question
Top Pramac Electrical Supplies Experts
RSole
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
