Question about GPS
I have a nextar gps but the screen is black no power
    Top Expert:
  • 14,553 Answers
If only being used with lighter plug look for a fuse inside that as most will work even if battery bad or very low--also inspect where that plugs in looking for a damaged connector.
Posted on Nov 06, 2012
Need new battery for Nextar gps yoku battery 3.7v
eBay... 3.7v generic lithium polymer battery. Check dimensions to make sure it will fit inside your device (most sellers have a pic with the dimensions of the battery). Solder red to red and black to black.... Reassemble device, and your done.
May 29, 2010 | Nextar Q3 GPS Receiver
Why does my gps nextar show a red light and not turn on screen is black tryed pushing reset button but nothing happens
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 25, 2009 | Nextar P3 GPS Navigation System
Doesnt go to navigation screen nextar x3-03
If it says it can't find map data then your SD card is corrupted.
It's a fatal flaw in the WindowCE 5.0 operating system that was used for Nextar GPS builds. Basically, if you have a power glitch while it's reading your SD card (contains the maps) then your SD card get's corrupted.
Don't expect any help from Nextar. You will have to get the original data from another person's SD card with the exact same model
Sep 13, 2009 | Nextar X3 GPS Receiver
My nextar GPS screen is flashing and won't turn on or off. I have had it for 1 week. X3-08 Please let me know. Tim Nextar X3-08
try tapping the bottom right of the screen with your finger, during the error or freeze up. > (gently)
Sep 03, 2009 | Nextar X3-08 Car GPS Receiver
NEXTAR 14-bct KEEPS FREEZING UP.
I just opened up a Nextar 14-BCT GPS unit and found the inner side of the ribbon cable is cracked. This unit has the exact same freeze on load screen as you do, so try looking inside, you may need the LCD ribbon cable or both LCD and LCD ribbon cable for your unit to function normally again.
Feb 23, 2009 | Nextar I4-BC GPS Receiver
Help with gps
Hi, Here is how to reset your device..
1- Turn off unit. 2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
If this helps you plz rate this 'fixa', if you have other questions post a comment & I'll be happy to help. Thank you kindly.
Feb 14, 2009 | Nextar Q4-04 Car GPS Receiver
Nextar w3g,can i update maps
I need up date for my nextar gps X3-03
Oct 20, 2008 | Nextar Q3 GPS Receiver
My gps not working
I had this problem and had to tap the right bottom part of the screen to get the proper screen to come up and just go from there!! You may have to do this each time when you use your GPS. Hope that this will solve your problem!
Oct 16, 2007 | Nextar P7 GPS Receiver
GPS Logo
14 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
