Question about Kenwood Kac-m846 4/3/2 Channel Amplifier Car Audio Amp
Which speakers (Front/Rear) to buy that match Kenwood KAC-M846 4/3/2 Channel Amplifier.
I do not know what speakers (Fronts/Rears) to buy as the most rear 6x9 speakers have power rating of 110 watts@ 4ohms each but amp is only 50 Watts/channel @ 4 ohms. Does that mean that the amp is highly underpowered and not suitable? Most articles say that amp power should be more than the speakers nominal input power.
  • samir saini Nov 05, 2012
    Note: Speaker input power is nominal not max power. Please bear that in mind when answering the Question
    Master:
  • 689 Answers
I don,t no where you are reading thease articles from,I installed car audio equipment for over 40 years, Untill i retired a couple of months ago, Who ever is writeing those sort of articles does not have the slightest clue what they are talking about, It is the opposite way around, It is allway better for yor (Speakers) To handle more power then what your amp puts out, Then you will not blow the spaekers, It is best to get speakers at least 20 watts more then what your amps maximuin (RMS) Watts are, Hope this helps you out, (PS) 50 watts (RMS) Is what most people go for, It is in no means (Under) Powered.
Posted on Nov 06, 2012
Testimonial: "Rob cleared the cloud of confusion and shared his wisdom and expert know how about car audio amps and speakers."
  • 3 more comments
  • samir saini Nov 06, 2012
    "Driving a high power capacity speaker with a very low powered amp is more dangarous than a high power amp driving slightly less power capacity speaker. It is the low power amp when maxed out , clips and causes maximum damage to speakers." This is the bottom line message in most video reviews and articles. for examplehttp://www.crutchfield.com/S-z38o4EjeILG...
    Thanks for the reply Rob. Highly appreciate that.My apologies as this comment should have been before my previous one. Because of all the confusion I posted this question.
  • Rob getz Nov 06, 2012
    Don,t worry, I have seen a lot of articles on the net, That if the guys that wrote them new , Any thing about home & Car audio, They would be (Dangerous) It is true that a low powered amp will damage, High power Speakers, But if you look in a Stereo review magazine or High Fidelity (Magazine) About amps ,You will see (Articles) From actual (Certified) Electronic (Technicains) Not sales men in thease audio (Stores) Never go buy the garbage they feed you, Or that some of thease (Young) Guys tell you Allso (That) Call them self a car (Audio) installer, e
    Thank you most kindly Rob. Can you please point me out in the right direction where to look for the right information on the web.
    Samir, That is verry hard question to answer for you buy,Trying to get the right answer buy useing the web,All as i come across is verry miss Leading information buy useing the web to get (Proper) answer on anything, I have fround the only way to get a proper answer on Audio is from a repitable (Audio) Magazine, Where you no the (Company) Has been in buisiness for a long time,
3 Suggested Answers
SOURCE: KAC-9104D output terminals
ok i have the same amp and 1 2ohm dvc sub and was woundering the same thing but from futher research and askin sum xsperts. What i found out is that it is only one channel and even tho there are 2 (+) and 2(-) they actually connect inside the amp makein it one . so if u wanted to wire sumthing parralel u wouldnt have to hook wires from one coil to the other on the speaker , u can just hook it up to the amp. so basically both +'s and negatives on the amp are actually one within it so all the power if you only use one set of them and if u wanna add more subs its just easier to add to the amp by using the xtras .
Posted on Feb 15, 2009
  • 5 Answers
SOURCE: Kenwood KAC-8103D Power Amplifier wont turn on
it sounds to me like its burnt.but with some amps the screws that hold it in place have to be screwed into the car chassisfor grounding. be careful not to srewe into hidden wires.
Posted on Apr 15, 2009
Ihave a keenwood kac 7252 amp that is running two mtx thunder 4500 12`s but amp fuse keeps blowing at higher volume why?
1.-check proper heat sink, or dissipation.
2.- check speaker impedance. Must match between amp and speakers.
3.-low power line on the house may cause low efficience work on the amp, overheat, and finally fuse protection.
4.- finally, check speaker wires. Thin cable overheat amp too.
Nov 23, 2014 | Kenwood Kac-7252 2-channel 1000watt Power...
Best subs for the kenwood x812d
Try and match the rms output of the amp to the speaker , if the amp puts out 150 watts RMS make sure your speaker is at least 150 watts RMS.
Feb 03, 2014 | Kenwood eXcelon KAC-X812D Car Audio...
What colors are ignition and 12 v
Ignition wire for the radio is RED.
The constant 12v is YELLOW.
BLUE is the remote/power antenna.
ORANGE is for the dimmer.
PURPLE pairs are right rear speakers.
GREEN pairs are left rears speakers.
GRAY pairs are right fronts and
WHITE pairs left fronts speakers. Hope this helps.
May 19, 2011 | Kenwood KDC-MP208 Car CD/ MP3 Player
Where can i get a new kenwood speaker level input cable for my Kenwood KAC-6202
Usually i would consult a radio installer company Like a Mom and pop store or Best Buy.
Jan 24, 2010 | Kenwood KAC-6202 Car Audio Amplifier
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
KAC-8070 kenwood 4-channel power amp
Audio section
Max Power Output (4 ohms, 1kHz)
Rear 70W + 70W
Front 35W + 35W
Max Power Output (4 ohms, 1kHz, 10% THD)
Rear 45W + 45W
Front 25W + 25W
Max Power Output (4 ohms, 1kHz, 1& THD)
Rear 37W + 37W
Front 20W + 20W
Frequency Response (-3dB)
Rear 2 Hz ~ 100 kHz
Front 5 Hz ~ 50 kHz
Sep 27, 2009 | Kenwood KAC-8101D Car Audio Amplifier
Need to know
I would recommend running a four channel amplifier using component speakers up front and co-axial speakers in the rear. You can add more speakers up front, but it depends on what you're trying to accomplish in your car. Do you want it louder? Do you want it clearer? Any system will benefit from an amplifier. More power to your speakers will give you better sound because you'll have more accurate control over the speaker cone. This extra power will result in better clarity, not only at high volume, but low volume too.
Sep 06, 2008 | Kenwood KDC-3024 CD Player
Car audio
Yes you can use the speaker output in conjuction with the rca pre-outs...but depending on the wattage of the amp, there may be a big difference between the loudness of the front speakers over the rear speakers. If you have a 4 channel amp you can put the rear speakers on the amp also and lower the input gain for the rear speaker. Or if you have a 2 channel amp, you could use a passive crossover to filter out some of the bass to the rear speakers since they are smaller, this would help prevent over-driving them...as it is normally too much bass that distorts and blows a speaker. I'm not sure what you are asking about the hi-rear preouts vs the mid front pre-outs. If you decide to use the amp for the fronts you should be able to connect the amp from the front preouts of the deck. Hope this helps.
Mar 30, 2008 | Audio Players & Recorders
OEM gm stereo
If your amplifier has what they call High level inputs (basically inputs on the amp that you run the speaker wires from your radio into), you can splice wires from where the connectors are on your rear speaker(s), still leaving the speaker hooked up, and use those as an input into the amp. If your amplifier does not have high level inputs, a convertor is available to turn an audio signal from your radio output speaker wires ( spliced in just as above, leaving the speaker hooked up), into an rca output jack. Or the best thing to do would be to buy another say 2-4 channel amp w/high level inputs and rca inputs and outputs, and run your rear speaker wires into the amp. Then you'll be able to run the rca cables out of that amp and into the sub amp, and you'll have the new amp to power your rear speakers or rears and fronts. That would be ideal. But, A convertor is your best bet. Got em at best buy, circuit city, etc. Hope this was helpful.
Nov 25, 2007 | Car Audio & Video
My back speakers wont produce any sound
OK I believe there is a small indented "Reset Button" around somewhere on the back of the unit, With the unit powered ON, & using a small diameter implement, straightened paper clip etc, press IN the button and this should "Reset" ya unit. This may indeed fix all your problems as the Unit "Reads" the speakers at turn on.
Aug 08, 2007 | Kenwood KAC-8403 Car Audio Amplifier
Kenwood Kac-m846 4/3/2 Channel Amplifier Car Audio Amp Logo
534 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
