Question about Jet Health & Beauty
Ultra 3 wiring diagram
Where is the electrical shunt for the charging meter, the actual meter seems fine but does not indicate eventhough the battery charges ??
  • Ralph Moonshower
    Ralph Moonshower Nov 07, 2012
    Just need a schematic of the charging circuit including the meter next to the power cord conneter on the chair base, thanks for FAQ responses.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
The meter is an amp indicator, therefore wired in line with charger, if batteries are charging and meter is not indicating then the meter is bad. if batteries are full then it will move very slightly when batteries are low it moves more
Posted on Nov 09, 2012
  • Ralph Moonshower
    Ralph Moonshower Nov 09, 2012
    Are you sure the meter is in series w/the battery w/no shunt? the meter is good and can be deflected w/a few ma of dc current.
  • Ralph Moonshower
    Thanks for your erply
3 Suggested Answers
  • 186 Answers
SOURCE: charging system on a Jet 3 ultra power chair
rectifier on charger
Posted on Aug 14, 2012
vetteman3002
  • 2299 Answers
SOURCE: After installing new batteries(BC12350) on my Jet
Do you have the owners manual? From doing this job, I always try to start with the most simple solution first. Make sure that the batteries are hooked up properly. Then my second suggestion would be to make sure that the front battery has a good connection. Then third would be that the back battery has a major load on it, for it to be getting warm. Like maybe it is grounding out. You can check this by disconnecting the positive cable and reading the continuity from the cable to ground. It should not have continuity. That should give you a place to start. If this doesn't solve the problem let me know . And I will help more.
Posted on Oct 26, 2010
Craftsman 917289101 wiring diagram
The diagram will not be of much help. Try a an ohm meter for continuity, wire by wire with ground.
Jul 06, 2015 | Craftsman Garden
2001 Electraglide Ultra..battery won't charge. Where do I test the output of the Volt. Reg.?
Hi Thomas, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in aprerage then get out your test light and track down the short in that circuit.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v while cranking replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor.
17. For a free wiring diagram please visit the website below and good luck.Harley Davidson Wiring Diagrams and Schematics
Nov 18, 2012 | 2001 Harley Davidson FLHTCUI Electra Glide...
My Harley Voltmeter pegs out at 16+ for hours of riding!
Hi Adeggert, perform the following tests:
3. Make sure all connections are clean and tight especially the negative cable at "BOTH" ends.
17. For a free wiring diagram please visit the website below. Good luck and have nice day.
Sep 03, 2012 | 2010 Harley Davidson FLHTK Electra Glide...
Why dos my 95 ultra classic volt meter drop
Hi Gary, you could have a bad connection between your battery and the volt gauge but more than likely you have charging system issues. Try to perform the following tests:
Aug 26, 2012 | 2000 Harley Davidson FLHTCUI Electra Glide...
Pucrchased 2001 ultra classic. Battery would not stay charged. Replaced battery and still would not keep charge. Replaced ststor and voltage regulator. Rode 750 miles and stator went out. What would c
Hi Ed, perform the following tests:
3. Make sure all connections are clean and tight especially the negative cable at BOTH ends.
17. For a free wiring diagram please visit the website below and good luck. Harley Davidson Wiring Diagrams and Schematics
Jul 07, 2012 | 2001 Harley Davidson FLHTCUI Electra Glide...
How do i test the alternator for 2003 ultra classic harley davidson
Hi Harleyrid564, perform the following tests:
Mar 23, 2012 | 2003 Harley Davidson FLHTCUI Electra Glide...
Have a jet 3 power chair will not take a charge, can't tell that iy is charging
Cathey when you plug in the charger look at the rear of the chair at the meter if the chair is charging then the meter will indicate some amperage reading when it is fully charged the meter will read zero. Also turn on the chair and if the lights are scrolling or flashing it shows that the charger is plugged in. Now if after the meter reads zero (if it ever does) the lights on the joystick should all be lit indicating a full charge. If you aren't getting all the lights and the meter indicated the charger was working then you need to replace the batteries Hope this helps
Mar 24, 2011 | Jet 3 Ultra Power Chair
Shop rider sovereign voltage indication. Brand new fully charged
hi Richard,
Does the scooter actually lose power after the 3 leds show ?
If it is losing power then a suggest to try some other batteries to confirm dodgy batteries, check the terminal connections etc.
If it does not lose power then the volt meter is at fault, if you can check the voltage before riding then after it shows only 3 leds , if there is a big drop, check the charger first to make sure the batteries are getting fully charged.
Regards
GeWiz.,
Dec 21, 2009 | Electric Mobility Shoprider Electric Power...
2003 Ultra shuts off while riding
how many lights are you running? try disconnecting the battery and hooking up a shunt with a volt meter or a current meter inline. then check the current with different accessories or everything running. If you have a big load and stereo amp you may need to upgrade the charging system and the Circuit Breaker or try a aftermarket CB.
It happened once to me, riding slow, new pavement, very hot day, spot lights and stereo amp on.
Have a new CB on order but, put on another 4000 miles without another problem????
Jun 29, 2009 | 2003 Harley Davidson FLHTC Electra Glide...
With all DC systems on no negative Ah readings
The shunt needs two (2) wires coming from it to your amp meter. If the meter reads backwards polarity, reverse the shunt leads.
May 28, 2009 | Xantrex Technology Xantrex LinkLITE...
Health & Beauty Logo
174 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
