Question about Garden
Echobackpackwontshutoff SHUT OFF SWITCH WONT SHUT OFF BACKPACK
  • 430 Answers
Check switch for continuity when in the stop position. Check wires for continuity from module to switch. If wires and switch are good then the module will need to be replaced.
Posted on Nov 12, 2012
Why won't my Husqvarna 150 BT blower shut off? It starts and runs great, but won't kill with the switch.
Kill switch most likely has broken wire between switch and engine. When in "kill" position, it should connect the top of the sparkplug to the rest of the engine. If it doesn't, either the switch is bad or the wire is.
Jun 15, 2015 | Husqvarna 150BT 50CC Gas Leaf Backpack...
Backpack blower will not shut off when knob is pushed to "stop". Have to disconnect spark plug boot to shut off blower.
Your off switch may be wet or disconnected. You can try spraying it with a little bit of contact cleaner or WD to clear the moisture. If this doesnt work you can pull a cover and trace back the wire and see if it just fell off or melted. Good luck and be safe!
Oct 04, 2014 | Stihl Br 320 340 400 420 Backpack Blower...
Br500 wont start
fuel filter inside the tank and inline
bad start stop switch
bad carbiration
bad spark plug {burned}
bad ht cable
bad magnito coil
take your pick and rull them out one by one
Feb 08, 2014 | Stihl Br550 Br500 Backpack Blower Fan...
Blower not getting spark
You will need to disassemble the unit to expose the ignition module. Remove the ground wire from the module and reassemble ( you can not spin the flywheel fast enough by hand to make a spark you need to reassemble the unit and use the recoil starter) and check for spark. If you have spark there is a problem with the wires or the switch, if there is no spark then the module is bad and needs to be replaced.
Tip 1. Dont start unit with ground wire disconnected- you wont be able to shut it off.
Tip 2. Laying a spark plug on the head or grabbling the end of the plug wire are not reliable ways to test for spark. You should use a spark tester.
Jul 15, 2012 | Echo Inc. 44 CC, Carb Certified Backpack...
150bt blower no spark
sounds like your kill/shut off switch is bad grounding it out. Unhook the small wire from the coil and see if you have spark then, if you do then the problem is the switch or safety switch and or possibly the wires that run to the switch .
Dec 03, 2011 | Husqvarna Backpack Blower 25cc, 140 Mph,...
My backpack leaf blower wont star. It was working fine yesterday now it wont star at all. Any suggestions?
Hi! Look for the spark plug,take it out and replace it with a new one,and then try to start it up.Also check if you have fuel and oil mixture right.
It is the most common failure in such hardware.Good luck!
Mar 06, 2011 | Ryobi Backpack Blower 25.4cc
I have a Husqvarna 125BT blower. It runs fine but
GAP is the opening between terminals at the end of the spark plug ( on the threaded side of the spark plug) but spark plugs should come with the right gap from factory, as for your problem with to restart your blower it is ok just need to let cool down for 15 min or more.
May 15, 2010 | Husqvarna Forest & Garden 125bt Backpack...
No spark at spark plug and unit will not start
what kind of gear is it. is there an on off switch? could the wire from the switch be earthed because its worn thru?? check this and see. lets face it. no spark it wont run. try another plug too. sometimes thats the answer
Apr 03, 2010 | Echo Pb - 413t Backpack Blower
Reading disks but wont burn them
The only "help" is to purchase a new "internal" CD-writer, disassemble the casing, remove the "dead" CD-writer, insert the new one, and reassemble the casing.
Nov 05, 2009 | Micro Solutions Backpack Burner
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
