Question about Akai LCT3201TD 32 in. LCD Television
Akai tv combo
Sound but no picture, screen appears to be turned off, I assume no power is being diverted to itI have sound, but no picture on my unit. I watched it last night, turned it off, this morning I have no sound, but can change channels, Will not play a DVD either.
    Master:
  • 763 Answers
Sir try to check the menu settings of your tv like the audio settings and also the connections of your dvd to your tv. it must be configured by mistake or changed.
thank you for using fixya
CHARCOIS
Posted on Jan 05, 2009
Akai tv/dvd combo LCT3201ad 32" auto-shutoff or turns off after 3-5 seconds after being turned on.
Change input device to some other like a DVD player and see.
Switch off TV, switch off power, remove plug and wait for 48 hours and retry.
If problem persists, call in a qualified service technician.
Aug 05, 2012 | Akai LCT3201AD 32 in. LCD Television
Akai 32" wide-screen lcd tv/dvd
Tramaine, I would suggest a new PSU. I have used ShopJimmy.com in the past with great success. Here is a link to the part you need on their site. Hope that helps! TeeVeeMan2
http://www.shopjimmy.com/megmeet-mlt168a-power-supply-unit.htm
Aug 18, 2011 | Akai LCT3201AD 32 in. LCD Television
When i turn on my Akai LCT2715 tv the blue screen that says akai appears but disappears sooner then it normally does, then i receive sound but no picture. Even when i change the source (to my ps2 or super...
Use a flashlight to shine light near the screen in a 45 degrees angle when the TV is ON, press menu to see if you get fainted dark video in the background. fainted video indicates that the backlight is defective.
This type of failure could be due to a lower backlight inverter voltage as well.
Check this link for availability.
Let me know if you require further assistance.
Jul 02, 2009 | Televison & Video
No picture (black screen); making popping/crackling sound
there is a possibility that the semiconductor in power supply side damaged due to electrical surge. more likely the STR IC of Diodes.
Jun 01, 2009 | RCA P61960 61" Rear Projection Television
No power
If you have an external power supply check it with a voltmeter
Is the red stand by light on?
yes, but no pictures ,no sounds you will need to be a good techies to fix it.
No , open the back and check the fuse close to the connector from the power supply cable.
cheeers
May 15, 2009 | Akai CFT2490 24" TV
Akai combo
There could be a back light inverter failure or the power supply is not providing enough power to the back light inverter.
Oct 14, 2008 | Akai LCT3201TD 32 in. LCD Television
AKAI Black TV screen, but still have audio
I think your Video Drum needs to be replaced since it's bad. You can get replacement Video Drums on the Internet.
Mar 10, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Akai model ws-p28ntf-sf-d-gb (s) tv/dvd combo
I believe you either have a problem with your Power Supply inside your TV from a defective component in the circuit or you have a problem with the Picture Tube on your TV. I don't recommend you working on TV's by yourself unless you know what you're doing since you can get badly shocked. You need to discharge the Picture Tube on the TV before you work down any further. If you don't know what you're doing then you should get someone that knows what they're doing to work on your TV.
Jan 20, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
AKAI 50"LCD T.V.
you need to check the resolution settings on your cable box
Dec 16, 2006 | Akai CFTD2052 20 in. EDTV-Ready LCD...
Akai LCT3201TD 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
