I have a 90w ac/dc power adapter w/usb K33403. It has worked fine and someone tripped over the cord and the power adapter now makes a beeping sound whether it is plugged into the computer or not.
  • 89 Answers
Replace the adapter. They are relatively cheap and your problem is solved. Just do a search on Google and you'll find plenty of them available.
Posted on Jan 05, 2009
Wire my ac jack for my samsung np365e5c
The AC adaptor goes into the AC socket, NOT the computer connection. The Computer connection is DC and comes from the DC side of the Adaptor. If you mean the DC socket has broken, then you need someone to replace it inside the computer.
If the AC adaptor has failed, you can buy a replacement ( 19V 3.16A 60W AC Adapter).
See the Manual
http://downloadcenter.samsung.com/content/UM/201408/20140829115137641/Win7_Manual_eng.pdf
Feb 23, 2015 | Samsung Computers & Internet
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
My hp ac adapter KEEPS FREEKIN BEEPING
Hello, NO it isn't going to explode, you need to replace the battery or the power cord it isnt charging or being charged.
Jan 16, 2013 | HP Original 90w Ppp012d-s 519330-003 Ac...
What are the Schamatics to a Dell ac/dc adapter MODEL: DA90PS1-00
Specification of DA90PS1-00 AC Adapter:
Output: DC19.5V 4.62A
Power: 90W MaxOutlet: 3-Prong
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin
Sep 18, 2011 | Dell Laptop DC Power Jack (DELLDL271600)...
How do i change out the charger port of my gateway p-6301? I believe this is the issue... I have tried replacing the battery and power cord, but it still will not detect that the cord is plugged in.
Im very sorry to hear that, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Aug 18, 2011 | Computers & Internet
Dell latitude e6410 chargin fault ,will run on dc adapter but shows not chargin ,battery not conected
  1. If the motherboard has ever been replaced, check the service tag section of the BIOS. If it is blank, enter the service tag off the bottom of the system. (The charging circuit will not work without it.)
  2. Also in the BIOS see if the AC adapter is identified or is listed as UNKNOWN. If the system cannot ID the adapter as a Dell Branded AC adapter 90w or larger, then the charger is again disabled. If unknown, check the barrel end of the DC jack of the adapter for the fine wire in the center, if broken or bent, then the adapter is not identified.
  3. Try with a different Dell branded 90w or larger D or E series adapter.
if all the above make no difference, and the Adapter is recognized, the battery may be at fault.
http://www.fixya.com/support/r3743571-long_will_battery_in_portable_computer
if the adapter is unknown, replace the adapter, unless it works normally on another system, and the other system's adapter has the same issue, in that case the motherboard is likely the issue.
Note: a 65w Auto/Air adapter will only charge the battery if the system is OFF
Jul 27, 2011 | Dell Latitude E6410 Notebook
My Dell XPS-M1530's 90W-AC Adapter beeps and doesn't work
Thi might affect the XPS system performance. Please have AC Adapter replaced.
Nov 17, 2009 | Computers & Internet
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Kensington 33403 power adapter beeping and providing no power
I have the same model. I pinched the cord from the from the supply to the notebook. The cord looked ok from the outside, but was damaged internally. I called Kensington support and they sent out a referb unit at no cost using only the serial number to validate the date of manufacture. The company has a two year replacement policy from purchase date, but if you lose your receipt they came go by maufacture date. give them a call.
HAL
Feb 21, 2009 | ACCO Brands Kensington Wall/Auto/Air...
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
