Question about Denon 201SA Audio Shelf Systems
Where can I geta new set of speakers for the denon 2016Asystem
    Master:
  • 689 Answers
They do not have to be the same, Any decent set of speakers will work on it for you, As long As the (OHM) Rateing is the same as the denons,
Posted on Nov 05, 2012
Denon instructions
I don't have this particular model but I have owned 2 Denon receivers and I suspect yours is similar. On my Denon there is a manual speaker set up with a test tone for each channel. This will allow you to boost or reduce the DB level of each speaker individually. I would do this while sitting where you do while watching TV. be sure:
1. The receiver is in surround sound mode to do this.
2. My receiver also came with a microphone that can be plugged into the receiver to allow automatic level set up through what Denon calls the "Audyssey" set up. The equalizer setting are also located in the "Audyssey" settings.
You might check your manual before you begin.
Sep 07, 2014 | Denon Avr-4802R-Av Receiver-7.1 Channel
No Sound in Right Front Speaker- Denon AVR-1508
hi there,
have you check the system settings for each of the speaker..? should be set and balance all output of the speaker
`jack
May 24, 2008 | Audio Players & Recorders
No sound from Denon AVR 988
make sure the TV audio setting is set to send sound through to the Denon not just out of the TV speakers, you wont be able to do both
Mar 17, 2014 | Denon AVR-988 7.1-Channel Multizone Home...
Connecting computer speaker to a receiver
Which output section of the Denon are you using? Tape monitor out? And are you getting sound through the speakers (not the PC speakers) that are attached to the Denon speaker terminals?
Oct 26, 2009 | Denon AVR-1601 Receiver
Want to put set of outside polk speakers to Denon avr 2807
Do you have outputs for both A and B speakers? If so you can easily hook the outside speakers to the B outputs.
Jun 16, 2009 | Denon AVR-2807 Receiver
Protection circuit momentary activation. Not heat/speaker problem
Is it possible for you to lower the source level? if yes go ahead...
There is an automatic Dialogue normalisation function in Denon which is activated to reduce overly bright input signals. ( most movies have wide variation in sound levels and therefore this function is avaialble). (see page45 of your user manual).
When your system worked fine with the AVR 2808CI, then why is it giving problem with AVR 3808CI....???? You must ask Denon.
Protection circuits are activated when:
1). There is rise of internal temperature.
2).Core wires of the speakers are touching each other or a core wire is sticking out of the terminal and touching the set's rear panel or the speaker itself has a problem.
3). Speakers with an impedance other than specified are being used.
or
4). the set is damamged or has bad solder / dry solder connection .
If your AVR is new, please do not accept, the set could be faulty. The protection circuits should not be activated unless any of the above happen.
You must know, at times the protection circuits are not fast enough and it could burn some of the transistors on the power output circuit. With time, the solders on the circuit board could give way and give you problems later on.
You must sort out with Denon if the AVR is under warranty.
Best of Luck.
Mar 11, 2009 | Denon AVR 3808Ci Receiver
Back speakers with av denon 1908
Plug your rear 5.1 speakers into the surround speaker connections. Be sure to use the AVR 1908 set up menu to set rear speakers (not an amp assign). Hope this helps.
Jan 03, 2009 | Denon AVR-1908
Denon avr 2802 can't get subwoofer to work all else fine
in the Denon setup under speaker configuration set the sub to LFE+Main
Jan 02, 2009 | Denon AVR-2802
Is it possible to to have a home theatre with Denon AVR 3600
one option that may yield results, since the bose connection to equalizer is presently not possible is to set the speaker out put on the denon for 'small' on all but the front speakers.
and then set the delay for all speakers based on the distance to the amp.
this should result in better audio that that with the bose eq.
will work on the issue of using the eq. with the denon if you like. but, you will likely not improve on the sound with the denon set up correctly.
good luck
mark
Dec 17, 2007 | Bose 901 VI Main / Stereo Speaker
How to add more speakers?
In the end I biwired the speakers and that's worked fine.
Aug 12, 2007 | Denon D-M71DVS System
Denon 201SA Audio Shelf Systems Logo
41 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
