How to eliminate black/white lines on the screen ?
Black/white lines on the screen instead of picture
    Top Expert:
  • Televison & ... Master
  • 74,118 Answers
The video output section to your TV is faulty. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there
Posted on Nov 06, 2012
5 Suggested Answers
  • 1694 Answers
SOURCE: Picture went black
Check vertical B+ and replace vertical output IC.......Let me know if you need more help.................T.
Posted on Dec 11, 2007
SOURCE: Toshiba 27D46 Black Screen - White Horizontal Line
I fixed the problem by taking it to a repair shop
Posted on Apr 26, 2008
VtToolMan
  • 704 Answers
SOURCE: white line
This is cauced by a collaspe of the vertical output circuit. Normally a relatively easy/quick fix by a skilled repair tech. If you have a nice quality set that is less than 7 years old, it might be worth fixing, otherwise, you might want to consider getting a new one.
Give a call to a local service shop and tell them what TV you have and the problem and see what they provide for an estimate to repair, it might be worth doing and it might make your decision easier to go buy a new one.
Posted on Dec 15, 2008
  • 35 Answers
SOURCE: Rca 32 inch tv
this is a frame fault
the fact that you can still see the line when the tv is off is because you have been watching with the line and it has burnt into the crt.
time to buy a new tv
Posted on Sep 04, 2009
I have a Samsung LED computer monitor (model S23A300B). The monitor connects to my Macbook air. The Samsung monitor recently stopped showing the picture on my laptop. Instead, red, green, blue and white...
Try the plugging the setup into a different monitor to eliminate the lead however it sounds like the monitors died. With cost of screens even if you can get hold of one you'll be better off getting a new monmitor.
Jan 20, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
White screen
This is a problem with shutter not fast enough opening to take a picture indoor shows the horizontal lines. In sun light it is too slow and over expose the picture. Not worth the trouble to fix, buy another camera?
Jun 26, 2012 | Olympus Cameras
My LG TV has suddenly become darker all across the bottom of the screen (10cm strip) it still has colour but is darker. In left hand corner it is considerably darker and depending on what you are watching...
Hi; your TV has burn screen or traces.it comes from one image left on the screen for too long, it can get burned into the screen, making it visible at all times. You can actually eliminate most screen burns with the use of a PC computer and a black and white screen saver. This trick eliminates screen burn after a period of several minutes because the black and white screens flash quickly, removing all traces of color from the screen. This will eventually eliminate any burned images on the LCD screen. you can do it by creating a DVD picture slide with only black and white image. you can use a computer to make DVD picture slide first go to paint brush and draw only white then save as white.jpg. second burn it into nero or other dvd burner third play it to your DVD player connected to you LCD TV.it has to be played in full screen let the white image display on your HDTV for several hours or even overnight. It should remove any burned-in images or ghosts. hope this help...............
thanks....
Sep 13, 2011 | LG 32LD350 32 in. LCD TV
White lines across tv screen
Without seeing the lines I can't be sure what your set has wrong, but here are a some possibilities:
If the lines are lines are confined to the top inch or two of the screen and the picture looks otherwise normal, the trouble is bad capacitors in the vertical output circuit. Fixable by replacing the bad parts.
If diagonal lines are across the entire face of the picture tube and the picture looks washed out, the trouble is often a bad capacitor on the 200-volt line to the picture tube. This may be on the main circuit board near the horizontal output transformer, or on the small circuit board plugged onto the end of the picture tube. Again, replacing the bad capacitor can fix this.
If your TV is actually an RCA, someone may have bumped a rear-panel adjustment. On the back of the TV near the bottom right are two small knobs. RCA left these adjustments exposed inside of putting them inside the set like other manufacturers. These sometimes get bumped if someone was behind the set cleaning, or if a pet got back there and hit them with a tail. The top knob adjusts focus, and the bottom knob adjusts something called G2 or screen voltage. If this gets turned up too high it can cause the faded picture and diagonal white lines. Turn the adjustment down until a black screen looks black instead of gray.
A bad picture tube or horizontal output transformer can also cause lines through the picture. If this is the case with your set, it's time for a new TV. The transformer is relatively inexpensive but labor costs aren't, and the repair bill may exceed $200. If the tube is bad, there's no point even considering repair. The tube cost alone exceeds the cost of new TV.
Hopefully your lines are easy and cheap to fix. Good luck, and thanks for using Fixya!
Jul 22, 2011 | RCA F35673MB 35" TV
I cannot seem to get a clear picture with my camera. The color is off and it looks blurry sometimes. What am I doing wrong?
Thee pictures are blurry most likely because you are shaking the camera as you are taking the picture. To help eliminate this lean against something solid, use the viewfinder instead of the LCD screen or mount the camera to a tripod. The colour could be from not selecting the proper white balance for the scene you are shooting. Look in you manual and see if you have an "auto" white balance and set the camera to that.
Dec 28, 2010 | Polaroid a300 Digital Camera
The color is all red.
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Jan 01, 2010 | Hitachi 51F500 51" Rear Projection...
I have a sony cyber-shot 6.0 mega pixel it will take pictures and after I hookit to the computer u can see them but the view screen on the camera will only show a white screen.Camera's view screen stay...
Skip using the camera for downloading and use a card reader instead. A lot of troubles will be eliminated.
A card reader is not expensive.
A card reader can be found in most electronic stores or on a site such as Ebay.
Nov 14, 2009 | Sony Cyber-shot DSC-S600 Digital Camera
Vertical lines down center of Plasma TV
Because of the complexity of these sets, the fault can be much more than just a bad IC. These sets are serviced at the board level. After changing the board, calibration is done as necessary.
The fault may be in the matrix power driver output area, or in the plasma screen back-plane layer itself. This has to be determined by the process of elimination.
I can tell you in advance that this will not be a low cost repair.
Jerry G.
Jan 10, 2009 | Philips Magnavox 42MF521D/37 Television
TV Keeps flashing Fuzzy black and white static then the picture appears
The half picture is a verticale problem. This is difficult to repair. Send to a repair shop.
Jul 19, 2008 | Sony KV-36XBR450 36" TV
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Jun 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
